korben
29 October 2026 11:37
1
Just installed the new STABLE update and now I need reassurance my system does boot next time I reboot my machine.
sudo diff -u /etc/default/grub /etc/default/grub.pacnew
sudo diff -u /etc/mkinitcpio.conf /etc/mkinitcpio.conf.pacnew
included here:
should I add these?
sudo diff -u /etc/pam.d/sddm /etc/pam.d/sddm.pacnew
sudo diff -u /etc/pam.d/kde /etc/pam.d/kde.pacnew
before starting the HOOK migration?
suggested method to follow - is it proper one?
# 1. Backup your old config
sudo cp /etc/mkinitcpio.conf /etc/mkinitcpio.conf.backup
# 2. Merge the new config (carefully!)
# The safest way is to replace HOOKS line manually, but let's do it safely:
sudo sed -i 's/^HOOKS=.*/HOOKS=(base systemd autodetect microcode modconf kms keyboard sd-vconsole block filesystems fsck)/' /etc/mkinitcpio.conf
# 3. Verify the change
grep "^HOOKS" /etc/mkinitcpio.conf
# 4. REBUILD ALL INITRAMFS IMAGES WITH THE NEW CONFIG
sudo mkinitcpio -P
Teo
29 October 2026 13:20
2
Instead of blindly following oneliners some ai spitted out, if you really want to understand the config, just open it with a text editor.
I am not a sed expert so no idea if the automatic replacement will work, but the array with hooks looks ok.
You also have remnants of kernel 5.19 which you can delete and the preset.
Passwd should not be touched, tpm.pacnew can be replaced with the new version. The grub pacnew is only important if you have too many boot entries.
No idea for ssdm and kde stuff - if you want advice better post the new and old one so man can compare.
The proper way by the way to work with pacnews is pacdiff -s.
korben
29 October 2026 13:35
3
I do not wish to follow AI. I need users’ input, but second opinion is always valuable.
here goes:
[~]$ sudo diff -u /etc/pam.d/sddm /etc/pam.d/sddm.pacnew
diff: /etc/pam.d/sddm: No such file or directory
$ sudo diff -u /etc/pam.d/kde /etc/pam.d/kde.pacnew
diff: /etc/pam.d/kde: No such file or directory
Teo
29 October 2026 13:48
4
Soooo …the files just do not exist?!
I am no kde user, somebody with kde should look at it and say if those have to be there and if there is pacnew.
i think its quiet a while since your last update.
i just looked up the files. I do have a /etc/pam.d/sddm which is from 2024 which seems outdated cause of pam_kwallet5.so ?
/etc/pam.d/sddm
#%PAM-1.0
auth include system-login
auth optional pam_kwallet5.so
account include system-login
password include system-login
session include system-login
session optional pam_kwallet5.so auto_start
but no /etc/pam.d/kde (only the standard on in /usr/lib/pam.d which looks like
#%PAM-1.0
auth include system-local-login
account include system-local-login
password include system-local-login
session include system-local-login
hope it helps…
I would recommend using meld for comparison … it makes it much easier to understand the changes.
Update:
just browsed your pastebin…
Got the grub.conf.pacnew myself. The only thing i changed was adding the rd. infront of udev.log_priority=3. So your line will look:
GRUB_CMDLINE_LINUX_DEFAULT="quiet rd.udev.log_priority=3 i915.i915_enable_rc6=1 i915.i915_enable_fbc=1"
i also addes the new variables at the end but commented it out.
# See also Arch-Wiki: https://wiki.archlinux.org/title/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
# Disable generating menu entries for other EFI boot manager entries detected
#GRUB_DISABLE_BOOTNEXT=true
# Skip EFI boot manager entries that are marked inactive
# when when generating bootnext entries
#GRUB_BOOTNEXT_OMIT_INACTIVE=true
Edit the HOOKs in your /etc/mkinitcpio.conf to
HOOKS=(base systemd autodetect microcode modconf kms block keyboard sd-vconsole filesystems fsck)
so its ok to run the 4 commands in your post.
with that it should be save to reboot.
but dont forget to check also the rest of the pacnews.
korben
30 October 2026 08:25
6
It is tad complicated for my brain.
first this:
GRUB_CMDLINE_LINUX_DEFAULT=“quiet rd.udev.log_priority=3 i915.i915_enable_rc6=1 i915.i915_enable_fbc=1”
then the 4 commands suggested above?
in this particular order? exactly in this order?
sudo mkinitcpio -P
Teo
30 October 2026 17:29
7
If you mean 1-4: One usually backs up something before doing the change, not after So yes, backup if you want, change, verify if you want, regenerate config, obligatory.
