I am running Cinnamon desktop on manjaro. Two days ago, I could press the Print Screen key to grab an screenshot and save it to my Images folder. Now, whenever I press the Print Screen key, a “Not allowed” icon appears on the bottom of the screen (see attached photo).
I had to take a photo with my phone because… well, I can’t take screenshots, obviously ;-).
After update i have same problem.I reinstalled system first there was no problem than i update system problem came again.
Help please i need screenshot.
In the AUR is an app called Ksnip, install it and see what happens. I have many personal pc’s and laptops using my version of Cinnamon and have not had any issues, but then again I have Ksnip installed on all of them.
There is cinnamon screenshot app at system before update it was working very well.But update was about cinnamon and problem came after it.I hope it will fix a simple update.
My Print Screen key also is out of order since the 4.8.0 upgrade. Need this, so my workaround for now was to use the screenshot app that I already had installed (Gnome) and ad it to my panel. So now I can right click on it to make screen-shoots and choose screen or window.
Edit: Panel right click choice Window does not work for me, just grabs full screen with the panel menu so I probably will use it differently.
There was an issue with gnome screenshot and hi-dpi which I filed a bug tracker for so I switched to pantheon-screenshot from pamac gui. Pantheon-screenshot is working fine on the latest cinnamon update
Re installing those packages doesn’t have any effect on my system.
I ended up making a custom keyboard shortcut, named it Screenshot, and pointed to /bin/gnome-screenshot (to the shared library)
After that give it a keybinding you like, i used printscn button.
Only issue remain is that the playbutton does do the same, so i removed all keybindings from the play button, i don’t use that.
