I just received my Samsung T5 SSD. It is not mounted automatically, unfortunately. I tried a lot of things on my own to mount it manually, but I don’t know how. I even don’t know if it is actually possible and supported.
Anyone can help me with this? lsubs does list the device. fdisk -l does not.
aqm@aqm ~> lsusb
Bus 002 Device 007: ID 04e8:61f5 Samsung Electronics Co., Ltd Portable SSD T5
aqm@aqm ~> sudo fdisk -l
Disk /dev/nvme0n1: 476,94 GiB, 512110190592 bytes, 1000215216 sectors
Disk model: PC401 NVMe SK hynix 512GB
Disklabel type: gpt
Disk identifier: 929F45FA-8E2B-4F2E-AE03-A6A2A46D723A
Device Start End Sectors Size Type
/dev/nvme0n1p1 4097 618497 614401 300M EFI System
/dev/nvme0n1p2 618498 964396811 963778314 459,6G Linux filesystem
/dev/nvme0n1p3 964396812 1000206899 35810088 17,1G Linux swap
@kisun thanks, good suggestion. I just opened gparted. I only see my internal HD with its partitions. I cannot choose the external SSD in the devices list. I tried refreshing the list ofcourse. I Also tried another USB port.
Sorry I overread the ‘portable’. Then portable devices are still pre formatted. Mostly with ‘ntfs’. But preformatted or not it should be in device list.
@kisun ok what can I do when it is not listed? I also tried things with gvfs-mtp which apparently stands for media transfer protocol. It has something to do with Android hardware, which this SSD supports.
Should this be able to work? Or should I return it for a supported SSD? I am clueless at the moment.
I checked lsblk every time, I don’t see any difference.
The last log is like this.
[303573.321450] usb 2-1: USB disconnect, device number 10
[303584.954809] usb 2-2: new SuperSpeed USB device number 11 using xhci_hcd
[303613.061483] usb 2-2: USB disconnect, device number 11
[303621.471773] usb 4-1.3: new SuperSpeed USB device number 4 using xhci_hcd
[303700.018165] usb 4-1.3: USB disconnect, device number 4
[303704.231788] usb 4-1.3: new SuperSpeed USB device number 5 using xhci_hcd
[303714.864899] usb 4-1.3: USB disconnect, device number 5
[303718.181562] usb 2-1: new SuperSpeed USB device number 12 using xhci_hcd
aqm@aqm /> sudo lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
nvme0n1 259:0 0 476,9G 0 disk
├─nvme0n1p1 259:1 0 300M 0 part /boot/efi
├─nvme0n1p2 259:2 0 459,6G 0 part /
└─nvme0n1p3 259:3 0 17,1G 0 part [SWAP]
Yeah, I anticipated on that on my last post. But here it is as a whole.
aqm@aqm /> sudo dmesg -T | tail -n 50
[vr dec 31 13:54:35 2021] hub 3-0:1.0: 2 ports detected
[vr dec 31 13:54:35 2021] xhci_hcd 0000:3e:00.0: xHCI Host Controller
[vr dec 31 13:54:35 2021] xhci_hcd 0000:3e:00.0: new USB bus registered, assigned bus number 4
[vr dec 31 13:54:35 2021] xhci_hcd 0000:3e:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[vr dec 31 13:54:35 2021] hub 4-0:1.0: USB hub found
[vr dec 31 13:54:35 2021] hub 4-0:1.0: 2 ports detected
[vr dec 31 13:54:35 2021] usb 3-1: new high-speed USB device number 2 using xhci_hcd
[vr dec 31 13:54:35 2021] hub 3-1:1.0: USB hub found
[vr dec 31 13:54:35 2021] hub 3-1:1.0: 7 ports detected
[vr dec 31 13:54:35 2021] usb 4-1: new SuperSpeed USB device number 2 using xhci_hcd
[vr dec 31 13:54:35 2021] hub 4-1:1.0: USB hub found
[vr dec 31 13:54:35 2021] hub 4-1:1.0: 7 ports detected
[vr dec 31 13:54:35 2021] usb 3-1.1: new full-speed USB device number 3 using xhci_hcd
[vr dec 31 13:54:35 2021] usblp 3-1.1:1.0: usblp0: USB Bidirectional printer dev 3 if 0 alt 1 proto 2 vid 0x03F0 pid 0x1D17
[vr dec 31 13:54:35 2021] usb 4-1.2: new SuperSpeed USB device number 3 using xhci_hcd
[vr dec 31 13:54:36 2021] usb 3-1.5: new high-speed USB device number 4 using xhci_hcd
[vr dec 31 13:54:36 2021] usb 4-1.2: reset SuperSpeed USB device number 3 using xhci_hcd
[vr dec 31 13:54:36 2021] r8152 4-1.2:1.0 (unnamed net_device) (uninitialized): Using pass-thru MAC addr 10:65:30:9a:45:23
