Screen frames problem on external screen
Good evening kind charitable souls.
I’ve been using Linux, i tried Arch for less than a week and now I’m with Manjaro.
I’m new on Linux.
Before I continue in my profile are the specifications of my laptop, I think everyone can see them, I’m not sure.
The problem is that I use an external monitor, and when running for example a game with steam, vulkan etc, it goes to me at 30 fps, horrible, although stable, at maximum quality, 2k etc etc etc.
It turns out that today I had the goverlay on the laptop screen, and while I was going in the game at 30, the laptop was going to 144 stable, limited by the 144 hz of the main one I think.
It turns out that after lowering graphics and everything I thought of releasing the hdmi, and surprise, I was going to 144fps the game stable, continuous, upload the graphics and surprise again, 120-144 fps. It’s a fairly new game and demanding CPU game rather than GPU.
I’ve done a little research and it could be maybe a sync bug or framebuffer, it could be, I’m not sure.
At the moment I have tried to disable the laptop screen and see if it corrects by just having to charge for the external and nothing.
I use KDE Plasma with Wayland, with X11 last time game couldn’t even open, it could be compatibility issues, I don’t know.
I’d like to fix the bug and stay in the Linux community, but I can’t be required to have that refresh rate for games, and I wouldn’t want to have to support performance on windows.
Any wonderful soul who knows where can be or who has a guide/wiki/something to explain how to fix it?
Thank you in advance.
Simply stating that you have performed “a little research” isn’t overly helpful. What did you discover? Please provide links and any detail that may be relevant - nobody here has a :crystal_ball: :wink:
Yes, I can see them.
The profile specs are a quick overview, but if you wish to give detail that might actually be useful to those wishing to help, we encourage you to provide your system information as described (below).
Of course, this is only a starting point; often more information is needed, including (for example) logs and outputs of various commands. Information about how these outputs should be formatted is also linked (below).
What follows is from a standard template.
As a new or infrequent forum user, please take some time to familiarise yourself with forum requirements, and the many ways to use the forum to your benefit.
Note: By virtue of using the Manjaro forum you acknowledge and agree to follow Rules and Guidelines outlined; so, you really should read them:
Required Reading
Highly Recommended
Work with us, not against us
Be prepared to provide output from commands when asked. It is equally important to provide as much actionable information as possible in your first post, rather than simply indicating there is a problem.
Simply waiting for others to ask you questions can be counter-productive – typically, nobody has a :crystal_ball: at their disposal – instead, please help others to make informed suggestions based on information you provide.
System Information
a) inxi command (long-form):
inxi --filter --verbosity=8
b) inxi command (short-form):
inxi -zv8
Running inxi within a chroot environment :eyes:
Your privacy is respected
Update Announcements
Technical Resources
If you did not do so already - check the recommended driver
nvidia-recommended-driver
And
nvidia-driver-assistant
When you say it is a laptop - you will likely need the hybrid driver
For the vast majority of newer nvidia cards
sudo pacman -Syu
sudo mhwd -i pci video-hybrid-intel-nvidia-prime
External monitors in dual-gpu laptops can be a pain - something to do with how the vendor has wired the outputs.
Tuxedo Computers has a great article on prime gpu offloading - most of it is generally applicable. See the Validity paragraph in the following link PRIME GPU Render Offloading/GPU on-demand Mode Guide - TUXEDO Computers
When you have the intel-nvidia hybrid driver synced, the command primerun <application> will use the nvidia dGPU to render the application - e.g.
primerun steam
or
primerun steam steam://rungameid/<yourgameid>
I have the manjaro hardware detection and i have the hybrid newest drivers yes, i found by investigating that at 99% sure is not a drivers issue, there is a lot of people with bugs with KDE, gnome and a few more with external monitors, there is a bug or wrong configuration by the desktop environment related to frame rate, it seems to halve the frames of the external window, and within full screen apps it depends on how that app works it could halve it again.
