I am very pleased to announce the release of SbK Gnome 21.0.7
- The 5.10.42 LTS kernel.
- The following Gnome shell extensions are installed and used:
Dash to Dock
Clipboard Indicator
Remove dropdown arrows
Hide Top bar (The top bar is hiddin by default. Moving the cursor to the top edge will show it.)
Desktop Icons ng (It is enabled. But end users wil have to manually set for launchers to be executable, or trusted. Until then they will have the generic launcher icon and will only open as a text file.) - Minimize and Maximize window controls.
- The New FlatRemixSpin-Magenta icon theme with light and dark versions.
- The new KvSpinDarkMagenta dual Kvantum and matching Gtk theme.
- 5 new desktop wallpapers. One of them is the background for the grub, desktop, and login screen backgrounds.
- Usplash2 Wallpapers are included in the wallpaper selector.
- LightDM instead of GDM with lightlocker screen locking.
- Lots of updates since the 20.1.1 release. The iso’s are up to date as of 6/21/2021.
- A Manjaro stable install that is also AUR compatible.
- The latest long term support kernel
- All SbK iso’s contain Manjaro Architect script in case you want to do a custom install. Sadly to get any SbK packages like themes, icons, and other goodies you will have to add the SbK Repository after install. http://spins.tuxfamily.org/repo.html
Jim
P.S Yes the SbK Gnome 21.0.7 iso’s are smaller in size than the official ones. ![]()