The hooks are fine. Their order is extremely important. I would still do it manually in a text editor like micro, just to see how the file looks like.
This is the main reason i wrote maxi (without AI, so it may contain human errors)
Summary
> maxi
maxi v0.7.28 (2026-07-26 17:15)
Currently running: 7.2.9-1-MANJARO (linux72)
linux612 vmlinuz-6.12-x86_64 initramfs-6.12-x86_64.img=227M fallback=429M
linux618 vmlinuz-6.18-x86_64 initramfs-6.18-x86_64.img=323M fallback=525M
linux72 vmlinuz-7.2-x86_64 initramfs-7.2-x86_64.img =331M fallback=543M
Info about: /lib/modules
modules612 6.12.112-1-MANJARO=170M <none>=
modules618 6.18.55-1-MANJARO =176M <none>=
modules72 7.2.9-1-MANJARO =180M <none>=
> maxi -g
Info about: /etc/default/grub
Please update grub.cfg:/boot/grub/grub.cfg <is older than> /etc/default/grub
GRUB_DEFAULT =saved
GRUB_TIMEOUT =5
GRUB_DISTRIBUTOR ="Manjaro"
# GRUB_CMDLINE_LINUX_DEFAULT="quiet loglevel=3 rd.udev.log_level=3"
GRUB_CMDLINE_LINUX_DEFAULT="apparmor=1 security=apparmor loglevel=3 rd.udev.log_level=3"
GRUB_CMDLINE_LINUX =""
GRUB_PRELOAD_MODULES ="part_gpt part_msdos"
# GRUB_TIMEOUT_STYLE =hidden
GRUB_TIMEOUT_STYLE =menu
GRUB_THEME ="/usr/share/grub/themes/manjaro/theme.txt"
GRUB_SAVEDEFAULT =false
GRUB_DISABLE_OS_PROBER =false
korben
31 October 2026 08:54
9
[~]$ sha256sum /usr/local/bin/maxi
b15a083beafe952e462f3b48b780f8b3818387ef0eceb387e4821a5a077bae1f /usr/local/bin/maxi
[rafal@estudio ~]$ sudo chmod -c a+x /usr/local/bin/maxi
mode of '/usr/local/bin/maxi' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
[rafal@estudio ~]$ maxi -kmf
Currently running: 6.18.49-1-MANJARO (linux618)
linux612 vmlinuz-6.12-x86_64 initramfs-6.12-x86_64.img=22M fallback=<none>
linux618 vmlinuz-6.18-x86_64 initramfs-6.18-x86_64.img=22M fallback=<none>
modules612 6.12.112-1-MANJARO=346M <none>=
modules618 6.18.55-1-MANJARO =365M <none>=
Press ENTER to proceed.
[~]$ maxi -kmsgeif
linux612 vmlinuz-6.12-x86_64∑502d~4292 initramfs-6.12-x86_64.img=22M fallback=<none>∑<sha?>
linux618 vmlinuz-6.18-x86_64∑61c0~1af1 initramfs-6.18-x86_64.img=22M fallback=<none>∑<sha?>
Info about: /lib/modules Checksumming all modules may take a while
modules612 6.12.112-1-MANJARO=346M∑<sha?> <none>=∑<sha?>
modules618 6.18.55-1-MANJARO =365M∑<sha?> <none>=∑<sha?>
GRUB_DEFAULT =saved
GRUB_TIMEOUT =2
GRUB_CMDLINE_LINUX_DEFAULT="quiet udev.log_priority=3 i915.i915_enable_rc6=1 i915.i915_enable_fbc=1"
GRUB_SAVEDEFAULT =true
Info about: /etc/mkinitcpio.conf
MODULES =()
BINARIES =()
FILES =()
HOOKS =(base udev autodetect modconf kms block keyboard keymap consolefont filesystems fsck)
# COMPRESSION ="gzip"
# COMPRESSION ="bzip2"
# COMPRESSION ="lzma"
# COMPRESSION ="xz"
# COMPRESSION ="lzop"
# COMPRESSION ="lz4"
# COMPRESSION ="zstd"
# COMPRESSION_OPTIONS =()
# MODULES_DECOMPRESS ="yes"
Info about: efi bootloaders
7a57~b0e7 164K /boot/grub/x86_64-efi/grub.efi /include/grub
7a57~b0e7 164K /boot/grub/x86_64-efi/core.efi /include/grub
Info about: efi vars (needs efibootmgr)
Boot0000* Manjaro HD(5,GPT,ebcd389e-dcb1-8546-8108-3ccf44722d0b,0x1fef6800,0x96000)
Boot0001* Windows Boot Manager HD(1,GPT,2a2420df-fd06-4071-935a-7261bb91bf5f,0x800,0x32000)
now we have all the info we need, right? YES, i am still waiting for the approval of my steps… bear with me.
