I was working with some systemd services and I decided to restart, but when I booted up again, I got the error “Root device mounted successfully, but /sbin/init does not exist. Bailing out, you are on your own. Good luck. sh: can’t access tty; job control turned off”.
Any help would be appreciated.
I suggest you boot with a live CD, chroot into your environment and set this link manually. Lets see if that already helps. You probably do not even need to do a chroot. Just mount your root partition and set the link.
