Hey guys I just installed Manjaro and noticed that my screens resolution is wrong.
The monitor supports 2560x1440 at 144hz but the resolution does not appear in the Display configurator.
The highest resolution it gives me is 1280x800 at 60hz.
I’ve tried manually adding the resolution using cvt and xrandr as described elsewhere, but I get the error message “xrandr: Configure crtc 0 failed”
inxi -Fza:
Kernel: 5.7.14-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64
root=UUID=e52355c3-fc9e-41d7-8217-c68f6fd78024 rw quiet apparmor=1
security=apparmor resume=UUID=c6246d6e-04a0-4a53-bf7f-3896b4b208da
udev.log_priority=3
Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-F GAMING v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 1405 date: 11/19/2019
ID-1: hidpp_battery_0 charge: N/A condition: N/A volts: 3.8/N/A
model: Logitech G502 LIGHTSPEED Wireless Gaming Mouse type: N/A
serial: <filter> status: Discharging
Topology: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP
arch: Zen 2 family: 17 (23) model-id: 71 (113) stepping: N/A
microcode: 8701013 L2 cache: 4096 KiB
bogomips: 115024
Speed: 2190 MHz min/max: 2200/3600 MHz boost: enabled
Core speeds (MHz): 1: 2197 2: 2193 3: 2187 4: 2191 5: 2195 6: 2192
7: 2191 8: 2189 9: 2196 10: 2196 11: 2197 12: 2192 13: 2197 14: 2194
15: 2196 16: 2193
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: ASUSTeK driver: amdgpu v: kernel bus ID: 0b:00.0
chip ID: 1002:731f
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: amdgpu
FAILED: ati unloaded: modesetting,radeon alternate: fbdev,vesa
display ID: :0 screens: 1
Screen-1: 0 s-res: 3520x1080 s-dpi: 96 s-size: 928x285mm (36.5x11.2")
s-diag: 971mm (38.2")
Monitor-1: DisplayPort-0 res: 1600x900 hz: 60 dpi: 68
size: 597x336mm (23.5x13.2") diag: 685mm (27")
Monitor-2: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 93
size: 522x294mm (20.6x11.6") diag: 599mm (23.6")
OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.37.0
5.7.14-1-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.1.5 direct render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
bus ID: 0b:00.1 chip ID: 1002:ab38
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 0d:00.4 chip ID: 1022:1487
Device-3: Kingston HyperX 7.1 Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-3:3
chip ID: 0951:16a4 serial: <filter>
Sound Server: ALSA v: k5.7.14-1-MANJARO
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb
v: 5.6.0-k port: f000 bus ID: 05:00.0 chip ID: 8086:1539
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 2.70 TiB used: 1.27 TiB (47.1%)
ID-1: /dev/nvme0n1 vendor: Corsair model: Force MP510 size: 894.25 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: ECFM22.6 scheme: GPT
ID-2: /dev/nvme1n1 vendor: Corsair model: Force MP510 size: 894.25 GiB
serial: <filter> rev: ECFM12.2 scheme: GPT
ID-3: /dev/sda vendor: Seagate model: ST2000DM001-1ER164 size: 1.82 TiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: CC25 scheme: MBR
ID-4: /dev/sdb type: USB vendor: Kingston model: DataTraveler 3.0
size: 7.23 GiB block size: physical: 512 B logical: 512 B
serial: <filter> rev: PMAP scheme: MBR
ID-1: / raw size: 859.48 GiB size: 844.99 GiB (98.31%)
used: 8.38 GiB (1.0%) fs: ext4 dev: /dev/nvme0n1p2
ID-1: swap-1 type: partition size: 34.48 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3
System Temperatures: cpu: 58.9 C mobo: N/A gpu: amdgpu temp: 46 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 314 Uptime: 11m Memory: 31.34 GiB used: 2.12 GiB (6.8%)
Init: systemd v: 245 Compilers: gcc: 10.1.0 Packages: pacman: 1186
lib: 318 flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole
inxi: 3.1.05
