I’m not sure if it’s the right section to post, but still.
I have an issue with the screen since kernel 5.6.x.
Sometimes it blinks, it looks like a rapid switching off and on every 2-4 seconds.
When it happens, I just do something that could turn the screen off (screen locking, switching refresh rate, etc.) But it could take up to 3 iterations, moreover, it’s obviously just a weird workaround.
Also, on 5.8 kernel it could not restore previous backlight brightness state. It is still saved in GNOME, but without touching brightness setting it stays on some default value from UEFI or something in the way. It doesn’t happen on 5.7, though.
And, of course, my inxi -Fxxxz:
System: Kernel: 5.8.2-1-MANJARO x86_64 bits: 64 compiler: N/A Desktop: GNOME 3.36.5 tk: GTK 3.24.22 wm: gnome-shell
dm: GDM 3.36.3 Distro: Manjaro Linux
Machine: Type: Laptop System: ASUSTeK product: TUF Gaming FA506IV_FX506IV v: 1.0 serial: <filter>
Mobo: ASUSTeK model: FA506IV v: 1.0 serial: <filter> UEFI: American Megatrends v: FA506IV.309 date: 07/02/2020
Battery: ID-1: BAT1 charge: 88.5 Wh condition: 88.5/90.2 Wh (98%) volts: 5.4/15.9 model: ASUS A32-K55 type: Li-ion
serial: N/A status: Full
CPU: Topology: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP arch: Zen rev: 1
L2 cache: 4096 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 92670
Speed: 1431 MHz min/max: 1400/2900 MHz boost: enabled Core speeds (MHz): 1: 2230 2: 1959 3: 1397 4: 1397 5: 1467
6: 1397 7: 1427 8: 1395 9: 1604 10: 1607 11: 1710 12: 1658 13: 1595 14: 1734 15: 1398 16: 1397
Graphics: Device-1: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: ASUSTeK driver: nvidia v: 450.66 bus ID: 01:00.0
chip ID: 10de:1f15
Device-2: Advanced Micro Devices [AMD/ATI] Renoir vendor: ASUSTeK driver: amdgpu v: kernel bus ID: 05:00.0
chip ID: 1002:1636
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo bus ID: 3-4:2 chip ID: 13d3:56a2
serial: <filter>
Display: x11 server: X.Org 1.20.8 compositor: gnome-shell driver: ati,modesetting,nvidia unloaded: nouveau
alternate: amdgpu,fbdev,nv,vesa resolution: 1920x1080~144Hz s-dpi: 96
OpenGL: renderer: AMD RENOIR (DRM 3.38.0 5.8.2-1-MANJARO LLVM 10.0.1) v: 4.6 Mesa 20.1.6 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 05:00.1
chip ID: 1002:1637
Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor driver: snd_rn_pci_acp3x
v: kernel bus ID: 05:00.5 chip ID: 1022:15e2
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 05:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.8.2-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: e000
bus ID: 02:00.0 chip ID: 10ec:8168
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter vendor: AzureWave driver: rtw_8822ce v: N/A
port: d000 bus ID: 03:00.0 chip ID: 10ec:c822
Drives: Local Storage: total: 1.38 TiB used: 392.04 GiB (27.8%)
ID-1: /dev/nvme0n1 vendor: Kingston model: OM8PCP3512F-AB size: 476.94 GiB speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: ECFK52.3 scheme: GPT
ID-2: /dev/sda type: USB vendor: Toshiba model: MQ04UBF100 size: 931.51 GiB rotation: 5400 rpm serial: <filter>
scheme: MBR
Partition: ID-1: / size: 290.98 GiB used: 133.97 GiB (46.0%) fs: ext4 dev: /dev/nvme0n1p3
Swap: ID-1: swap-1 type: partition size: 20.00 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p2
Sensors: System Temperatures: cpu: 64.1 C mobo: N/A gpu: amdgpu temp: 56 C
Info: Processes: 405 Uptime: 4h 24m Memory: 15.13 GiB used: 6.43 GiB (42.5%) Init: systemd v: 246 Compilers: gcc: 10.1.0
clang: 10.0.1 Packages: 1487 pacman: 1482 snap: 5 Shell: Zsh v: 5.8 running in: gnome-terminal inxi: 3.1.05
I’d be glad for any tips.
