m364n0
July 28, 2022, 4:28am
1
When I type:
sudo systemctl status samba.service
~ sudo systemctl status samba.service ✔
[sudo] password for m6bmgdipolog:
× samba.service - Samba AD Daemon
Loaded: loaded (/usr/lib/systemd/system/samba.service; enabled; preset: disabled)
Active: failed (Result: exit-code) since Thu 2022-07-28 00:18:43 EDT; 28s ago
Docs: man:samba(8)
man:samba(7)
man:smb.conf(5)
Process: 933 ExecStart=/usr/bin/samba --foreground --no-process-group $SAMBAOPTIONS (code=exited, status=1/FAILURE)
Main PID: 933 (code=exited, status=1/FAILURE)
Status: "daemon failed to start: Samba detected misconfigured 'server role' and exited. Check logs for details"
Error: 22 (Invalid argument)
CPU: 73ms
Jul 28 00:18:43 M6-BMGDIPOLOG samba[933]: daemon_status: daemon 'samba' : Starting process...
Jul 28 00:18:43 M6-BMGDIPOLOG samba[933]: [2022/07/28 00:18:43.457187, 0] ../../source4/samba/server.c:851(binary_smbd_main)
Jul 28 00:18:43 M6-BMGDIPOLOG samba[933]: At this time the 'samba' binary should only be used for either:
Jul 28 00:18:43 M6-BMGDIPOLOG samba[933]: 'server role = active directory domain controller' or to access the ntvfs file server with 'ser>
Jul 28 00:18:43 M6-BMGDIPOLOG samba[933]: You should start smbd/nmbd/winbindd instead for domain member and standalone file server tasks
Jul 28 00:18:43 M6-BMGDIPOLOG samba[933]: [2022/07/28 00:18:43.457290, 0] ../../lib/util/become_daemon.c:119(exit_daemon)
Jul 28 00:18:43 M6-BMGDIPOLOG samba[933]: exit_daemon: daemon failed to start: Samba detected misconfigured 'server role' and exited. Che>
Jul 28 00:18:43 M6-BMGDIPOLOG systemd[1]: samba.service: Main process exited, code=exited, status=1/FAILURE
Jul 28 00:18:43 M6-BMGDIPOLOG systemd[1]: samba.service: Failed with result 'exit-code'.
Jul 28 00:18:43 M6-BMGDIPOLOG systemd[1]: Failed to start Samba AD Daemon.
When I type:
sudo systemctl status smb.service
~ sudo systemctl status smb.service 3 ✘ 16s
● smb.service - Samba SMB Daemon
Loaded: loaded (/usr/lib/systemd/system/smb.service; enabled; preset: disabled)
Active: active (running) since Thu 2022-07-28 00:18:43 EDT; 48s ago
Docs: man:smbd(8)
man:samba(7)
man:smb.conf(5)
Main PID: 948 (smbd)
Status: "smbd: ready to serve connections..."
Tasks: 3 (limit: 4502)
Memory: 9.9M
CPU: 56ms
CGroup: /system.slice/smb.service
├─948 /usr/bin/smbd --foreground --no-process-group
├─958 /usr/bin/smbd --foreground --no-process-group
└─959 /usr/bin/smbd --foreground --no-process-group
Jul 28 00:18:43 M6-BMGDIPOLOG systemd[1]: Starting Samba SMB Daemon...
Jul 28 00:18:43 M6-BMGDIPOLOG smbd[948]: [2022/07/28 00:18:43.465018, 0] ../../source3/smbd/server.c:1741(main)
Jul 28 00:18:43 M6-BMGDIPOLOG smbd[948]: smbd version 4.16.3 started.
Jul 28 00:18:43 M6-BMGDIPOLOG smbd[948]: Copyright Andrew Tridgell and the Samba Team 1992-2022
Jul 28 00:18:43 M6-BMGDIPOLOG systemd[1]: Started Samba SMB Daemon.
When I type:
testparm
~ testparm INT ✘
Load smb config files from /etc/samba/smb.conf
Loaded services file OK.
Weak crypto is allowed
Server role: ROLE_STANDALONE
Press enter to see a dump of your service definitions
# Global parameters
[global]
client min protocol = SMB2
disable spoolss = Yes
dns proxy = No
load printers = No
log file = /var/log/samba/%m.log
map to guest = Bad Password
max log size = 1000
name resolve order = lmhosts bcast host wins
obey pam restrictions = Yes
pam password change = Yes
passwd chat = *New*UNIX*password* %n\n *ReType*new*UNIX*password* %n\n *passwd:*all*authentication*tokens*updated*successfully*
passwd program = /usr/bin/passwd %u
printcap name = /dev/null
security = USER
server role = standalone server
show add printer wizard = No
unix password sync = Yes
usershare allow guests = Yes
usershare max shares = 100
usershare path = /var/lib/samba/usershare
idmap config * : backend = tdb
force create mode = 0070
force directory mode = 0070
printing = bsd
[homes]
browseable = No
comment = Home Directories
create mask = 0700
directory mask = 0700
valid users = %S
[printers]
browseable = No
comment = All Printers
create mask = 0700
path = /var/spool/samba
printable = Yes
[print$]
comment = Printer Drivers
path = /var/lib/samba/printers
Read the error message - then search the samba documentation
m364n0:
Jul 28 00:18:43 M6-BMGDIPOLOG samba[933]: exit_daemon: daemon failed to start: Samba detected misconfigured 'server role' and exited. Che>```
Some basic troubleshooting is available
xabbu
July 28, 2022, 4:58am
3
Do not enable and start the samba.service. Do it only if you want to run a Active Directory domain controller.
