Hi, I just got 2 new 27" monitors.
Both are running fine during operations, but when I boot the system I get a message from one of monitors, stating the current resolution is set to 3840x2160 instead of the recommend of 2560x1440.
The other doesn’t display show that message and has the proper resolution on launch.
I have tried this solution: ‘Resolution of login screen customizable - #2 by Mirdarthos’, but that didn’t work.
I’ve looked at the sddm.config, but didn’t find a way to set resolution.
KDE Plasma Version: 5.27.8
KDE Frameworks Version: 5.110.0
Qt Version: 5.15.10
Kernel Version: 6.1.55-1-MANJARO (64-bit)
Graphics Platform: X11
Processors: 8 × Intel® Core™ i7-4790 CPU @ 3.60GHz
Memory: 15.6 GiB of RAM
Graphics Processor: NVIDIA GeForce GTX 760/PCIe/SSE2
Manufacturer: MSI
Product Name: MS-7821
System Version: 1.0
xrandr returns:
Screen 0: minimum 8 x 8, current 5120 x 1440, maximum 16384 x 16384
DVI-I-0 disconnected (normal left inverted right x axis y axis)
DVI-I-1 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected primary 2560x1440+2560+0 (normal left inverted right x axis y axis) 600mm x 340mm
3840x2160 59.94 + 50.00 29.97 25.00 23.98
2560x1440 59.95*
1920x1080 119.88 60.00 59.94 50.00
1280x720 59.94 50.00
1024x768 60.00
800x600 60.32
720x576 50.00
720x480 59.94
640x480 59.94 59.93
DP-0 disconnected (normal left inverted right x axis y axis)
DVI-D-0 disconnected (normal left inverted right x axis y axis)
DP-1 connected 2560x1440+0+0 (normal left inverted right x axis y axis) 600mm x 340mm
2560x1440 120.00*+ 99.95 59.95
1920x1080 119.88 100.00 60.00 59.94 50.00
1024x768 60.00
800x600 60.32
720x480 59.94
640x480 59.94 59.93
I’m pretty sure I can set the screen with xrandr, but I’m unsure how, because as far as I’m aware this is for the setup during running operations.
And I haven’t found a page where the xrandr output is fully explained.
Best,
Edward
