The idea is that you would merge the files. Do not blindly copy the .pacnew over the existing configuration file, but also do not ignore the .pacnew — it exists for a reason, i.e. that new options and/or new defaults were introduced by upstream.
In this particular case, the .pacnew introduces new options, which allow you to disable the new behavior — the new behavior being that it adds all of your EFI boot manager entries to the grub menu by default.
After merging the changes from the .pacnew into your existing /etc/default/grub, run…
I’ll just add an important observation here, about pacnew handling…
If you encounter a .pacnew file, open it in Meld (or, however you may have it set up) – and you have no clue what to merge or what to keep – this is a prime time to learn.
That there is a .pacnew file often does not demand that you do something with it right now – one can leave it unattended for a few hours, if need be, while researching what the configuration file does, what needs to be changed, merged or kept as-is.
If you frame it that way to yourself, it becomes an excellent learning opportunity.
You are all right about the way it should be handled. Learning, oh boy, I should have had enough of that, or perhaps have only begun to do so.
I need now to copy:
# Disable generating menu entries for other EFI boot manager entries detected
GRUB_DISABLE_BOOTNEXT=true
# Skip EFI boot manager entries that are marked inactive
# when when generating bootnext entries
GRUB_BOOTNEXT_OMIT_INACTIVE=true
exacty like above under
#GRUB_ROOT_FS_RO=true
And that’s what is to be done?
Why don’t I just paste both…
the GRUB:
GRUB_DEFAULT=saved
GRUB_TIMEOUT=2
GRUB_TIMEOUT_STYLE=menu
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet udev.log_priority=3 i915.i915_enable_rc6=1 i915.i915_enable_fbc=1"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
GRUB_DISABLE_OS_PROBER=false
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
grub.pacnew:
# GRUB boot loader configuration
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_CMDLINE_LINUX_DEFAULT="quiet loglevel=3 rd.udev.log_level=3"
# Set to 'countdown' or 'menu' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT_STYLE=hidden
GRUB_GFXMODE=auto
#GRUB_THEME="/path/to/gfxtheme"
# Uncomment to make GRUB remember the last selection. This requires
# setting 'GRUB_DEFAULT=saved' above.
#GRUB_DISABLE_OS_PROBER=false
# See also Arch-Wiki: https://wiki.archlinux.org/title/Fsck#Boot_time_checking
Bear with me…
Mod edit:Pasted the pastebin output here for easier reference, and because pastebin deletes content after some time.
The idea is that you merge the new changes into your old config. You should end up with the new config but with your custom configuration still in place (assuming it’s still valid).
Here’s a merged version, please compare the three versions so you can see how to handle it in future.
GRUB_DEFAULT=saved
GRUB_TIMEOUT=2
GRUB_CMDLINE_LINUX_DEFAULT="quiet loglevel=3 rd.udev.log_level=3 i915.i915_enable_rc6=1 i915.i915_enable_fbc=1"
GRUB_GFXMODE=auto
Sometimes, the officially recommended way to do the things is also the easiest. One doesn’t need to reinvent the wheel.
Install meld. Then
DIFFPROG=meld pacdiff -s
Then hit V and meld will open with colors bells and whistles, and arrows..and then you won’t have to ask where goes what, because it will be positioned automatically. If the pacnew is left, there will be green blocks with an arrow. Click on the arrow and the whole block gets copied in the old file.
After you are ready, click save on the right file, close meld and choose to delete the pacnew, it will ask for the next one.