See the Arch wiki on Sambas AD to figure out if you really want this.
https://wiki.archlinux.org/title/Samba/Active_Directory_domain_controller
m364n0
July 28, 2022, 6:19am
4
before it wasn’t like this, I can immediately access to Windows Shared Folder from my Windows 11 laptop, but after I updated it to 4.16 can’t access no more. It will always says “Failed to mount windows share: Invalid argument”
That may be true - but your issue is very unclear and your comments confusing.
If your Windows 11 cannot connect and the above is a reference to your Windows 11 system - let it be clear - this is not a Manjaro issue.
The error message is quite clear - you have a configuration problem - which is why the service refuses to start.
Have you checked your logs?
Upstream Samba is constantly evolving and has to adapt to avoid ransomware propagating over network.
If you are using Manjaro as a stand-alone fileserver in your home network - I strongly advise you to go over your configuration - simplify it as much as possible.
The guide referenced earlier provides a working configuration
m364n0
July 28, 2022, 11:41pm
6
I downgraded the SAMBA & SMB to 4.15 and this is what happened when i run both samba ang smb services
Active: failed (Result: exit-code) since Thu 2022-07-28 19:34:01 EDT; 5s ago
Docs: man:samba(8)
man:samba(7)
man:smb.conf(5)
Process: 1379 ExecStart=/usr/bin/samba --foreground --no-process-group $SAMBAOPTIONS (code=exited, status=127)
Main PID: 1379 (code=exited, status=127)
CPU: 4ms
Jul 28 19:34:01 M6-BMGDIPOLOG systemd[1]: Starting Samba AD Daemon...
Jul 28 19:34:01 M6-BMGDIPOLOG samba[1379]: /usr/bin/samba: error while loading shared libraries: libicui18n.so.70: cannot open shared objec>
Jul 28 19:34:01 M6-BMGDIPOLOG systemd[1]: samba.service: Main process exited, code=exited, status=127/n/a
Jul 28 19:34:01 M6-BMGDIPOLOG systemd[1]: samba.service: Failed with result 'exit-code'.
Jul 28 19:34:01 M6-BMGDIPOLOG systemd[1]: Failed to start Samba AD Daemon.
~ sudo systemctl status smb.service 3 ✘ 11s
× smb.service - Samba SMB Daemon
Active: failed (Result: exit-code) since Thu 2022-07-28 19:34:01 EDT; 23s ago
Docs: man:smbd(8)
man:samba(7)
man:smb.conf(5)
Process: 1380 ExecStart=/usr/bin/smbd --foreground --no-process-group $SMBDOPTIONS (code=exited, status=127)
Main PID: 1380 (code=exited, status=127)
CPU: 6ms
Jul 28 19:34:01 M6-BMGDIPOLOG systemd[1]: Starting Samba SMB Daemon...
Jul 28 19:34:01 M6-BMGDIPOLOG smbd[1380]: /usr/bin/smbd: error while loading shared libraries: libicui18n.so.70: cannot open shared object file: No such file or directory
Jul 28 19:34:01 M6-BMGDIPOLOG systemd[1]: smb.service: Main process exited, code=exited, status=127/n/a
Jul 28 19:34:01 M6-BMGDIPOLOG systemd[1]: smb.service: Failed with result 'exit-code'.
Jul 28 19:34:01 M6-BMGDIPOLOG systemd[1]: Failed to start Samba SMB Daemon.
Downgrading packages are not supported. That can and will cause problems like…
If you want help from our volunteer community members, please follow the advice provided and follow the helpful tutorials linked above.
m364n0
July 29, 2022, 4:17am
9
~ cat /etc/samba/smb.conf 3 ✘ 11s
[global]
workgroup = WORKGROUP
dns proxy = no
max log size = 1000
passdb backend = tdbsam
obey pam restrictions = yes
unix password sync = yes
pam password change = yes
usershare allow guests = yes
security = user
guest account = nobody
usershare owner only = yes
load printers = no
printing = bsd
disable spoolss = yes
show add printer wizard = no
[homes]
browseable = no
read only = yes
create mask = 0700
valid users = %S
[printers]
browseable = no
printable = yes
guest ok = no
read only = yes
create mask = 0700
[print$]
browseable = yes
read only = yes
guest ok = no
