Samba WERR_ACCESS_DENIED
New Manjaro install, trying to set up SAMBA share. I keep getting the same error.
Failed to add share
net: Failed to initialize the registry: WERR_ACCESS_DENIED
Can't load /etc/samba/smb.conf - run testparm to debug it
Failed to initialize the registry: WERR_ACCESS_DENIED (255)
testparm                                                         ✔
Load smb config files from /etc/samba/smb.conf
regdb_init: Failed to open registry /var/lib/samba/registry.tdb (Permission denied)
error initializing registry configuration: SBC_ERR_BADFILE
Error loading services.
sudo testparm                                                  1 ✘
Loaded services file OK.
Weak crypto is allowed by GnuTLS (e.g. NTLM as a compatibility fallback)
Server role: ROLE_STANDALONE
Press enter to see a dump of your service definitions
# Global parameters
[global]
        client min protocol = SMB2
        disable spoolss = Yes
        dns proxy = No
        load printers = No
        log file = /var/log/samba/%m.log
        map to guest = Bad Password
        max log size = 1000
        name resolve order = lmhosts bcast host wins
        obey pam restrictions = Yes
        pam password change = Yes
        passwd chat = *New*UNIX*password* %n\n *ReType*new*UNIX*password* %n\n *passwd:*all*authentication*tokens*updated*successfully*
        passwd program = /usr/bin/passwd %u
        printcap name = /dev/null
        registry shares = Yes
        security = USER
        server role = standalone server
        show add printer wizard = No
        unix password sync = Yes
        usershare allow guests = Yes
        usershare max shares = 100
        usershare path = /var/lib/samba/usershare
        idmap config * : backend = tdb
        force create mode = 0070
        force directory mode = 0070
        printing = bsd
[homes]
        comment = Home Directories
        create mask = 0700
        directory mask = 0700
        read only = No
        valid users = %S
[printers]
        browseable = No
        comment = All Printers
        create mask = 0700
        path = /var/spool/samba
        printable = Yes
[print$]
        comment = Printer Drivers
        path = /var/lib/samba/printers
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
registry.tdb permissions may be wrong. Execute commands:
sudo ls -l /var/lib/samba/registry.tdb
and
ps -aux | grep smb
And copy here the output.
rw-rw---- 1 nobody root 421888 Feb 27 10:02 /var/lib/samba/registry.tdb
ps -aux | grep smb                                               ✔
root         596  0.0  0.3  93348 26752 ?        Ss   12:03   0:00 /usr/bin/smbd --foreground --no-process-group
root         602  0.0  0.0  90828  6400 ?        S    12:03   0:00 smbd: notifyd
root         603  0.0  0.0  90836  5760 ?        S    12:03   0:00 smbd: cleanupd
john        4548  0.0  0.0   6580  2432 pts/1    S+   13:03   0:00 grep smb
This guide might be of some help. Is your user name a member of the sambashare group?
You may fare better setting up samba file sharing via your file manager. Thunar has thunar-shares-plugin. It is fine for basic file sharing between my various Manjaro systems. Maybe Dolphin/KDE has something similar?
It’s built into KDE Dolphin file manager… and throwing off the same error. :frowning:
It is fairly obvious why it won’t work
You are missing the /etc/samba/smb.conf or it is misconfigured.
Even the most basic samba requires knowledge … and nothing with relation to samba comes pre-configured.
You must learn how to configure samba and the topic linked above describes how you setup a basic samba service.
Another topic is [root tip] [How To] Samba Server From Scratch which goes into more details regarding permissions and user access.
A forum search for samba will also reveal a lot of topics.
If you want to create a user share using your file manager - besides configuring the samba server service - see the usershares section → [root tip] [How To] Basic Samba Setup and Troubleshooting
Well, I do have a samba.conf (see below) and I have gone through a bunch of sources to try to identify what is wrong. WERR_ACCESS_DENIED seems to be a permissions issue, not a configuration issue, but I’d sure appreciate any review of the .conf file to see if anything is wrong there that could be driving it.
[global]
   workgroup = WORKGROUP
   dns proxy = no
   max log size = 1000
   passdb backend = tdbsam
   obey pam restrictions = yes
   unix password sync = yes
   pam password change = yes
   usershare allow guests = yes
   security = user
   guest account = nobody
   usershare owner only = yes
   load printers = no
   printing = bsd
   disable spoolss = yes
   show add printer wizard = no
   include = registry
[homes]
   browseable = yes
   read only = no
   create mask = 0700
   valid users = %S
[printers]
   browseable = no
   printable = yes
   guest ok = no
   read only = yes
   create mask = 0700
[print$]
   browseable = yes
   read only = yes
   guest ok = no
samba.conf or smb.conf?
Thanks, sorry, smb.conf
A bit more info…
smbclient -L //sambaserver                                ✔  5s 
do_connect: Connection to sambaserver failed (Error NT_STATUS_INVALID_PARAMETER)
move that smb.conf → smb.conf.bak
Then rewrite it using only the options you actually need → see the topics linked
For example - in the general section you specifically exclude printers but you define a share later - that is inconsistent.
I don’t know why you have this - you don’t need it - your smb.conf is a mess - and you are better off rewriting the config from scratch
If the goal is to share one or two folders from your user account
This should suffice
[global]
   workgroup = MANJARO
   server string = Manjaro Samba Server
   log file = /var/log/samba/log.%m
   max log size = 50
   min protocol = SMB2
   max protocol = SMB3
  usershare path = /var/lib/samba/usershares
You still need to configure the usershares → [root tip] [How To] Basic Samba Setup and Troubleshooting
OK, followed that with new smb.conf, now I’m at the point where I have a new error, ‘var/lib/samba/usershares’ has its group owner inappropirately set to ‘root,’ which is not allowed… need to change folder’s group owner to ‘sambashares.’ I recognize that should use ‘sudo chown’ in some manner, but trying to figure out how, exactly… something like chown -hR sambashares /var/lib/samba/usershares ?
You neglected the steps outlined in the link …
Possibly you also neglected to create the necessary smbuser …
Well, this got me going… thanks to all who opined! A simple, fool proof tutorial on installing Samba - Linux Mint Forums
Creating entries like this in smb.conf solves the problem for me, anyway:
[Downloads]
path = /home/user/Downloads
read only = no
force user = root
guest ok = no
