Apologies for the late reply. Here is the inxi output you requested – thank you.
[...]$ sudo inxi --verbosity=8 --filter
[sudo] password for ...:
Kernel: 6.12.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
clocksource: tsc avail: kvm-clock,acpi_pm
root=UUID=1261871b-4569-42f3-9211-40baaf16a30b rw quiet apparmor=1
Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 v: 4.20.0
with: xfce4-panel tools: light-locker,xfce4-screensaver dm: LightDM
v: 1.32.0 Distro: Manjaro base: Arch Linux
Type: Virtualbox System: innotek GmbH product: VirtualBox v: 1.2 serial: N/A
Chassis: Oracle Corporation type: 1 serial: N/A
Mobo: Oracle model: VirtualBox v: 1.2 serial: N/A
uuid: ce018902-e435-2646-85de-9a2a4a3819db BIOS: innotek GmbH v: VirtualBox
date: 12/01/2006
ID-1: BAT0 charge: 50.0 Wh (100.0%) condition: 50.0/50.0 Wh (100.0%)
volts: 10.0 min: 10.0 model: innotek 1 type: Unknown serial: N/A
status: full
System RAM: total: 16 GiB available: 15.62 GiB used: 1.78 GiB (11.4%)
RAM Report: message: No RAM data found using dmidecode.
Message: No PCI Slot data found.
Info: model: Intel Core i7-9750H bits: 64 type: MCP arch: Coffee Lake
gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF4
Topology: cpus: 1x dies: 1 clusters: 3 cores: 3 smt: <unsupported> cache:
L1: 192 KiB desc: d-3x32 KiB; i-3x32 KiB L2: 768 KiB desc: 3x256 KiB
L3: 36 MiB desc: 3x12 MiB
Speed (MHz): avg: 2592 min/max: N/A cores: 1: 2592 2: 2592 3: 2592
bogomips: 15560
Flags: 3dnowprefetch abm adx aes apic arat arch_capabilities avx avx2
bmi1 bmi2 clflush clflushopt cmov constant_tsc cpuid cx16 cx8 de f16c
flush_l1d fma fpu fsgsbase fxsr ht hypervisor invpcid lahf_lm lm mca mce
md_clear mmx movbe msr mtrr nonstop_tsc nopl nx pae pat pcid pclmulqdq
pge pni popcnt pse pse36 pti rdrand rdseed rdtscp rep_good sep sse sse2
sse4_1 sse4_2 ssse3 syscall tsc tsc_known_freq vme x2apic xsave xtopology
Type: gather_data_sampling status: Unknown: Dependent on hypervisor status
Type: itlb_multihit status: KVM: VMX unsupported
Type: mds mitigation: Clear CPU buffers; SMT Host state unknown
Type: mmio_stale_data mitigation: Clear CPU buffers; SMT Host state
unknown
Type: retbleed status: Vulnerable
Type: spectre_v2 mitigation: Retpolines; STIBP: disabled; RSB filling;
PBRSB-eIBRS: Not affected; BHI: Retpoline
Type: srbds status: Unknown: Dependent on hypervisor status
Device-1: VMware SVGA II Adapter driver: vmwgfx v: 2.20.0.0 ports:
active: Virtual-1 empty: Virtual-2, Virtual-3, Virtual-4, Virtual-5,
Virtual-6, Virtual-7, Virtual-8 bus-ID: 00:02.0 chip-ID: 15ad:0405
class-ID: 0300
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: xfwm4 v: 4.20.0 driver: X: loaded: vmware unloaded: modesetting
alternate: fbdev,vesa dri: vmwgfx gpu: vmwgfx display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x966 s-dpi: 96 s-size: 509x256mm (20.04x10.08")
s-diag: 570mm (22.43")
Monitor-1: Virtual-1 mapped: Virtual1 res: mode: 1920x966 hz: 60
scale: 100% (1) size: N/A modes: 1920x966, 4096x2160, 2560x1600, 1920x1440,
1856x1392, 1792x1344, 2048x1152, 1920x1200, 1920x1080, 1600x1200,
1680x1050, 1400x1050, 1600x900, 1280x1024, 1440x900, 1280x960, 1366x768,
1360x768, 1280x800, 1280x768, 1280x720, 1024x768, 800x600, 848x480,
640x480
API: EGL v: 1.5 platforms: device: 0 drv: vmwgfx device: 1 drv: swrast
gbm: drv: vmwgfx surfaceless: drv: vmwgfx x11: drv: vmwgfx inactive: wayland