As how it works outside the external monitor is not a drivers issue, and the nvidia is working properly when i start games, so it shouldn’t be
As an answer to moderator, could not send links without basic level, i just unlocked it now😅
I just saw this on arch [SOLVED] external display seems to display 1/2 refresh rate on wayland / Applications & Desktop Environments / Arch Linux Forums
This on reddit
https://www.reddit.com/r/kde/comments/11i8l25/nvidia_external_monitor_issues_lowfpsvsync_look/
Is the original solution the arch wiki talks about.
This was what i could try and check this morning at 7 am.
And this is ALL i found, and im going to read, but im busy and haven’t got full time so i won’t be able to read all and try this week, thats the reason i was asking, cause i found that is a “common” bug.
Links to possibly related issues discovered
  1. [SOLVED] external display seems to display 1/2 refresh rate on wayland / Applications & Desktop Environments / Arch Linux Forums Arch Linux forum thread where a user reports the “half refresh rate” bug (72Hz on a 144Hz monitor) in Wayland.[1] Solutions like KWIN_FORCE_SW_CURSOR=1 are tested without initial success.[1]
  2. Nvidia, please get it together with external monitors on Wayland - Linux - NVIDIA Developer Forums Extensive NVIDIA forums thread where multiple users report the “half refresh rate” bug on Wayland.[2] The kernel parameter nvidia.nvreg_enablegpufirmware=0 is identified as the main solution.[2]
  3. https://www.reddit.com/r/kde/comments/1bq0djf/fixing_refresh_rate_in_wayland_on_multigpu_laptop/ Reddit thread describing how a user fixed lag and low refresh rate on KDE 6 Wayland.[3] The solution was to use the KWIN_DRM_DEVICES environment variable to set the primary GPU.[3]
  4. https://bugs.kde.org/show_bug.cgi?id=452219 Official KDE bug report (452219) detailing high CPU usage (kwin_wayland) and low FPS on external monitors.[4] The root cause is identified as an inefficient memory copy (memcpy) between the iGPU and dGPU.[4]
  5. https://www.reddit.com/r/linux_gaming/comments/1f50kt5/nvidia_kde_plasma_wayland_multiple_monitors_60hz/ Reddit thread where a user with multiple monitors (165Hz, 144Hz, 60Hz) experiences lag on the 60Hz monitor. The kernel parameter nvidia.NVreg_EnableGpuFirmware=0 reportedly fixed the problem.[5]
  6. Gnome wayland external monitor refresh rate issue (nvidia) - Fedora Discussion Fedora forum discussion about the “half refresh rate” bug (60Hz on a 120Hz monitor). It confirms the issue occurs in both GNOME and KDE.[6]
  7. https://www.reddit.com/r/linux_gaming/comments/zi3xi8/144hz_60fps_gnome_wayland_microstutter/ Reddit thread explaining micro-stutter when recording at 60FPS on a 144Hz monitor. This is due to 144 not being a multiple of 60, a sync problem different from the “half-refresh” bug.[7]
  8. Nvidia, please get it together with external monitors on Wayland - Page 2 - Linux - NVIDIA Developer Forums Page 2 of the NVIDIA thread (see link 2). Both solutions are confirmed: the nvidia.NVreg_EnableGpuFirmware=0 kernel parameter and the KWIN_DRM_DEVICES environment variable.[8]
