I have the same problem as defined here:
I’m using two monitors, I wonder if it is relevant.
journalctl -xe ✔
░░ Subject: Unit failed
░░ Defined-By: systemd
░░ The unit UNIT has entered the 'failed' state with result 'exit-code'.
Kas 29 11:37:13 eylem-ideapad kwin_wayland_wrapper[38766]: warning: queue "mesa egl surface queue" 0x560b549de720 destroyed while proxies still attached:
Kas 29 11:37:13 eylem-ideapad kwin_wayland_wrapper[38766]: wp_presentation#39 still attached
Kas 29 11:37:13 eylem-ideapad kscreenlocker_greet[38766]: qt.qpa.wayland: Could not create EGL surface (EGL error 0x3000)
Kas 29 11:37:13 eylem-ideapad kwin_wayland_wrapper[38766]: warning: queue "mesa egl surface queue" 0x7fcb4837bc90 destroyed while proxies still attached:
Kas 29 11:37:13 eylem-ideapad kscreenlocker_greet[38766]: Failed to write to the pipe: Bad file descriptor.
Kas 29 11:37:19 eylem-ideapad systemd[1]: dbus-:1.2-org.kde.powerdevil.backlighthelper@2.service: Deactivated successfully.
░░ Subject: Unit succeeded
░░ The unit dbus-:1.2-org.kde.powerdevil.backlighthelper@2.service has successfully entered the 'dead' state.
Kas 29 11:38:10 eylem-ideapad systemd[812]: Started Konsole - Terminal.
░░ Subject: A start job for unit UNIT has finished successfully
░░ A start job for unit UNIT has finished successfully.
░░ The job identifier is 544.
Kas 29 11:38:10 eylem-ideapad systemd[812]: Started app-org.kde.konsole-39406.scope.
░░ The job identifier is 563.
inxi -Fxza
Kernel: 6.17.1-0-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.17-x86_64
root=UUID=9b5af405-c72f-4456-a7f5-1f96aa139354 rw rootflags=subvol=@
udev.log_priority=3 sysrq_always_enabled=1
resume=UUID=9b5af405-c72f-4456-a7f5-1f96aa139354 resume_offset=6825216
Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.18.0
Type: Laptop System: LENOVO product: 82H9 v: IdeaPad 3 17ITL6
serial: <superuser required> Chassis: type: 10 v: IdeaPad 3 17ITL6
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
part-nu: LENOVO_MT_82H9_BU_idea_FM_IdeaPad 3 17ITL6
uuid: <superuser required> Firmware: UEFI vendor: LENOVO v: GGCN61WW
date: 11/28/2024
ID-1: BAT0 charge: 19.1 Wh (58.6%) condition: 32.5/38 Wh (85.5%) volts: 7.72
min: 7.7 model: Celxpert L20C2PF0 type: Li-poly serial: <filter> charging:
status: not charging type: long_life avail: long_life,standard cycles: 494
Device-1: hidpp_battery_0 model: Logitech Wireless Touch Keyboard K400
status: discharging
Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xBC
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
desc: 4x1.2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1112 min/max: 400/4700 scaling: driver: intel_pstate
governor: powersave cores: 1: 1112 2: 1112 3: 1112 4: 1112 5: 1112 6: 1112
7: 1112 8: 1112 bogomips: 44851
Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Type: indirect_target_selection mitigation: Aligned branch/return thunks
conditional; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Type: vmscape status: Not affected
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
built: 2020-21 ports: active: HDMI-A-1,eDP-1 empty: none bus-ID: 00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: NVIDIA GP107M [GeForce MX350] vendor: Lenovo driver: nvidia
v: 580.82.09 alternate: nouveau,nova_core,nvidia_drm non-free: 550-580.xx+
status: current (as of 2025-11; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1c94 class-ID: 0302
Device-3: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:4 chip-ID: 04f2:b6ee
compositor: kwin_wayland driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 d-rect: 3840x1080
display-ID: 0
Monitor-1: HDMI-A-1 pos: right model: Samsung LS24C36x serial: <filter>
built: 2023 res: mode: 1920x1080 hz: 75 scale: 100% (1) dpi: 82 gamma: 1.2
size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: eDP-1 pos: primary,left model: BOE Display 0x09c1 built: 2020
res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 128 gamma: 1.2
size: 382x215mm (15.04x8.46") diag: 438mm (17.3") ratio: 16:9
modes: 1920x1080
drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia wayland: drv: iris x11: drv: iris
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.2.3-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (TGL
GT2) device-ID: 8086:9a49 memory: 18.86 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.321 layers: 2 device: 0 type: discrete-gpu
name: NVIDIA GeForce MX350 driver: nvidia v: 580.82.09 device-ID: 10de:1c94
surfaces: N/A
wl: wayland-info x11: xdpyinfo,xprop
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl alternate: snd_soc_avs,
snd_sof_pci_intel_tgl, snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:a0c8
class-ID: 0401
API: ALSA v: k6.17.1-0-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:8
Local Storage: total: 2.27 TiB used: 978.39 GiB (42.0%)
model: WD Green SN3000 500GB size: 465.76 GiB block-size: physical: 512 B
fw-rev: 123000WD temp: 34.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.1
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter> scheme: GPT
ID-1: / raw-size: 219.73 GiB size: 219.73 GiB (100.00%)
used: 95.16 GiB (43.3%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 57.4 MiB (59.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 219.73 GiB size: 219.73 GiB (100.00%)
ID-4: /var/log raw-size: 219.73 GiB size: 219.73 GiB (100.00%)
ID-1: swap-1 type: file size: 11 GiB used: 0 KiB (0.0%) priority: -2
file: /@swap/swapfile
System Temperatures: cpu: 38.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 20 GiB note: est. available: 19.32 GiB used: 5.83 GiB (30.2%)
Processes: 331 Power: uptime: 1h 15m states: freeze,mem,disk
suspend: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 7.67 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: 1718 pm: dpkg pkgs: 1 pm: pacman pkgs: 1697 libs: 369
tools: pamac pm: flatpak pkgs: 20 Compilers: clang: 20.1.8 gcc: 15.2.1
Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.40
