Hi I recently built a new computer with a RX 5700 XT and Ryzen 3700x. I am currently using Windows, but OpenGL games like CS GO and Runescape run terribly with these drivers. I read that AMD Graphics Drivers are better with Linux but have been hesitant to change because of a lack of knowledge on the installation of Drivers on Linux (is it similar to windows). I have also read that some users have had more crashes on Linux than Windows. I decided that if I was going to change I wanted to use Manjaro because of the large community and articles that I read saying that it was more stable than other Distros like Ubuntu. My questions are…
How do you install Drivers in General (e.x. MOB Drivers, etc.)?
What is the Gaming Experience on Manjaro, is it better or worse than Windows, and what games are unplayable?
Is the software the same(Ex. Adrenalin, Epic Games Store, Steam, Discord)?
I’m fairly new to the existence of Linux and appreciate any help that I can get! Thanks!
As @realmain has already answered all of your questions, I can only add that before you switch to Manjaro (not Arch: that’s a different Linux and quite difficult for a first time user), you should read this:
Furthermore, I’ve marked this answer as the solution to your question as it is by far the best answer you’ll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
