Hi, I have a small USB dongle for combined Wifi and Bluetooth. It’s based on the rtl8723b chip. Until recently it worked flawlessly (I never used Wifi, but Bluetooth worked). But now I can’t connect to paired devices and when scanning for new devices the adapter doesn’t find anything.
I did sudo dmesg |grep -i bluetooth and it retured this:
[ 78.347275] usb 3-1: Product: Edimax Wi-Fi N150 Bluetooth4.0 USB Adapter
[ 78.992609] Bluetooth: Core ver 2.22
[ 78.992653] NET: Registered PF_BLUETOOTH protocol family
[ 78.992655] Bluetooth: HCI device and connection manager initialized
[ 78.992660] Bluetooth: HCI socket layer initialized
[ 78.992663] Bluetooth: L2CAP socket layer initialized
[ 78.992668] Bluetooth: SCO socket layer initialized
[ 79.065629] Bluetooth: hci0: RTL: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
[ 79.066621] Bluetooth: hci0: RTL: rom_version status=0 version=1
[ 79.066625] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_fw.bin
[ 79.067148] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_config.bin
[ 79.067176] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
[ 79.067183] Bluetooth: hci0: RTL: cfg_sz -2, total sz 22496
[ 79.193353] usb 3-1: Product: Edimax Wi-Fi N150 Bluetooth4.0 USB Adapte
[ 79.500709] Bluetooth: hci0: RTL: fw version 0x0e2f9f73
[ 80.034743] audit: type=1130 audit(1651044394.638:129): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 80.046897] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 80.046900] Bluetooth: BNEP filters: protocol multicast
[ 80.046904] Bluetooth: BNEP socket layer initialized
[ 80.123233] Bluetooth: RFCOMM TTY layer initialized
[ 80.123241] Bluetooth: RFCOMM socket layer initialized
[ 80.123244] Bluetooth: RFCOMM ver 1.11
[ 167.089784] Bluetooth: hci0: Ignoring error of Inquiry Cancel command
The line Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2 seemed interesting and after some digging around I found this patch.
I’m currently on kernel 5.17.1-3-MANJARO using Gnome 41.5.
Does someone know a fix for this or do I have to wait for this patch to get merged?
Btw. I’m open to all feedback and if you need more information just ask ![]()
EDIT: Output of sudo inxi --admin --verbosity=7 --filter --no-host --width :
Kernel: 5.17.1-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
root=UUID=f8087e40-6565-4846-8ea8-48051499aa11 rw quiet splash apparmor=1
security=apparmor resume=UUID=b854067a-73bc-45be-9154-2c2239c94e05
udev.log_priority=3
Desktop: GNOME v: 41.5 tk: GTK v: 3.24.33 wm: gnome-shell dm: GDM v: 41.3
Type: Desktop Mobo: Gigabyte model: H81M-D2V serial: N/A
UEFI: American Megatrends v: F4 date: 05/07/2014
RAM: total: 7.62 GiB used: 2.61 GiB (34.3%)
Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
note: est.
Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 4 GiB
speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: Kingston part-no: KHX1600C10D3/8G serial: <filter>
Device-2: ChannelA-DIMM1 type: no module installed
Device-3: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 4 GiB
manufacturer: Kingston part-no: KHX1600C10D3/4G serial: <filter>
Device-4: ChannelB-DIMM1 type: no module installed
Info: model: Intel Core i3-4130 bits: 64 type: MT MCP arch: Haswell
family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 3394 high: 3395 min/max: 800/3400 base/boost: 3400/7000
scaling: driver: intel_cpufreq governor: schedutil volts: 1.0 V
ext-clock: 100 MHz cores: 1: 3393 2: 3393 3: 3395 4: 3395 bogomips: 27149
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
fsgsbase fxsr ht ibpb ibrs invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel 4th Generation Core Processor Family Integrated Graphics
vendor: Gigabyte driver: i915 v: kernel ports: active: VGA-1 empty: HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:041e class-ID: 0300
Device-2: NVIDIA GP107 [GeForce GTX 1050] vendor: ZOTAC driver: nvidia
v: 510.60.02 alternate: nouveau,nvidia_drm pcie: gen: 2 speed: 5 GT/s
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1c81 class-ID: 0300
Display: server: X.Org v: 1.21.1.3 with: Xwayland v: 22.1.1