  9. Low fps on external monitor connected to nvidia hdmi port · Issue #650 · NVIDIA/open-gpu-kernel-modules · GitHub GitHub issue for NVIDIA’s open kernel modules. A user confirms the bug (37FPS on a 75Hz monitor) is a regression from the 555.42 driver, solved by nvidia.NVreg_EnableGpuFirmware=0.[9]
  10. [SOLVED] Kwin wayland FPS half of refresh rate on external monitor / Applications & Desktop Environments / Arch Linux Forums Another Arch Linux thread reporting the “half FPS” bug (72FPS on 144Hz, 50FPS on 100Hz).[10] It lists multiple failed environment variable fixes (KWIN_FORCE_SW_CURSOR=1, KWIN_DRM_USE_MODIFIERS=0, etc.).[10]
  11. Wayland external monitor refresh rate issue (nvidia gpu) - Desktop - GNOME Discourse GNOME forum discussion confirming the “half FPS” bug (70fps on 144hz) occurs in both GNOME and KDE. The NVIDIA proprietary driver is suspected as the cause.[11]
  12. Nvidia, please get it together with external monitors on Wayland - Page 3 - Linux - NVIDIA Developer Forums Page 3 of the NVIDIA thread (see link 2). A user provides a detailed bug report to NVIDIA, reproducing the bug (37-38 FPS on a 75Hz monitor) and confirming it as a 555.42 driver regression.[12]
  13. https://bugs.kde.org/show_bug.cgi?id=505371 A KDE bug report (marked as a duplicate). It describes KWin dropping every other frame due to a driver bug, suggesting a KWIN_DRM_OVERRIDE_SAFETY_MARGIN workaround.[13]
  14. https://www.reddit.com/r/kde/comments/1hadz0c/fluctuating_unstable_kwin_fps_wayland_on_nvidia/ Reddit thread showing a video of fluctuating and unstable KWin FPS on Wayland with NVIDIA. It discusses the need to report the bug correctly to KDE developers.[14]
  15. https://www.reddit.com/r/kde/comments/11krkg7/kde_wayland_commandline_tool_to_detect_hardware/ Technical Reddit discussion on dynamically configuring the KWIN_DRM_DEVICES variable. It confirms the variable is used to decide which GPU to use for rendering.[15]
  16. https://darkghosthunter.medium.com/bluefin-making-your-nvidia-dgpu-primary-for-external-monitors-0b5a293a4b9f Medium article technically explaining the lag: the iGPU renders, but the dGPU (connected to the port) must read the framebuffer from RAM, which is extremely slow.[16]
  17. Nvidia, please get it together with external monitors on Wayland - Page 4 - Linux - NVIDIA Developer Forums Page 4 of the NVIDIA thread (see link 2). A developer states the “half FPS” bug is fixed in the 580 driver, but a user refutes this.[17]
  18. https://forum.endeavouros.com/t/wayland-kde-6-optimus-nvidia/52991/16 EndeavourOS thread providing the exact syntax for KWIN_DRM_DEVICES. It recommends creating a script in /etc/profile.d/kde.sh to set the variable globally.[18]
  19. Making sure you're not a bot! GNOME (Mutter) GitLab issue discussing similar FPS drops even when the dGPU is the only active GPU, pointing to power management problems.[19]
  20. Maybe I am the one who should make sure i’m not talking with a Discord bot, maybe you should expend more time on read first what i said instead of editing the post calling someone a bot cause 1 link was miss written? i searched all this links but i did not READ any of them less the first one cause i have no time, i did not even open the links and said that, you asked what did i search, i gave links with the research i did, not with the links i already checked, if i did not say that it is okey, but i said I DID NOT.
