will to that today at some point and post when I can! it is a bit of a full day today! keep the ideas coming!
Same here. First things first, do that command from yesterday, and edit parameters in grub. And ignore that initramfs editing, I wasâŚwell I wasnât thinking. .P
Sorry for the delay but I couldnât make more tests until today. Here is the output of the command you suggested:
# diff <(lsinitcpio -a /boot/initramfs-5.18-x86_64.img) <(lsinitcpio -a /boot/initramfs-5.17-x86_64.img)
1c1
< ==> Image: /boot/initramfs-5.18-x86_64.img
> ==> Image: /boot/initramfs-5.17-x86_64.img
3,4c3,4
< ==> Kernel: 5.18.5-1-MANJARO
< ==> Size: 8.66 MiB
> ==> Kernel: 5.17.15-1-MANJARO
> ==> Size: 8.42 MiB
6,7c6,7
< -> Uncompressed size: 22.62 MiB (.383 ratio)
< -> Estimated decompression time: 0.120s
> -> Uncompressed size: 21.71 MiB (.387 ratio)
> -> Estimated decompression time: 0.117s
10,13c10,13
< cdrom crc-itu-t irqbypass mmc_core uas vfio_iommu_type1 [explicit] virtio_blk
< crc16 ext4 jbd2 nvme-core usbhid vfio-pci-core xhci-pci
< crc32c_generic firewire-core mbcache nvme [explicit] usb-storage vfio-pci [explicit] xhci-pci-renesas
< crc32c-intel firewire-sbp2 mmc_block sr_mod vfio [explicit] vfio_virqfd [explicit]
> cdrom crc-itu-t irqbypass mmc_core usb-storage vfio-pci [explicit] xhci-pci-renesas
> crc16 ext4 jbd2 sr_mod vfio [explicit] vfio_virqfd [explicit]
> crc32c_generic firewire-core mbcache uas vfio_iommu_type1 [explicit] virtio_blk
> crc32c-intel firewire-sbp2 mmc_block usbhid vfio-pci-core xhci-pci
I am trying with the iommu and the rest turned off now and report back.
Success! I have tried to boot 5.18 without the extra commands like you suggested and it worked! Then I added them one by one and figured out that one with the problem is: vfio_pci.ids=1002:67df,1002:aaf0,2646:2263
. I donât know why that is but without this works!
That command is supposed to stop the system from loading the drivers for that particular video card which is passed through to the qemu VM.
In any case the main problem is solved now! I should have tried your suggestion from the beginning! Thank you for your patience!
