Context
This issue started with a full system upgrade (sudo pacman -Syu) around 2 months ago.
I’m on a laptop running Manjaro with KDE 5.27.8 (Wayland) on kernel 6.6 (complete system info below).
Problem
My external monitor, which is can go at 144Hz, seems to be capped at 60Hz by something.
The built-in laptop monitor, a 144Hz panel as well, is working just fine.
Looking at KDE’s display settings, both screens are set to 144Hz. However, I cannot change the built-in one to 60Hz, it always works at 144Hz, for some reason (the setting seems to stick, but if I reopen the page, it reverts back to 144Hz). Changing the external monitor’s refresh rate “works” (as in, the setting sticks), though it changes nothing.
I’ve tried using kscreen-doctor to change settings, to no avail either.
Here’s what kscreen-doctor -io gives me:
Output
Environment:
* KSCREEN_BACKEND : [not set]
* KSCREEN_BACKEND_INPROCESS : [not set]
* KSCREEN_LOGGING : [not set]
Logging to : [logging disabled]
Preferred KScreen backend : KSC_KWayland.so
Available KScreen backends:
* KSC_Fake.so: /usr/lib/qt/plugins/kf5/kscreen/KSC_Fake.so
* KSC_KWayland.so: /usr/lib/qt/plugins/kf5/kscreen/KSC_KWayland.so
* KSC_QScreen.so: /usr/lib/qt/plugins/kf5/kscreen/KSC_QScreen.so
* KSC_XRandR.so: /usr/lib/qt/plugins/kf5/kscreen/KSC_XRandR.so
* KSC_XRandR11.so: /usr/lib/qt/plugins/kf5/kscreen/KSC_XRandR11.so
Output: 1 eDP-1 enabled connected priority 1 Panel Modes: 0:1920x1080@144*! 1:1280x1024@60 2:1024x768@60 3:1280x800@60 4:1920x1080@60 5:1600x900@60 6:1368x768@60 7:1280x720@60 Geometry: 0,1080 1920x1080 Scale: 1 Rotation: 1 Overscan: 0 Vrr: incapable RgbRange: Automatic
Output: 2 HDMI-A-1 enabled connected priority 2 HDMI Modes: 0:1920x1080@60! 1:1920x1080@144* 2:1920x1080@120 3:1920x1080@120 4:1920x1080@100 5:1920x1080@60 6:1920x1080@50 7:1680x1050@60 8:1600x900@60 9:1280x1024@60 10:1440x900@60 11:1280x800@60 12:1280x720@60 13:1280x720@60 14:1280x720@50 15:1024x768@60 16:800x600@60 17:720x576@50 18:720x480@60 19:640x480@60 20:640x480@60 Geometry: 0,0 1920x1080 Scale: 1 Rotation: 1 Overscan: 0 Vrr: incapable RgbRange: unknown
Has anyone had anything similar? Could it be some regression to the Intel graphics driver (the HDMI port is driven by the iGPU, not dGPU)? Is it a KDE bug?
Thank you!
System info
Kernel: 6.6.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
parameters: BOOT_IMAGE=/root/boot/vmlinuz-6.6-x86_64
root=UUID=767943ce-1fd1-40ac-8290-109ef2e820fd rw rootflags=subvol=root
apparmor=1 security=apparmor quiet loglevel=3 udev.log_priority=3
bootsplash.bootfile=/bootsplash-themes/kde/bootsplash
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 2
Type: Laptop System: SchenkerGmbH product: XMG FUSION 15 (XFU15L19)
v: Late 2019 serial: <superuser required> Chassis: type: 10 v: 1.0
Mobo: Intel model: LAPQC71A v: K54899-304 serial: <superuser required>
UEFI: Intel v: QCCFL357.0150.2022.0523.1145 date: 05/23/2022
ID-1: BAT0 charge: 74.8 Wh (80.0%) condition: 93.5/93.5 Wh (100.0%)
volts: 12.1 min: 11.4 model: standard type: Li-ion serial: <filter>
status: not charging
System RAM: total: 16 GiB available: 15.47 GiB used: 4.84 GiB (31.3%)
Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF4
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/4500 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62431
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Intel
driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s ports: active: none off: HDMI-A-1
empty: DP-1,DP-2 bus-ID: 01:00.0 chip-ID: 10de:2191 class-ID: 0300
Device-3: Chicony HD Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-13:5 chip-ID: 04f2:b68b
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.2.1
compositor: kwin_wayland driver: X: loaded: modesetting,nvidia dri: iris
gpu: i915,nvidia,nvidia-nvswitch display-ID: 0
Monitor-1: HDMI-A-1 model: HP ... serial: <filter> built: 2022
res: 1920x1080 dpi: 93 gamma: 1.2 size: ...
