Difficulty: ★★☆☆☆
Source: https://root.nix.dk/en/manjaro/install-nextcloud-on-raspberry-pi
NextCloud is an open-source collaboration tool which can be selfhosted.
Prerequisites
For this you need a server device - e.g. Raspberry Pi 4B using WiFi
This document was written using a Raspberry PI 4B 4GB using a 16GB microSD.
To install NextCloud you need to prepare the following components.
- Apache or Nginx
- PHP
- Sqlite or MariaDB
The most widely used setup is called LAMP and is an acronym for Linux, Apacke, MariaDB/MYSQL, PHP/Perl/Python.
Refer to the following document to setup your LAMP stack and return here when ready as this document assumes you have the phpMyAdmin webapp available on the system.
Important
Always ensure your system is up-to-date before adding new packages
sudo pacman -Syu
NextCloud requires any one of these locales to be enabled and generated
- en_US.UTF-8
- fr_FR.UTF-8
- es_ES.UTF-8
- de_DE.UTF-8
- ru_RU.UTF-8
- pt_BR.UTF-8
- it_IT.UTF-8
- ja_JP.UTF-8
- zh_CN.UTF-8
Ensure you have at least en_US.UTF-8 locale enabled and generated.
echo en_US.UTF-8 | sudo tee -a /etc/locale.gen
Generate locale
sudo locale-gen
Installing NextCloud
This document will focus on the Web installer provided as a NextCloud community project nonetheless you have the option to use the nextcloud package from the repo along with the extensive documentation at Nextcloud - ArchWiki
NextCloud Web installer
The Web installer https://download.nextcloud.com/server/installer/setup-nextcloud.php is a php script you download and place in the root of the web service.
If you followed the LAMP stack your http root lives at /srv/http.
Open a terminal and navigate to the http root folder
cd /srv/http
Use curl to fetch the script
sudo curl -O https://download.nextcloud.com/server/installer/setup-nextcloud.php
Best practice is to go over the content and ensure it is legit
less setup-nextcloud.php
NextCloud Setup Wizard
Before you open the web installer to start the NextCloud installer - ensure the required php packages has been synced
sudo pacman -S php-gd php-imagick php-intl
Depending on your actual requirements and the NextCloud features you want to make use of you will need to install other packages. A reference list can be viewed by visiting the Arch Community Repo package https://archlinux.org/packages/community/any/nextcloud/
The NextCloud developers recommend the use of MariaDB/MYSQL - but you can use sqlite for test and development. If you choose to use sqlite - you will need the php-sqlite package as well
sudo pacman -Syu php-sqlite
When you have installed the packages edit your system’s php.ini
sudo micro /etc/php/php.ini
Search and locate extension=bcmath or scroll down to the extensions list and enable
extension=bcmath
extension=bz2
extension=exif
extension=gd
extension=iconv
extension=imagick
extension=intl
extension=pdo_mysql
extension=pdo_sqlite
Search and locate memory_limit
memory_limit = 512M
Search and locate date.timezone, uncomment and set it to your timezone e.g.
date.timezone = Europe/Copenhagen
Save the file and close it then restart your http service
sudo systemctl restart httpd
Ensure the http user is set as owner of the /srv/http folder and content.
sudo chown http:http /srv/http -R
Load the installer in your browser by navigating to your server’s ip or name
http://ip.x.y.z/setup-nextcloud.php
When you click the Next button dependencies are verified and if they are found click Next to install in a subfolder named nextcloud. Replace nextcloud with a . if you want NextCloud in the root of the webserver.
Be patient - after a while you will be greeted with a Success message - click Next.
Setting up database
This document is only intended to wet your feet so SQLite may be just fine but for production you should use MariaDB. For production use you should refer to the NextCloud documentation
To create a database for your nextcloud app we will use phpMyAdmin. Navigate your browser to the web server’s phpmyadmin url
http://ip.x.y.z/phpmyadmin
Login using your mariadb root user and the password created earlier.
- Click the User accounts tab, then Add user account
- Click the button next Generate password labelled Generate
- Copy the password from the textbox and paste it somewhere convenient
- Tick the box next to Create database with same name and grant all privileges
- Scroll to the bottom and click Go
Go back to the NextCloud database setup page
- Fill in your desired administrative username
- Create a strong password
- Click the Storage & Database dropdown and select MySQL/MariaDB
- Fill in database user nextcloud
- Fill in database passwd - copy/paste the passwd created above
- Fill in the database name nextcloud
- Don’t change the host
- Click Install - have patience
- The script redirects to an apps page - which may return 404 - ignore it and open the root url address for your NextCloud instance.
Navigate to your own nextcloud address
http://ip.x.y.z/nextcloud
You are almost done
The rest is up to you - please remember to ensure your MariaDB engine is configured as recommended at NextCloud documetnation