  21. https://www.reddit.com/r/kde/comments/1nqutkd/kde_no_longer_respects_kwin_drm_devices_values/ Reddit thread where a user reports KWIN_DRM_DEVICES is no longer respected. Alternative GPU management methods like prime-select and bbswitch are discussed.[20]
  22. Wayland external monitor refresh rate issue - Linux - NVIDIA Developer Forums Another NVIDIA forums thread where a Fedora user reports 70 FPS on an external monitor.[21] The conversation confirms the problem occurs in both GNOME and KDE.[21]
  23. [ABANDONED] Force Wayland to use NVIDIA Graphics in Hybrid GPU Laptop / Laptop Issues / Arch Linux Forums Arch Linux thread where a user mentions Wayland is necessary because X11 is “unbearably slow” on >60Hz screens. This is an X11 issue, not the Wayland bug.[22]
  24. KDE Wayland monitor refresh rate is capped at ~60Hz Manjaro-specific forum thread where a user on KDE 5.27 (Wayland) reports their 144Hz external monitor is capped at 60Hz.[23]
  25. GBM_BACKEND=nvidia-drm on wayland with discrete GPU on laptop failure - Help - KDE Discuss KDE forum discussion where a user tries (and fails) to use the dGPU as primary. The correct solution provided is to use KWIN_DRM_DEVICES in /etc/environment.[24]
  26. Arch Linux thread (page 2) suggesting the syntax export KWIN_DRM_DEVICES=/dev/dri/card1:/dev/dri/card0 to force KWin to run on the NVIDIA GPU.[25]
  27. Serious performance issues with Wayland Nvidia Reddit thread describing performance issues on Wayland/NVIDIA. The user wants the iGPU to render to save VRAM, which is the cause of the framebuffer copy bug.[26]
And this is an image of the problem, first image is laptop screen (ignore gpu, nothing hard running, i did it this morning, when gpu at 1900 MHz is the same) and second screen is the same moment, but using goverlay on the external screen, it has a lot of noise, it is not stable and it drops over 70% framerate.
That frametime is the same the other user are reporting, that noise on the graphic line, by now i just tried source [1] solution, it did not work. Also tried to deactivate on settings the laptop monitor and also didn’t work
Mod edit: Malformed URLs corrected. No charge.
Please avoid posting images of textual information. Images removed.
In future, please recreate the textual information that you wish to convey, in text. Added Disclosure element to contain links, for the sake of brevity.
Summary
This text will be hidden
The joy of using Nvidia(-based) products with Linux - at least you know it is a general issue.. and there is nothing we can say or do that will make it any easier.
Yes, i know, but there is people that fixed it, just need to find the way my laptop needs, to much things to check, environment, distro, hardware, i just will try the 26 web solving ideas, but need time, i just posted so if someone truly know the bug exactly or experienced it
We are still waiting for your system information as previously requested. Providing this will enable others to identify possible contributing factors.
inxi -zv8
Paste the command output according to forum guidelines previously linked (above) between two rows of three backticks; like so:
Your inxi output here.
  Kernel: 6.12.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=57e54d1e-ce40-4965-b21f-61d3397eca6a rw rootflags=subvol=@
    quiet splash resume=UUID=522bc75c-0ae5-4cad-a9bd-0befbd6d8104
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.18.0
  Type: Laptop System: Micro-Star product: Please change product name
    v: REV:1.0 serial: <superuser required> Chassis: type: 10
  Mobo: Micro-Star model: MS-16P7 v: REV:1.0 serial: <superuser required>
    part-nu: 16P7.1 uuid: <superuser required> UEFI: American Megatrends
    v: E16P7IMS.113 date: 05/18/2020
  ID-1: BAT1 charge: 36.3 Wh (100%) condition: 36.3/53.2 Wh (68.2%)
    volts: 11.96 min: 10.86 model: MSI BIF0_9 type: Li-ion serial: N/A charging:
    status: full cycles: N/A
  System RAM: total: 32 GiB available: 31.19 GiB used: 9.64 GiB (30.9%)
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 16 GiB
    speed: 2667 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
    data: 64 total: 64 manufacturer: Samsung part-no: M471A2K43CB1-CTD
    serial: <filter>
  Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 16 GiB
    serial: <filter>
  Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xFA
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
    smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
    desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 4098 min/max: 800/4500 scaling: driver: intel_pstate
    governor: powersave cores: 1: 4098 2: 4098 3: 4098 4: 4098 5: 4098 6: 4098
    7: 4098 8: 4098 9: 4098 10: 4098 11: 4098 12: 4098 bogomips: 62431
    smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    vulnerable
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
    ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
    class-ID: 0300
  Device-2: NVIDIA TU106M [GeForce RTX 2070 Mobile] vendor: Micro-Star MSI
    driver: nvidia v: 580.82.09 alternate: nouveau,nvidia_drm
    non-free: 550-580.xx+ status: current (as of 2025-08; EOL~2026-12-xx)
    arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
    gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
    active: HDMI-A-1 empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:1f10
    class-ID: 0300
    compositor: kwin_wayland driver: X: loaded: modesetting,nvidia
    gpu: i915,nv_platform,nvidia,nvidia-nvswitch d-rect: 4480x2520
    display-ID: 0
  Monitor-1: HDMI-A-1 pos: top-right model: Samsung LC27G5xT
    serial: <filter> built: 2023 res: mode: 2560x1440 hz: 144 scale: 100% (1)
    dpi: 109 gamma: 1.2 chroma: red: x: 0.682 y: 0.310 green: x: 0.275
    y: 0.651 blue: x: 0.149 y: 0.067 white: x: 0.314 y: 0.329
    size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
    modes: 2560x1440, 3840x2160, 1920x1080, 1680x1050, 1600x900, 1280x1024,
    1440x900, 1280x800, 1152x864, 1280x720, 1024x768, 800x600, 720x576,
    720x480, 640x480
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 93 2: parse_edid:
    unhandled CEA mode 96 3: parse_edid: unhandled CEA mode 97
  Monitor-2: eDP-1 pos: bottom-l model: Sharp LQ173M1JW05 built: 2019 res:
    mode: 1920x1080 hz: 240 scale: 100% (1) dpi: 128 gamma: 1.2 chroma: red:
    x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059 white:
    x: 0.314 y: 0.329 size: 382x215mm (15.04x8.46") diag: 438mm (17.3")
    ratio: 16:9 modes: 1920x1080
    drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia wayland: drv: iris x11: drv: iris
    inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.82.09
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2070/PCIe/SSE2
    memory: 7.81 GiB display-ID: :1.0
  API: Vulkan v: 1.4.321 layers: 7 device: 0 type: discrete-gpu
    name: NVIDIA GeForce RTX 2070 driver: nvidia v: 580.82.09
    device-ID: 10de:1f10 surfaces: N/A
  Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl
    bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
  Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
    bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
  API: ALSA v: k6.12.48-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
  Device-1: Intel Cannon Lake PCH CNVi WiFi vendor: Rivet Networks Killer
    Wireless-AC 1550i Wireless driver: iwlwifi v: kernel bus-ID: 00:14.3
    chip-ID: 8086:a370 class-ID: 0280
  Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet
    vendor: Micro-Star MSI driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 3000 bus-ID: 05:00.0 chip-ID: 1969:e0b1 class-ID: 0200
  IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: CloudflareWARP state: unknown speed: 10000 Mbps duplex: full
    mac: N/A
  IP v4: <filter> scope: global
  IP v6: <filter> scope: global
  IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
  IF-ID-2: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
  IP v6: <filter> virtual: proto kernel_ll scope: link
  IF-ID-3: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:8
  Local Storage: total: 4.57 TiB used: 469.65 GiB (10.0%)
    model: MZVLB1T0HALR-00000 size: 953.87 GiB block-size: physical: 512 B
    fw-rev: EXA7301Q temp: 27.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: KIOXIA
    model: EXCERIA PLUS G3 SSD size: 1.82 TiB block-size: physical: 512 B
    fw-rev: ELFA01.2 temp: 25.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04UBD200
