During installation, I allowed 32 GB for Manjaro system /; actuall less than 1 GB is left free and almost once an hour a warning shows up. I Tried to understand the issue and found, that /var/cache/pacman/pkg takes about 7.9 GB.
I tried to reduce paccache, but this was already done:
$ paccache --remove --keep 2 --verbose
==> no candidate packages found for pruning
How can I solve this?
Thank you @Aragorn , the second proposal seems too difficult for myself. For the first one I had in mind
$ paccache --dryrun --keep 1 --verbose
==> finished dry run: 1286 candidates (disk space saved: 3.17 GiB)
Would this be OK?
But I would really like to understand the reason. After instalation, I could keep three paccache-versions.Only few additional software has been installed since then. So: What is eating the disk space?
inxi:
$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.15.85-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=3fb81935-3c2a-4b83-ae67-7b8f75e23839 rw text apparmor=1
security=apparmor resume=UUID=338139c5-0361-42c0-9573-dbd00f711a01
udev.log_priority=3 noplymouth acpi_backlight=none
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 20UH001QGE v: ThinkPad T14s Gen 1
Mobo: LENOVO model: 20UH001QGE v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: R1CET65W(1.34 ) date: 06/17/2021
ID-1: BAT0 charge: 17.8 Wh (38.0%) condition: 46.8/57.0 Wh (82.1%)
volts: 11.2 min: 11.5 model: SMP 5B10W139 type: Li-poly serial: <filter>
status: discharging cycles: 918
RAM: total: 30.59 GiB used: 4.13 GiB (13.5%)
Info: model: AMD Ryzen 7 PRO 4750U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1582 high: 2431 min/max: 1400/1700 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1637 2: 1530
3: 1538 4: 1610 5: 1347 6: 1301 7: 1340 8: 1366 9: 1561 10: 2209 11: 1329
12: 1352 13: 1292 14: 1327 15: 2157 16: 2431 bogomips: 54319
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5.1
code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1
bus-ID: 06:00.0 chip-ID: 1002:1636 class-ID: 0300 temp: 34.0 C
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 2-2:2 chip-ID: 13d3:5405 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x14f2 built: 2018
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81")
diag: 354mm (13.9") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: AMD Radeon Graphics (renoir LLVM
14.0.6 DRM 3.42 5.15.85-1-MANJARO) direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
bus-ID: 06:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x,snd_pci_acp5x
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 06:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 06:00.6
chip-ID: 1022:15e3 class-ID: 0403
Sound API: ALSA v: k5.15.85-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2400 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0f0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 6-4:3
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 1.82 TiB used: 1.14 TiB (62.5%)
model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 31.9 C scheme: GPT
ID-1: / raw-size: 32 GiB size: 31.2 GiB (97.50%) used: 28.85 GiB (92.5%)
fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: Manjaro
uuid: 3fb81935-3c2a-4b83-ae67-7b8f75e23839
used: 17.5 MiB (3.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: UEFI-ESP uuid: F8E8-132F
ID-3: /home raw-size: 32 GiB size: 31.2 GiB (97.50%)
used: 13.82 GiB (44.3%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
label: home uuid: 36be0edf-49c4-4ee0-96a3-4da6bc64a86c
ID-4: /home/<filter>/VirtualBoxVMs raw-size: 300 GiB
size: 294.23 GiB (98.08%) used: 152.14 GiB (51.7%) fs: ext4
dev: /dev/nvme0n1p5 maj-min: 259:5 label: Virtual
uuid: c29b5da5-b959-4989-87ed-6db493b9c3a0
ID-5: /mnt/Daten raw-size: 1.21 TiB size: 1.19 TiB (98.34%)
used: 969.44 GiB (79.9%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
label: Daten uuid: 249b9b5a-332c-4176-8a2e-9cef91138ce6
ID-1: swap-1 type: partition size: 64 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p2 maj-min: 259:2 label: Swap
uuid: 338139c5-0361-42c0-9573-dbd00f711a01
ID-1: /dev/nvme0n1p6 maj-min: 259:6 size: 200 GiB fs: ext4 label: TimeShift
uuid: ee73659c-5cf3-46d2-a7c8-29db485d1b85
Hub-1: 1-0:1 info: Full speed or root hub ports: 1 rev: 2.0 speed: 480 Mb/s
Hub-2: 2-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 2-2:2 info: IMC Networks Integrated Camera type: Video
driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-3: 3-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
Hub-4: 4-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 4-3:2 info: Alcor Micro AU9540 Smartcard Reader type: Smart Card
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 50mA
chip-ID: 058f:9540 class-ID: 0b00
Hub-5: 5-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-6: 6-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 6-3:5 info: Synaptics Prometheus MIS Touch Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 06cb:00bd class-ID: ff00 serial: <filter>
Device-2: 6-4:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-7: 7-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 35.0 C mobo: N/A gpu: amdgpu temp: 34.0 C
Fan Speeds (RPM): fan-1: 0
Processes: 356 Uptime: 22h 55m wakeups: 8 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1811 libs: 416 tools: pamac Shell: Bash v: 5.1.16
running-in: konsole inxi: 3.3.24
Filesystem is ext4
I don’t really see why; it contains the literal instructions.
That is for you to decide upon. It says that it would free 3.17 GiB of space, but you know that /var/cache/pacman/pkg takes up 7.9 GiB of space.
Packages grow as they evolve. Sometimes additional packages are being pushed out as well.
If you have any Snap and/or FlatPak packages installed, those use up a lot of space because they come bundled with all of the shared libraries used inside their container.
andreas85:
and :
Completely clean out the package cache.
sudo paccache -rvk0
Is there a way to add -d “dryrun” to this?
sudo paccache -dk0
-r removes the packages from the cache. -d shows you how much space would be freed if you remove the packages from the cache, without actually removing them. You cannot use -r and -d together.
Besides, you already know how much free space it will yield, because your /var/cache/pacman/pkg takes up 7.9 GiB of space.
The partitioning is not setup correctly.
eddier
26 December 2022 13:42
11
64GB for swap? Why so much?
In ancient times there was a rule to have twice as much swap as RAM
Today: swap == RAM (if you want to hibernate)
system
Closed
29 December 2022 04:41
13
