I have currently the same issue since 2 or 3 updates, sometimes (not always) when the screen is locked, i move the mouse, the login screen appears, type in my password, hit return and nothing happen, no response.
Then, if i hit Esc, then move the mouse again, type in my password and it works. I do not have to restart my system.
The error related i see in my logs are the following :
kscreenlocker_greet[87921]: Failed to write to the pipe: Bad file descriptor.
kscreenlocker_greet[87921]: qt.qpa.wayland: Could not create EGL surface (EGL error 0x3003)
I changed my sddm theme without any effect.
This is not related with heavy process or lack of RAM, i have a quite recent Nvidia card, core i5 12th gen.
inxi -Fxza
Kernel: 6.14.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.14-x86_64
root=UUID=0701ca92-2b7e-41c0-b4dd-d91194313cdf rw rootflags=subvol=@
cryptdevice=UUID=d916a464-4abf-46bd-b36a-e81a6381e0fc:luks-d916a464-4abf-46bd-b36a-e81a6381e0fc
root=/dev/mapper/luks-d916a464-4abf-46bd-b36a-e81a6381e0fc
udev.log_priority=3 nvidia-drm.modeset=1 nvidia_drm.fbdev=1
NVreg_PreserveVideoMemoryAllocations=1 ipv6.disable=1
Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.13.0
Type: Desktop Mobo: BIOSTAR model: B660T-SILVER serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: 5.27
date: 09/12/2023
Info: model: 12th Gen Intel Core i5-12400F bits: 64 type: MT MCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151) stepping: 2
microcode: 0x38
Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
smt: enabled cache: L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 7.5 MiB
desc: 6x1.2 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 780 min/max: 800/5600 scaling: driver: intel_pstate
governor: powersave cores: 1: 780 2: 780 3: 780 4: 780 5: 780 6: 780 7: 780
8: 780 9: 780 10: 780 11: 780 12: 780 bogomips: 59904
conditional; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: NVIDIA GA107 [GeForce RTX 3050 6GB] driver: nvidia v: 570.144
alternate: nouveau,nvidia_drm non-free: 550-570.xx+ status: current (as of
2025-04; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16
ports: active: none off: DP-1 empty: DVI-D-1,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:2584 class-ID: 0300
Device-2: Sunplus Innovation Angetube Live Camera
driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 1-4:3 chip-ID: 1bcf:7550 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.70x13.46")
s-diag: 692mm (27.26")
Monitor-1: DP-1 mapped: DP-0 note: disabled model: Idek Iiyama PL2760Q
serial: <filter> built: 2021 res: N/A dpi: 109 gamma: 1.2
size: 527x296mm (20.75x11.65") diag: 685mm (27") ratio: 16:9 modes:
max: 2560x1440 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia platforms: device: 0
drv: nvidia device: 1 drv: nouveau device: 2 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 570.144
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3050/PCIe/SSE2
memory: 5.86 GiB
API: Vulkan v: 1.4.309 layers: 5 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3050 driver: nvidia v: 570.144 device-ID: 10de:2584
surfaces: xcb,xlib
Device-1: Intel Alder Lake-S HD Audio vendor: Biostar Microtech Intl Corp
driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:7ad0 class-ID: 0403
Device-2: NVIDIA GA107 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:2291 class-ID: 0403
Device-3: Sunplus Innovation Angetube Live Camera
Device-4: Texas Instruments PCM2704 16-bit stereo audio DAC
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-5:4 chip-ID: 08bb:2704 class-ID: 0300
API: ALSA v: k6.14.6-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8125 2.5GbE vendor: Biostar Microtech Intl Corp
driver: r8169 v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000
bus-ID: 04:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp4s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
IF-ID-2: wg0-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
Info: services: NetworkManager, ntpd, wpa_supplicant
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 5.01 TiB used: 2.27 TiB (45.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 57.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Mushkin model: MKNSSDVT2TB-D8
lanes: 4 tech: SSD serial: <filter> fw-rev: 3.H.J.22 temp: 65.8 C
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Crucial model: CT512MX100SSD1
size: 476.94 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: MU03 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD10TPVT-00U4RT1 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 5200 serial: <filter> fw-rev: 01.0 scheme: MBR
ID-1: / raw-size: 312.5 GiB size: 312.5 GiB (100.00%)
used: 143.59 GiB (45.9%) fs: btrfs dev: /dev/dm-0 maj-min: 253:0
mapped: luks-d916a464-4abf-46bd-b36a-e81a6381e0fc
ID-2: /boot/efi raw-size: 400 MiB size: 399.2 MiB (99.80%)
used: 728 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 195.31 GiB size: 191.19 GiB (97.89%)
used: 138.92 GiB (72.7%) fs: ext4 dev: /dev/dm-1 maj-min: 253:1
mapped: luks-c3e0e757-8f71-4642-bce0-fa52246af02a
ID-4: /var/log raw-size: 312.5 GiB size: 312.5 GiB (100.00%)
System Temperatures: cpu: 37.0 C mobo: N/A gpu: nvidia temp: 54 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Memory: total: 16 GiB available: 15.45 GiB used: 5.43 GiB (35.2%)
Processes: 476 Power: uptime: 21h 5m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.1 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: 1842 pm: dpkg pkgs: 0 pm: pacman pkgs: 1823 libs: 445
tools: pamac,yay pm: flatpak pkgs: 19 Compilers: clang: 19.1.7 gcc: 15.1.1
Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.38
