Hello.
My system specs are as follows:
I’ve recently run into some difficulties I believe are from my desktop environment.
The problem initially lay with my attempts to perform a screenshot using Spectacle. Often I find that after pressing the print screen button on a page like the one below:
The Spectacle popup would instead generate a screenshot of some other, possibly already closed page. For example, after pressing print screen while running Dolphin (as above), the screen shot generated (under the capture area of “Full Page”) would actually be this:
Which is really an application that I had closed earlier during the day. Initially I thought it was a minor bug I could work around by changing the area selected under Capture Mode in Spectacle (a highly imperfect fix), but I tried another Screenshot app and the results were the same. Furthermore, I’ve recently found that this glitch has made screen sharing in Zoom impossible.
This is a link to two very short videos of what my screensharing looks like to others over zoom. I recorded my shared screen to generate it.
As you can see the desktop environment is chaotic (notice the tray icons on the bottom right giving popups despite my mouse not being over them) with the desktop background and page partially overlaid against a PowerPoint presentation I was trying to make. However, from my perspective everything is perfectly fine. From my perspective, I’m giving a PowerPoint presentation and moving from slide to slide (you can actually see this in the holes through the overlaid desktop background). It isn’t always the desktop background being overlaid, however. Sometimes it’s some other application page (like Chrome).
I find that restarting the computer seems to “clear” the backlog of pages that pop up (asides from the desktop background), and this is what makes me think it’s a desktop environment issue.
I’m not very sure what’s going on exactly. I hope you guys can help me out here, because this laptop is critical and doesn’t have access to Windows at the moment. Zoom sharing is a vital feature.
Any thoughts? I’d be happy to answer any questions that can help clarify this situation to the best of my ability.
