Screen shots and screen capture corrupted
I’m not sure if this actually a desktop environment / window manager issue or a graphics driver / acceleration issue, but the most similar previous posts were here.
I just installed Manjaro Budgie on a new Dell XPS 9310 with Intel Iris Xe integrated graphics and a ~3.5k screen. I consistently have issues taking screen shots or sharing my screen. When I do, the screen capture shows fragments of previously closed or minimized windows or sections of pure black. While sharing my screen via Zoom I see these fragments glitch in and out along with the currently open windows.
This behavior is mostly consistent between all of the screen shot and sharing tools I’ve tried including:
  • gnome-screenshot
  • gnome-screenshot --window
  • xwd -root
  • Zoom (screen sharing)
  • Zoom (window sharing)
  • Firefox (screen sharing)
  • Firefox (window sharing)
The one exception is that screenshots taken with shutter seem to work and gnome-screenshot --area sometimes works.
Here’s my inxi -SGxxx output:
  Host: grant-xps13 Kernel: 5.12.16-1-MANJARO x86_64 bits: 64 compiler: gcc
  v: 11.1.0 Desktop: Budgie 10.5.3 info: budgie-panel wm: budgie-wm
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell
  driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
  Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
  bus-ID: 3-6:3 chip-ID: 0c45:672a class-ID: 0e02
  Display: x11 server: X.Org 1.20.11 compositor: budgie-wm driver:
  loaded: intel unloaded: modesetting alternate: fbdev,vesa
  resolution: 3456x2160~60Hz s-dpi: 96
  OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 21.1.4
  direct render: Yes
This is possibly the the same as or related to issues observed on the forums before:
Screenshot tools capture garbage with Iris Xe graphics
Manjaro Desktop Environment Malfunction Causing Screenshot and Zoom Glitches
I did try closing all of my virtual desktops as suggested in the second topic, but that did not resolve the problem. I also attempted to switch window managers as suggested in the first thread (specifically to matter), but it seems anything other than budgie-wm causes other parts of Budgie to crash.
The presence of very similar issues on KDE and Xfce makes me think this might be a graphics issue and not a Budgie issue, but I’m not sure. Any help or suggestions on other things to try would be greatly appreciated.
Full output of inxi
$ inxi --admin --verbosity=7 --filter --no-host --width
  Kernel: 5.12.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
  root=UUID=03c478d8-df69-48b5-ae3f-9237a8fff5b0 rw quiet apparmor=1
  Desktop: Budgie 10.5.3 info: budgie-panel wm: budgie-wm dm: LightDM 1.30.0
  Type: Laptop System: Dell product: XPS 13 9310 v: N/A serial: <filter>
  Chassis: type: 10 serial: <filter>
  Mobo: Dell model: 0DMPXV v: A00 serial: <filter> UEFI: Dell v: 2.2.0
  date: 04/06/2021
  ID-1: BAT0 charge: 12.3 Wh (24.1%) condition: 51.0/51.0 Wh (100.0%)
  volts: 7.4 min: 7.6 model: BYD DELL FP86V0B type: Li-poly serial: <filter>
  status: Discharging
  RAM: total: 31.08 GiB used: 10.01 GiB (32.2%)
  Info: Quad Core model: 11th Gen Intel Core i7-1185G7 bits: 64 type: MT MCP
  arch: Tiger Lake family: 6 model-id: 8C (140) stepping: 1 microcode: 88
  cache: L2: 12 MiB bogomips: 47936
  Speed: 1049 MHz min/max: 400/4800 MHz Core speeds (MHz): 1: 1049 2: 646
  3: 1441 4: 942 5: 1085 6: 835 7: 1188 8: 1038
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
  arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2 avx512_vnni
  avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
  avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2 cdp_l2 clflush
  clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl
  dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma
  fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp hwp_notify
  hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid invpcid_single
  lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
  nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
  pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good
  sdbg sep sha_ni smap smep smx split_lock_detect ss ssbd sse sse2 sse4_1
  sse4_2 ssse3 stibp syscall tm tm2 tme tpr_shadow tsc tsc_adjust
  tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid
  x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
  screens: 1
  Screen-1: 0 s-res: 3456x2160 s-dpi: 96 s-size: 914x571mm (36.0x22.5")
  s-diag: 1078mm (42.4")
  Monitor-1: eDP1 res: 3456x2160 hz: 60 dpi: 303 size: 290x180mm (11.4x7.1")
  diag: 341mm (13.4")
  direct render: Yes
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
  driver: sof-audio-pci-intel-tgl
  alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
  chip-ID: 8086:a0c8 class-ID: 0401
  Sound Server-1: ALSA v: k5.12.16-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.31 running: no
  Device-1: Qualcomm QCA6390 Wireless Network Adapter [AX500-DBS ]
  vendor: Rivet Networks driver: ath11k_pci v: kernel port: efa0
  bus-ID: 72:00.0 chip-ID: 17cb:1101 class-ID: 0280
  IF: wlp114s0 state: up mac: <filter>
  Permissions: Unable to run lvs. Root privileges required.
  Local Storage: total: 953.87 GiB used: 35.99 GiB (3.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: PC711 NVMe 1TB
  size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 rotation: SSD serial: <filter> rev: 41001131 scheme: GPT
  ID-1: / raw-size: 953.57 GiB size: 937.53 GiB (98.32%) used: 35.4 GiB (3.8%)
  fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
  uuid: 03c478d8-df69-48b5-ae3f-9237a8fff5b0
  used: 304 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  label: NO_LABEL uuid: D145-A16B
  ID-3: /run/user/1000/keybase/kbfs raw-size: N/A size: 250 GiB
  used: 602 MiB (0.2%) fs: fuse dev: /dev/fuse label: N/A uuid: N/A
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
  Device-1: 3-3:2 info: Shenzhen Goodix FingerPrint type: <vendor specific>
  driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
  chip-ID: 27c6:533c class-ID: ff00
  Device-2: 3-6:3 info: Microdia Integrated_Webcam_HD type: Video
  driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 50.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 0 fan-2: 0
  Processes: 296 Uptime: 3h 56m wakeups: 9953 Init: systemd v: 248
  tool: systemctl Compilers: gcc: 11.1.0 Packages: 1450 pacman: 1440 lib: 431
  snap: 10 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.05
:+1: Welcome to Manjaro! :+1:
Does this also happen on 5.10 LTS (Long Term Support) and 5.4 LTS?
:thinking:
Do you have a custom xorg-config for your intel? There is an option (uxa, I believe) that creates this errors.
try lowering the resolution.
Still happens on 5.10.49. My WiFi doesn’t work on 5.4, so I wasn’t able to try that easily.
Also didn’t help at all. I tried both changing the resolution and scaling.
No custom xorg-config, but you might be on to something here. I tried creating a custom config and setting the AccelMode to UXA (instead of the default SNA) and the issue goes away. It also makes my desktop so slow it is nearly unusable, so that’s not a very useful workaround for me. It does suggest that the SNA graphics acceleration is involved though.
That’s an interesting result, I will try to test it in a week when time permits. :slight_smile:
The ArchWiki has some hints about the different Acceleration Methods Intel graphics - ArchWiki .
My xorg-conf has none, so I guess I’m using the default. However, your device is much newer than mine, so I suggest waiting for new kernel/driver versions.
I think, the problem is solved in Kernel 5.14!
edit: Sorry, just caught it again…
