SbK Manjaro Cinnamon 525
I am happy to announce the release of SbK Cinnamon 525.
  1. The 6.12.25 LTS kernel.
  2. The New KoraSpin-Blue18 icon theme with light and dark versions of the control icons. It is part of the KoraSpin-525 package
  3. The new SpinThemeDarBlue23 matching Gtk and Kvantum themes in one package.
  4. The new Usplash-525 desktop wallpapers. One of them is the background for the grub, desktop, and login screen backgrounds. The wallapaer used was created by me.
  5. The Blue23 Cinnamon theme in the panel iso included a faded panel and menu.
  6. The iso’s are up to date as of 5/15/2025.
  7. An optional Firefox theme, SbK Dark Blue23, that matches the color scheme is available here, Firefox Themes just click on the image in Firefox to install it.
  1. The latest LTS kernel.
  11. A basic Conly with matching color theme.
Jim
I tried it out.
Is the resolution fixed to XGA?
It’s fixed to XGA even after the installation is complete.
I feel like I’ve missed something, but I decided to hold off until the next challenge. My NVMe disk is already full, so I don’t have any room.
I’ve also tried GNOME and KDE with the latest manjaro ISO.
If it’s a bother, please ignore it.
Click
 4330168320 2025-05-15 18:09 manjaro-gnome-25.0.1-250508-linux612.iso
        107 2025-05-15 18:02 manjaro-gnome-25.0.1-250508-linux612.iso.sha256
        438 2025-05-15 18:09 manjaro-gnome-25.0.1-250508-linux612.iso.sig
 4481851392 2025-05-15 18:02 manjaro-kde-25.0.1-250508-linux612.iso
        105 2025-05-15 17:55 manjaro-kde-25.0.1-250508-linux612.iso.sha256
        438 2025-05-15 18:02 manjaro-kde-25.0.1-250508-linux612.iso.sig
 2651525120 2025-05-17 08:49 sbk-manjaro-cinnamon-dock-525-stable-full-x86_64.iso
        119 2025-05-17 08:35 sbk-manjaro-cinnamon-dock-525-stable-full-x86_64.iso.sha256
One difference between SbK spins and normal Manjaro releases is that the install media only contains open source drivers. You may need to use the Manjaro Settings Manager to install proprietary graphics drivers once installed.
I forgot to give it a proper title and take notes, but this is probably inxi. Please try it if it’s useful. If not, forget about it.
Basically, the monitor is set to unknown.
Thank you.
inxi
Another notable feature is that a PCIe bandwidth splitter card is used to add NVMe. I think the rest of the configuration is normal.
https://0x0.st/8wzo.txt
I am unable to open that link, it errors out.
I also recieved a message from you with this info
 inxi -G
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX
    470/480/570/570X/580/580X/590] driver: amdgpu v: kernel
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6 driver: X:
    loaded: amdgpu unloaded: modesetting dri: radeonsi gpu: amdgpu
    resolution: 3840x2160~60Hz
  API: EGL v: 1.5 drivers: kms_swrast,radeonsi,swrast
This line shows that the proprietary AMD driver isnt loaded. I have bolded the important part.
I suggest you try and install the driver with this command
sudo mhwd -a pci nonfree 0300
Additionally this page may be helpful if you continue to have problems. You may need to uninstall the radeonsi (a driver for a different AMD series) driver to force the os to use the amdgpu driver after reinstalling the amdgpu driver.
As a side note, I have a Rx 570 in my machine, I know the card works with the spins and Manjaro.