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.0
    spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5400
    serial: <filter> scheme: GPT
  ID-1: / raw-size: 1.81 TiB size: 1.81 TiB (100.00%) used: 40.27 GiB (2.2%)
    fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:7 label: N/A
    uuid: 57e54d1e-ce40-4965-b21f-61d3397eca6a
    used: 632 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:6 label: N/A
    uuid: CE4A-DDDA
  ID-3: /home raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
    used: 40.27 GiB (2.2%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:7
    label: N/A uuid: 57e54d1e-ce40-4965-b21f-61d3397eca6a
  ID-4: /run/media/ekaitz/Datos raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
    used: 429.38 GiB (23.0%) fs: btrfs dev: /dev/sda1 maj-min: 8:1 label: Datos
    uuid: e0fe4695-ae2e-419a-bbcd-c62156f2f0f6
  ID-5: /var/cache raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
  ID-6: /var/log raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
  ID-1: swap-1 type: partition size: 8.8 GiB used: 512 KiB (0.0%)
    priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:8 label: swap
    uuid: 522bc75c-0ae5-4cad-a9bd-0befbd6d8104
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
    uuid: 18D5-8D08
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 953.02 GiB fs: ntfs label: N/A
    uuid: 00FAD776FAD76686
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 748 MiB fs: ntfs label: N/A
    uuid: DE7233FF7233DACB
  Device-1: 1-1:2 info: Logitech USB Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046d:c53f class-ID: 0300
  Hub-2: 1-4:3 info: Genesys Logic Hub ports: 4 rev: 2.1
  Device-1: 1-4.1:5 info: Zikway HID zk type: HID driver: hid-generic,usbhid
    interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 400mA chip-ID: 3537:2106 class-ID: 0300
  Hub-3: 1-4.2:7 info: Terminus Hub ports: 4 rev: 2.0
    chip-ID: 1a40:0101 class-ID: 0900
  Device-1: 1-4.3:9 info: Razer USA RZ03-0338 Gaming Keyboard [Ornata V2]
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 4 rev: 2.0
    chip-ID: 1532:025d class-ID: 0300
  Device-2: 1-4.4:10 info: Logitech G502 SE HERO Gaming Mouse
    type: mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
    chip-ID: 046d:c08b class-ID: 0300 serial: <filter>
  Device-3: 1-7:4 info: Realtek RTS5129 Card Reader Controller
    power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
  Device-4: 1-9:6 info: SteelSeries ApS KLC type: HID
    lanes: 1 mode: 1.1 power: 300mA chip-ID: 1038:1122 class-ID: 0300
  Device-5: 1-14:8 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
  Hub-4: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
  Device-1: 2-2:3 info: Toshiba America Canvio Advance 2TB model DTC920
    type: mass storage driver: usb-storage interfaces: 1 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 896mA
    chip-ID: 0480:0821 class-ID: 0806 serial: <filter>
  Hub-5: 2-4:2 info: Genesys Logic Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
  System Temperatures: cpu: 47.0 C pch: 35.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1696 libs: 375 tools: pamac,paru,yay pm: flatpak
    pkgs: 0
    1: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    3: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 380
  1: cpu: 33.4% command: plasmashell pid: 1259 mem: 662.0 MiB (2.0%)
  2: cpu: 18.6% command: kwin_wayland pid: 1061 mem: 425.7 MiB (1.3%)
  3: cpu: 14.7% command: intellij-idea-ultimate-edition pid: 52043
    mem: 2197.2 MiB (6.8%)
  4: cpu: 9.2% command: firefox pid: 2025 mem: 887.8 MiB (2.7%)
  5: cpu: 6.6% command: firefox pid: 59460 mem: 401.7 MiB (1.2%)
  Memory top: 5 of 380
  1: mem: 2197.2 MiB (6.8%) command: intellij-idea-ultimate-edition
    pid: 52043 cpu: 14.7%
  2: mem: 887.8 MiB (2.7%) command: firefox pid: 2025 cpu: 9.2%
  3: mem: 743.9 MiB (2.3%) command: FP started-by: calligrasheets pid: 25247
    cpu: 0.0%
  4: mem: 694.0 MiB (2.1%) command: firefox pid: 19212 cpu: 0.4%
  5: mem: 662.0 MiB (2.0%) command: plasmashell pid: 1259 cpu: 33.4%
  Processes: 380 Power: uptime: 5h 40m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.44 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: yakuake
    inxi: 3.3.39
