After upgrade to Kernel 5.10.49-1 LTS, the screen (login and desktop) begin scintilating and the problem was only solved after the downgrade to the predecessor Kernel 5.4.131-1 LTS.
My computer is a celeron n4000, with only a shared gpu, that always worked well.
Even if the problem doesn’t have a solution, I would like to contribute with the bug information for possible and desirable correction. If someone knows and recommends a more appropriate communication channel, I accept suggestions.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