[vr dec 31 13:54:36 2021] r8152 4-1.2:1.0 eth0: v1.09.9
[vr dec 31 13:54:37 2021] usb 3-1.7: new high-speed USB device number 5 using xhci_hcd
[vr dec 31 13:54:37 2021] hub 3-1.7:1.0: USB hub found
[vr dec 31 13:54:37 2021] hub 3-1.7:1.0: 4 ports detected
[vr dec 31 13:54:37 2021] usb 3-1.7.1: new full-speed USB device number 6 using xhci_hcd
[vr dec 31 13:54:37 2021] hub 3-1.7.1:1.0: USB hub found
[vr dec 31 13:54:37 2021] hub 3-1.7.1:1.0: 3 ports detected
[vr dec 31 13:54:37 2021] usb 3-1.7.4: new low-speed USB device number 7 using xhci_hcd
[vr dec 31 13:54:37 2021] input: Logitech USB Laser Mouse as /devices/pci0000:00/0000:00:1d.6/0000:06:00.0/0000:07:02.0/0000:3e:00.0/usb3/3-1/3-1.7/3-1.7.4/3-1.7.4:1.0/0003:046D:C069.0014/input/input66
[vr dec 31 13:54:37 2021] hid-generic 0003:046D:C069.0014: input,hidraw1: USB HID v1.10 Mouse [Logitech USB Laser Mouse] on usb-0000:3e:00.0-1.7.4/input0
[vr dec 31 13:54:37 2021] usb 3-1.7.1.1: new full-speed USB device number 8 using xhci_hcd
[vr dec 31 13:54:37 2021] input: Dell Dell USB Keyboard Hub as /devices/pci0000:00/0000:00:1d.6/0000:06:00.0/0000:07:02.0/0000:3e:00.0/usb3/3-1/3-1.7/3-1.7.1/3-1.7.1.1/3-1.7.1.1:1.0/0003:413C:2010.0015/input/input67
[vr dec 31 13:54:38 2021] hid-generic 0003:413C:2010.0015: input,hidraw2: USB HID v1.10 Keyboard [Dell Dell USB Keyboard Hub] on usb-0000:3e:00.0-1.7.1.1/input0
[vr dec 31 13:54:38 2021] input: Dell Dell USB Keyboard Hub as /devices/pci0000:00/0000:00:1d.6/0000:06:00.0/0000:07:02.0/0000:3e:00.0/usb3/3-1/3-1.7/3-1.7.1/3-1.7.1.1/3-1.7.1.1:1.1/0003:413C:2010.0016/input/input68
[vr dec 31 13:54:38 2021] hid-generic 0003:413C:2010.0016: input,hidraw3: USB HID v1.10 Device [Dell Dell USB Keyboard Hub] on usb-0000:3e:00.0-1.7.1.1/input1
[vr dec 31 13:54:38 2021] r8152 4-1.2:1.0 enp62s0u1u2: renamed from eth0
[vr dec 31 13:54:38 2021] IPv6: ADDRCONF(NETDEV_UP): enp62s0u1u2: link is not ready
[vr dec 31 13:54:39 2021] acpi INT3400:00: Unsupported event [0x86]
[vr dec 31 13:54:39 2021] ata2: SATA link down (SStatus 4 SControl 300)
[vr dec 31 13:54:44 2021] usb 2-1: new SuperSpeed USB device number 10 using xhci_hcd
[vr dec 31 13:54:44 2021] usblp0: removed
[vr dec 31 13:54:44 2021] usblp 3-1.1:1.0: usblp0: USB Bidirectional printer dev 3 if 0 alt 1 proto 2 vid 0x03F0 pid 0x1D17
[vr dec 31 14:03:43 2021] [drm:intel_pipe_update_end [i915]] *ERROR* Atomic update failure on pipe B (start=1980091 end=1980092) time 134 us, min 1192, max 1199, scanline start 1191, end 1201
[vr dec 31 14:10:54 2021] usb 2-1: USB disconnect, device number 10
[vr dec 31 14:11:05 2021] usb 2-2: new SuperSpeed USB device number 11 using xhci_hcd
[vr dec 31 14:11:34 2021] usb 2-2: USB disconnect, device number 11
[vr dec 31 14:11:42 2021] usb 4-1.3: new SuperSpeed USB device number 4 using xhci_hcd
[vr dec 31 14:13:01 2021] usb 4-1.3: USB disconnect, device number 4
[vr dec 31 14:13:05 2021] usb 4-1.3: new SuperSpeed USB device number 5 using xhci_hcd
[vr dec 31 14:13:15 2021] usb 4-1.3: USB disconnect, device number 5
[vr dec 31 14:13:19 2021] usb 2-1: new SuperSpeed USB device number 12 using xhci_hcd
aqm@aqm ~> ll /dev/
total 0
lrwxrwxrwx 1 root root 15 31 dec 14:13 android -> bus/usb/002/012
lrwxrwxrwx 1 root root 15 31 dec 14:13 android1 -> bus/usb/002/012
EDIT:
aqm@aqm ~> sudo mount /dev/android /media
mount: /media: /dev/bus/usb/002/012 is not a block device.
aqm@aqm ~> sudo mount /dev/android1 /media
aqm@aqm ~> sudo dmesg -T | grep usb | tail -n 20
EDIT:
I replugged in. The times are as fresh as they get. My local time here is 14.24
[vr dec 31 14:24:28 2021] usb 2-1: USB disconnect, device number 12
[vr dec 31 14:24:30 2021] usb 2-1: new SuperSpeed USB device number 13 using xhci_hcd
I’m pretty sure the problem is your USB port. The device is not properly detected. Some Samsung devices are known to not be 100% compatible with the specs. You could try kernels before 5.10.