In my opinion the infos are fine.
To get the big picture you could post the output of inxi -zv8. (to satisfy [HowTo] Request support I’m really surprised that no one has complained yet)
Okay, I’ll summarize it briefly:
(optional and redundant when comment out the old HOOKs line and add the new line under the old) Backup your old config sudo cp /etc/mkinitcpio.conf /etc/mkinitcpio.conf.backup
Edit the HOOKS line in your /etc/mkinitcpio.conf by using one of the following options
Option a) execute this in your shell: sudo sed -i 's/^HOOKS=.*/HOOKS=(base systemd autodetect microcode modconf kms block keyboard sd-vconsole filesystems fsck)/' /etc/mkinitcpio.conf
OR
Option b) (usual the prevered way) open the file in editor with
sudo nano /etc/mkinitcpio.conf and add a # at the beginning of the existing HOOKS= line ( disables the line by marking it as a comment)
and add the new HOOKS line beneath the old one:
regenerate mikinitcpio by using
sudo mkinitcpio -P
edit the /etc/default/grub by using this:
open the file in editor: sudo nano /etc/default/grub
change the line GRUB_CMDLINE_LINUX_DEFAULT=... by addig a rd. in front of udev. so the result looks like this:
save the file with CTRL + o and confirm with ENTER
exit nano with CTRL + x
regenerate Grub using sudo grub-mkconfig -o /boot/grub/grub.cfg
after that it should be save to reboot.
Next, you should check the .pacnew files using the following command:
DIFFPROG=meld pacdiff -s
Assuming you have meld installed—which I highly recommend, since it allows you to view the changes and edit the files directly in the same window.
You can install meld with pacman -S meld.
How about reboot, check what happens and go from there. As it is now, it’s all mental gymnastics
for /etc/default/grub , the GRUB boot parameters must be changed and GRUB updated before system restart
Untitled (0p2u6wsy) - PasteCode.io
$ sudo diff -u /etc/default/grub /etc/default/grub.pacnew
— /etc/default/grub 2025-12-12 12:18:27.975690585 +0100
+++ /etc/default/grub.pacnew 2026-10-28 17:46:29.000000000 +0100
@@ -1,23 +1,21 @@
+# GRUB boot loader configuration
-GRUB_CMDLINE_LINUX_DEFAULT=“quiet udev.log_priority=3 i915.i915_enable_rc6=1 i915.i915_enable_fbc=1”
+GRUB_CMDLINE_LINUX_DEFAULT=“quiet loglevel=3 rd.udev.log_level=3 ”
I would also recommend using meld to compare files, but KDE users may prefer to use kcompare
There are 2 Kernels installed, and the initramdisk for them is present
You will see Grub menu for 2 Seconds, but you need to merge the .pacnew for grub first.
korben:
Your EFI Bootloaders (including fallback) are present, and you have EFI Vars pointing to your Bootloaders
That’s no guarantee that everything will go smoothly. But the “usual suspects”—the common causes for a system failing to boot—are all fine.