diag: ... ratio: 16:9 modes: max: 1920x1080 min: 640x480
Monitor-2: eDP-1 model: BOE Display 0x084d built: 2018 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
device: 2 drv: swrast surfaceless: drv: iris wayland: drv: iris x11:
drv: iris inactive: gbm,device-1
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL GT2)
device-ID: 8086:3e9b memory: 15.11 GiB unified: yes display-ID: :0.0
API: Vulkan v: 1.3.264 layers: 18 device: 0 type: integrated-gpu name: Intel
UHD Graphics 630 (CFL GT2) driver: mesa intel v: 23.1.9-manjaro1.1
device-ID: 8086:3e9b surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce GTX 1660 Ti driver: nvidia
v: 535.113.01 device-ID: 10de:2191 surfaces: xcb,xlib,wayland
Device-1: Intel Cannon Lake PCH cAVS driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
Device-2: NVIDIA TU116 High Definition Audio vendor: Tongfang Hongkong
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:1aeb
class-ID: 0403
Device-3: Texas Instruments PCM2902 Audio Codec
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-12:4 chip-ID: 08bb:2902 class-ID: 0300
API: ALSA v: k6.6.0-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 0.3.81 status: active with: 1: pipewire-pulse
vendor: Intel driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 3d:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp61s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 3e:00.0 chip-ID: 8086:2723 class-ID: 0280
IF-ID-1: docker0 state: down mac: <filter>
IF-ID-2: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
IP v4: <filter> scope: global
IP v6: <filter> scope: global
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:6 chip-ID: 8087:0029
class-ID: e001
Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
lmp-v: 11 sub-v: 20ce hci-v: 11 rev: 20ce class-ID: 7c010c
Info: acl-mtu: 1021:4 sco-mtu: 96:6 link-policy: rswitch sniff
link-mode: peripheral accept service-classes: rendering, capturing, object
transfer, audio, telephony
Local Storage: total: 1.36 TiB used: 625.24 GiB (44.7%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Smart Modular Tech.
model: ... size: 931.51 GiB block-size: physical: 512 B
fw-rev: ... temp: 48.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Crucial model: ...
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: P3CR021 temp: 41.9 C
scheme: GPT
ID-1: / raw-size: 900 GiB size: 900 GiB (100.00%) used: 625.24 GiB (69.5%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:7 label: N/A
uuid: 767943ce-1fd1-40ac-8290-109ef2e820fd
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6 label: BOOT
uuid: 849A-1063
ID-3: /home raw-size: 900 GiB size: 900 GiB (100.00%)
used: 625.24 GiB (69.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:7
label: N/A uuid: 767943ce-1fd1-40ac-8290-109ef2e820fd
ID-1: /dev/nvme1n1p1 maj-min: 259:1 size: 512 MiB fs: vfat label: N/A
uuid: 8BCC-FA41
ID-2: /dev/nvme1n1p2 maj-min: 259:2 size: 70 GiB fs: ext4 label: root
uuid: b8e4ec89-794c-4ce3-b10a-0102bf25e5b4
ID-3: /dev/nvme1n1p3 maj-min: 259:3 size: 350 GiB fs: ext4 label: home
uuid: c2c4dab5-0a58-42d4-b279-2791c65f4a17
ID-4: /dev/nvme1n1p4 maj-min: 259:4 size: 8 GiB fs: swap label: SWAP
uuid: 89ff7953-8699-42ab-bf57-98a619111bac
Device-1: 1-6:2 info: Integrated Express ITE Device(8291)
type: keyboard,HID driver: N/A interfaces: 2 rev: 2.0
chip-ID: 048d:ce00 class-ID: 0300
Device-3: 1-12:4 info: Texas Instruments PCM2902 Audio Codec
type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
Device-4: 1-13:5 info: Chicony HD Webcam type: video driver: uvcvideo
interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 04f2:b68b class-ID: 0e02 serial: <filter>
Device-5: 1-14:6 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0029 class-ID: e001
Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
Device-1: 2-2:2 info: Realtek Card Reader type: mass storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 800mA chip-ID: 0bda:0316 class-ID: 0806
serial: <filter>
Hub-3: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
System Temperatures: cpu: 53.0 C pch: 67.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 324 Uptime: 8m wakeups: 7 Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 alt: 12 clang: 16.0.6 Packages: 4362
pm: pacman pkgs: 4351 libs: 618 tools: octopi,pamac,paru,yay pm: flatpak
pkgs: 11 Shell: fish v: 3.6.1 running-in: kitty inxi: 3.3.30