API: OpenGL v: 4.5 compat-v: 4.1 vendor: vmware mesa v: 25.0.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: SVGA3D; build: RELEASE; LLVM;
device-ID: 15ad:0405 memory: 1000 KiB unified: no
Info: Tools: api: eglinfo, glxinfo, vulkaninfo de: xfce4-display-settings
x11: xdpyinfo, xprop, xrandr
Device-1: Intel 82801FB/FBM/FR/FW/FRW High Definition Audio vendor: SigmaTel
driver: snd_hda_intel v: kernel bus-ID: 00:05.0 chip-ID: 8086:2668
class-ID: 0403
API: ALSA v: k6.12.28-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.2 status: n/a (root, process) tools: pw-cli
Server-3: PulseAudio v: 17.0-43-g3e2bb status: active (root, process)
with: 1: pulseaudio-alsa type: plugin 2: pulseaudio-jack type: module
tools: pacat,pactl,pavucontrol
Device-1: Intel 82540EM Gigabit Ethernet driver: e1000 v: kernel port: d020
bus-ID: 00:03.0 chip-ID: 8086:100e class-ID: 0200
IF: enp0s3 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel 82371AB/EB/MB PIIX4 ACPI type: network bridge
driver: piix4_smbus v: N/A modules: i2c_piix4 port: N/A bus-ID: 00:07.0
chip-ID: 8086:7113 class-ID: 0680
Local Storage: total: 50 GiB used: 17.22 GiB (34.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: VirtualBox model: VBOX HARDDISK
size: 50 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: SSD serial: <filter> fw-rev: 1.0 scheme: MBR
Optical-1: /dev/sr0 vendor: VBOX model: CD-ROM rev: 1.0 dev-links: cdrom
Features: speed: 32 multisession: yes audio: yes dvd: yes rw: none
state: running
ID-1: / raw-size: 50 GiB size: 48.91 GiB (97.83%) used: 17.22 GiB (35.2%)
fs: ext4 block-size: 4096 B dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 1261871b-4569-42f3-9211-40baaf16a30b
ID-2: /media/sf_SHARED raw-size: N/A size: 462.32 GiB
used: 353.58 GiB (76.5%) fs: vboxsf remote: SHARED
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 8 rev: 2.0
Device-1: 1-1:2 info: VirtualBox USB Tablet type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 80ee:0021 class-ID: 0300
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
Src: lm-sensors+/sys Message: No sensor data found using /sys/class/hwmon
or lm-sensors.
Packages: 1377 pm: pacman pkgs: 1371 libs: 409 tools: pamac pm: flatpak
pkgs: 0 pm: snap pkgs: 6
1: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
2: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 193
1: cpu: 10.3% command: firefox pid: 1720 mem: 353.1 MiB (2.2%)
2: cpu: 9.4% command: firefox pid: 1496 mem: 527.1 MiB (3.2%)
3: cpu: 3.2% command: Xorg pid: 866 mem: 104.8 MiB (0.6%)
4: cpu: 1.2% command: firefox pid: 1634 mem: 226.2 MiB (1.4%)
5: cpu: 0.8% command: pulseaudio pid: 1118 mem: 31.7 MiB (0.1%)
Memory top: 5 of 193
1: mem: 527.1 MiB (3.2%) command: firefox pid: 1496 cpu: 9.4%
2: mem: 353.1 MiB (2.2%) command: firefox pid: 1720 cpu: 10.3%
3: mem: 226.2 MiB (1.4%) command: firefox pid: 1634 cpu: 1.2%
4: mem: 166.4 MiB (1.0%) command: firefox pid: 1579 cpu: 0.1%
5: mem: 122.6 MiB (0.7%) command: firefox pid: 1790 cpu: 0.0%
Processes: 193 Power: uptime: 24m states: freeze,mem,disk suspend: s2idle
wakeups: 0 hibernate: shutdown avail: reboot,suspend,test_resume
image: 6.24 GiB services: upowerd,xfce4-power-manager Init: systemd v: 257
Compilers: clang: 19.1.7 gcc: 15.1.1 Shell: Sudo (sudo) v: 1.9.16p2
default: Bash v: 5.2.37 running-in: xfce4-terminal inxi: 3.3.38