If this were my computer, I wouldn’t be worried about booting it up (after merging the .pacnews)
korben
4 November 2026 08:16
15
Kernel: 6.18.49-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
root=UUID=d540af20-98bf-4853-84e1-5bce691c998d rw quiet
Desktop: KDE Plasma v: 6.7.5 tk: Qt v: N/A info: frameworks v: 6.30.0
wm: kwin_x11 with: krunner vt: 2 dm: N/A Distro: Manjaro base: Arch Linux
Type: Laptop System: Acer product: Swift SF314-511 v: V1.10
serial: <superuser required>
Mobo: TGL model: Sake_TL v: V1.10 serial: <superuser required>
part-nu: 0000000000000000 uuid: <superuser required> Firmware: UEFI
vendor: Insyde v: 1.10 date: 09/16/2021
ID-1: BAT1 charge: 22.2 Wh (55.5%) condition: 40/56 Wh (71.5%) volts: 14.73
min: 15.4 model: SMP AP18C7M type: Li-ion serial: <filter> charging:
status: discharging cycles: 84
System RAM: total: 16 GiB available: 15.41 GiB used: 5.3 GiB (34.4%)
Array-1: capacity: 16 GiB slots: 8 modules: 8 EC: None
max-module-size: 2 GiB note: est.
Device-1: Controller0-ChannelA type: LPDDR4 detail: synchronous
size: 2 GiB speed: 4267 MT/s volts: curr: 0.6 width (bits): data: 16
total: 16 manufacturer: Micron Technology part-no: 53E1G32D2NP-046
serial: N/A
Device-2: Controller0-ChannelB type: LPDDR4 detail: synchronous
serial: N/A
Device-3: Controller0-ChannelC type: LPDDR4 detail: synchronous
serial: N/A
Device-4: Controller0-ChannelD type: LPDDR4 detail: synchronous
serial: N/A
Device-5: Controller1-ChannelA type: LPDDR4 detail: synchronous
serial: N/A
Device-6: Controller1-ChannelB type: LPDDR4 detail: synchronous
serial: N/A
Device-7: Controller1-ChannelC type: LPDDR4 detail: synchronous
serial: N/A
Device-8: Controller1-ChannelD type: LPDDR4 detail: synchronous
serial: N/A
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xBE
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
desc: 4x1.2 MiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1111 min/max: 400/2400 scaling: driver: intel_pstate
governor: powersave cores: 1: 1111 2: 1111 3: 1111 4: 1111 5: 1111 6: 1111
7: 1111 8: 1111 bogomips: 38707
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp
rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2
tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
Type: indirect_target_selection mitigation: Aligned branch/return thunks
conditional; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Type: vmscape status: Not affected
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics]
vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Xe
process: Intel 10nm built: 2020-21 ports: active: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 0000:00:02.0 chip-ID: 8086:9a49
class-ID: 0300
Device-2: Chicony HD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:4 chip-ID: 04f2:b6dd
Display: x11 server: X.Org v: 21.1.24 with: Xwayland v: 24.1.13
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: AU Optronics 0xda91 built: 2020 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 158 gamma: 1.2 chroma: red:
x: 0.651 y: 0.329 green: x: 0.290 y: 0.608 blue: x: 0.149 y: 0.055 white:
x: 0.314 y: 0.329 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1920x1080
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 vendor: intel mesa v: 26.2.4-arch1.1 glx-v: 1.4
direct-render: yes renderer: Mesa Intel Iris Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 15.05 GiB unified: yes
API: Vulkan v: 1.4.363 layers: 2 device: 0 type: integrated-gpu name: Intel
Iris Xe Graphics (TGL GT2) driver: mesa intel v: 26.2.4-arch1.1
device-ID: 8086:9a49 surfaces: N/A
x11: xdpyinfo, xprop, xrandr
Device-1: Intel 500 Series Family On-Package High Definition Audio
vendor: Acer Incorporated ALI driver: sof-audio-pci-intel-tgl
bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 class-ID: 0401
Device-2: AOKEO LCS_USB_Audio driver: snd-usb-audio type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:15 chip-ID: 2e3c:4444
class-ID: 0102 serial: <filter>
API: ALSA v: k6.18.49-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.6.9 status: off with: pipewire-media-session
status: off tools: pw-cat,pw-cli
Server-4: PulseAudio v: 17.0-98-gb096 status: active with: pulseaudio-alsa
type: plugin tools: pacat,pactl,pavucontrol
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