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
unloaded: nouveau,vesa alternate: fbdev,nv gpu: i915 display-ID: :1
screens: 1
Screen-1: 0 s-res: 4000x1024 s-dpi: 96 s-size: 1058x271mm (41.65x10.67")
s-diag: 1092mm (43")
Monitor-1: DVI-D-0 pos: primary,left res: 1280x1024 hz: 60 dpi: 96
size: 338x270mm (13.31x10.63") diag: 433mm (17.03") modes: N/A
Monitor-2: HDMI-0 pos: primary,center res: 1440x900 hz: 60 dpi: 89
size: 410x256mm (16.14x10.08") diag: 483mm (19.03") modes: N/A
Monitor-3: VGA-1-1 pos: right res: 1280x1024 hz: 60 dpi: 96
size: 340x270mm (13.39x10.63") diag: 434mm (17.09") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1050/PCIe/SSE2
v: 4.6.0 NVIDIA 510.60.02 direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c
class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:8c20 class-ID: 0403
Device-3: NVIDIA GP107GL High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Sound Server-1: ALSA v: k5.17.1-3-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.49 running: yes
lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: wlp0s20u1i2 state: down mac: <filter>
Device-1: Edimax EW-7611ULB 802.11b/g/n and Bluetooth 4.0 Adapter type: USB
driver: btusb,rtl8xxxu bus-ID: 3-1:5 chip-ID: 7392:a611 class-ID: e001
serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: <filter>
Local Storage: total: 3.64 TiB used: 1.66 TiB (45.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDH3 1T00
type: SSD serial: <filter> rev: 00RL scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD20EZRZ-00Z5HB0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 0A80 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH16NS55 rev: 1.04
dev-links: cdrom
ID-1: / raw-size: 922.42 GiB size: 906.86 GiB (98.31%)
used: 593.19 GiB (65.4%) fs: ext4 block-size: 4096 B dev: /dev/sda2
maj-min: 8:2 label: N/A uuid: f8087e40-6565-4846-8ea8-48051499aa11
used: 288 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
label: NO_LABEL uuid: BF58-5DD7
ID-3: /run/media/daten/Daten raw-size: 1.82 TiB
size: 1.82 TiB (100.00%) used: 1.08 TiB (59.2%) fs: ntfs block-size: 4096 B
dev: /dev/sdb1 maj-min: 8:17 label: Daten uuid: 147A9C117A9BEDAC
dev: /dev/sda3 maj-min: 8:3 label: swap
uuid: b854067a-73bc-45be-9154-2c2239c94e05
ID-1: /dev/sdc1 maj-min: 8:33 size: 300 MiB fs: vfat label: N/A
uuid: F362-83D6
ID-2: /dev/sdc2 maj-min: 8:34 size: 16 GiB fs: swap label: N/A
uuid: 4ea9087f-f2d2-48b9-938e-3039162cfef7
ID-3: /dev/sdc3 maj-min: 8:35 size: 915.22 GiB fs: ext4 label: N/A
uuid: 44dc5ca1-5125-4814-a597-fbe2c6ff22ed
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 3-1:5
info: Edimax EW-7611ULB 802.11b/g/n and Bluetooth 4.0 Adapter
type: Bluetooth driver: btusb,rtl8xxxu interfaces: 3 rev: 2.1
speed: 480 Mb/s power: 500mA chip-ID: 7392:a611 class-ID: e001
serial: <filter>
Device-2: 3-8:2 info: Genesys Logic Multislot Card Reader/Writer
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 05e3:0716 class-ID: 0806
serial: <filter>
Device-3: 3-9:3 info: Logitech G910 Orion Spark Mechanical Keyboard
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 046d:c32b class-ID: 0300
serial: <filter>
Device-4: 3-10:4 info: Logitech G203 Gaming Mouse type: Mouse,HID
power: 300mA chip-ID: 046d:c084 class-ID: 0300 serial: <filter>
Hub-6: 4-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
Hub-7: 5-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-8: 5-1:2 info: VIA Labs Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 2109:3431 class-ID: 0900
Hub-9: 5-1.4:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0605 class-ID: 0900
Device-1: 5-1.4.1:4 info: Logitech F710 Wireless Gamepad [XInput Mode]
type: <vendor specific> driver: xpad interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c21f class-ID: ff00 serial: <filter>
Hub-10: 6-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 37 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 48%
Processes: 247 Uptime: 40m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1777 lib: 498
flatpak: 0 Shell: fish (sudo) v: 3.4.1 default: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.15