Device-2: ASIX AX88179 Gigabit Ethernet driver: cdc_ncm type: USB rev: 3.2
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-1:73 chip-ID: 0b95:1790
class-ID: 0a00 serial: <filter>
IF: enp0s13f0u1c2 state: up speed: 100 Mbps duplex: unknown mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:6 chip-ID: 8087:0026
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 96.21 GiB (20.2%)
model: MZVL2512HCJQ-00BT7 size: 476.94 GiB block-size: physical: 512 B
fw-rev: GXA7302Q temp: 25.9 C scheme: GPT
ID-1: / raw-size: 220.17 GiB size: 215.65 GiB (97.95%)
used: 96.21 GiB (44.6%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
label: N/A uuid: d540af20-98bf-4853-84e1-5bce691c998d
used: 344 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5
label: NO_LABEL uuid: 375E-CC05
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: ESP
uuid: 44A6-6A0A
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 255.37 GiB fs: ntfs label: Acer
uuid: EE4AA6FE4AA6C327
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 1024 MiB fs: ntfs
label: Recovery uuid: 782CA7A32CA75B40
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Device-1: 2-1:73 info: ASIX AX88179 Gigabit Ethernet
type: communication,CDC-data driver: cdc_ncm interfaces: 2 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 184mA
chip-ID: 0b95:1790 class-ID: 0a00 serial: <filter>
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-1:15 info: AOKEO LCS_USB_Audio type: audio
driver: snd-usb-audio interfaces: 2 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 2e3c:4444 class-ID: 0102
serial: <filter>
Device-2: 3-3:3 info: Areson Corp 2.4G Wireless Receiver
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
chip-ID: 25a7:fa10 class-ID: 0301
Device-3: 3-5:4 info: Chicony HD User Facing type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 04f2:b6dd class-ID: 0e02 serial: <filter>
Device-4: 3-7:5 info: LighTuning EgisTec EH575 type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 100mA chip-ID: 1c7a:0575 class-ID: ff00 serial: <filter>
Device-5: 3-10:6 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0026 class-ID: e001
System Temperatures: cpu: 33.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: 2007 pm: pacman pkgs: 1981 libs: 457 tools: octopi,pamac,yay
pm: flatpak pkgs: 11 pm: snap pkgs: 15
1: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
2: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
3: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
4: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
5: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
6: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
7: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
8: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 263
1: cpu: 19.0% command: konsole pid: 523683 mem: 110.7 MiB (0.7%)
2: cpu: 5.3% command: firefox pid: 511502 mem: 621.4 MiB (3.9%)
3: cpu: 3.7% command: firefox pid: 511715 mem: 877.2 MiB (5.5%)
4: cpu: 3.7% command: firefox pid: 515028 mem: 506.0 MiB (3.2%)
5: cpu: 3.2% command: signal-desktop pid: 514594 mem: 345.3 MiB (2.1%)
Memory top: 5 of 263
1: mem: 877.2 MiB (5.5%) command: firefox pid: 511715 cpu: 3.7%
2: mem: 621.4 MiB (3.9%) command: firefox pid: 511502 cpu: 5.3%
3: mem: 611.0 MiB (3.8%) command: baloo_file pid: 1324 cpu: 0.0%
4: mem: 507.8 MiB (3.2%) command: plasmashell pid: 1374 cpu: 0.1%
5: mem: 506.0 MiB (3.2%) command: firefox pid: 515028 cpu: 3.7%
Processes: 263 Power: uptime: 28d 18h 4m states: freeze,mem,disk
suspend: s2idle avail: deep wakeups: 128 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 6.11 GiB
services: org_kde_powerdevil,upowerd Init: systemd v: 261
Compilers: clang: 23.1.1 gcc: 16.2.1 Shell: Bash v: 5.3.20
running-in: konsole inxi: 3.3.41
Mission accomplished, and the success of which is dedicated to you, guys.
BTW, now the boot menu has soooo many entries .
korben
4 November 2026 10:55
17
Checked mine- already set to true. I should get used to seeing this list of entries by now?
Teo
4 November 2026 14:08
18
You have to sudo update-grub after changing it.
korben
4 November 2026 16:21
19
They are still present, even though the
Then the grub you are updating is not the grub you are booting through.
korben
4 November 2026 17:14
21
they are to be found in my
grub.pacnew
they are not present in
grub
