Restarting and shut down taking too much time.
My kernel Linux 510
I’ve already set lvmetad=0
And DefaultTimeout =05s
Dumpcore = no
But still the same…
My kernel Linux 510
Dumpcore = no
But still the same…
Hi Rhmerin,
I probably can’t help you, and for others to help you there needs to be more specifics to get some input for your issue. A good start would be to include some of the relevant output of some of the commands in this post A comparison of the time and what constitutes to much for you would also be helpful.
Can you please tell me what kind of things??
Thanks in advance.
Read this please, you could start with the output of
$ sudo inxi -Fazy
Maybe the output of the errors in the journal starting from the last boot?
journalctl --boot=-1 --priority=err
Is there any output that could point to a cause in:
$ sudo dmesg -l emerg,alert,crit,err,warn
Why have you set these options and where have you set them? Are you using LVM? (since a quick google leads me to think this is a specific setting if you use LVM )
What is to much time to shutdown and restart? Eg it used to take 10 seconds to shutdown, now it takes 2 minutes.
sudo inxi -Fazy
Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=3c89c311-afd7-4fa8-8a9a-98b65dd2877c rw quiet apparmor=1
security=apparmor resume=UUID=e1fa377e-7cad-47c9-92d8-9aae984753fa
udev.log_priority=3
Console: tty 2 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
Type: Desktop Mobo: MSI model: H81M-E33 (MS-7817) v: 1.0 serial:
UEFI: American Megatrends v: 6.8 date: 07/17/2018
Info: Dual Core model: Intel Core i3-4150 socket: BGA1155 bits: 64
type: MT MCP arch: Haswell family: 6 model-id: 3C (60) stepping: 3
microcode: 28 L1 cache: 128 KiB L2 cache: 3 MiB L3 cache: 2.9 MiB
bogomips: 28012
Speed: 810 MHz min/max: 800/3500 MHz base/boost: 3500/3800 volts: 1.2 V
ext-clock: 100 MHz Core speeds (MHz): 1: 810 2: 1126 3: 1062 4: 820
Type: l1tf
Device-1: AMD Cedar [Radeon HD 5000/6000/7350/8350 Series] vendor: Gigabyte
driver: radeon v: kernel bus ID: 01:00.0 chip ID: 1002:68f9
Display: server: X.Org 1.20.10 compositor: kwin_x11 driver: ati,radeon
unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: VGA-0 res: 1366x768 hz: 60 dpi: 85 size: 410x230mm (16.1x9.1")
diag: 470mm (18.5")
OpenGL: renderer: AMD CEDAR (DRM 2.50.0 / 5.10.2-2-MANJARO LLVM 11.0.0)
v: 3.3 Mesa 20.3.1 compat-v: 3.1 direct render: Yes
Device-1: Intel 8 Series/C220 Series High Definition Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:8c20
Device-2: AMD Cedar HDMI Audio [Radeon HD 5400/6300/7300 Series]
vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 01:00.1
chip ID: 1002:aa68
Sound Server: ALSA v: k5.10.2-2-MANJARO
vendor: Micro-Star MSI driver: r8169 v: kernel port: d000 bus ID: 03:00.0
chip ID: 10ec:8168
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac:
Local Storage: total: 1.05 TiB used: 351.89 GiB (32.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS120G2G0A-00JH30 family: WD Blue and Green SSDs size: 111.8 GiB
block size: physical: 512 B logical: 512 B sata: 3.2 speed: 6.0 Gb/s
serial: rev: 0000 temp: 29 C
SMART: yes state: enabled health: PASSED on: 91d 0h cycles: 2053
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10EZEX-00BN5A0
family: Blue size: 931.51 GiB block size: physical: 4096 B logical: 512 B
sata: 3.1 speed: 6.0 Gb/s rotation: 7200 rpm serial: rev: 1A01
temp: 30 C
SMART: yes state: enabled health: PASSED on: 342d 12h cycles: 5637
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Toshiba model: TransMemory-Mx
size: 28.83 GiB block size: physical: 512 B logical: 512 B serial:
rev: PMAP
ID-1: / raw size: 102.7 GiB size: 100.59 GiB (97.94%)
used: 14.32 GiB (14.2%) fs: ext4 block size: 4096 B dev: /dev/sda2
maj-min: 8:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat block size: 512 B dev: /dev/sda1 maj-min: 8:1
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: radeon temp: 39.5 C
Processes: 201 Uptime: 39m wakeups: 0 Memory: 7.72 GiB
used: 1.96 GiB (25.4%) Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages:
pacman: 1325 lib: 405 flatpak: 0 Shell: Zsh (sudo) v: 5.8 default: Bash
v: 5.1.0 running in: konsole inxi: 3.2.01
#19 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#20 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#21 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#22 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#23 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#24 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#25 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#26 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#27 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#28 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#29 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#30 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#31 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#32 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#33 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#34 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#35 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#36 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#37 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#38 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#39 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#40 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#41 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#42 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#43 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#44 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#45 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#46 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#47 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#48 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#49 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#50 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#51 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#52 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#53 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#54 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#55 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#56 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#57 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#58 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#59 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#60 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#61 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#62 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
#63 0x00007f5a01d55557 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyE>
Stack trace of thread 924:
#0 0x00007f5a013e046f __poll (libc.so.6 + 0xf546f)
#1 0x00007f5a000a293f n/a (libglib-2.0.so.0 + 0xa693f)
#2 0x00007f5a0004d2b1 g_main_context_iteration (libglib-2.0.so.0 + 0x512b1)
#3 0x00007f5a01ae56e1 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17Pr>
#4 0x00007f5a01a8b3fc _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.>
#5 0x00007f5a01a93894 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x2bc894)
#6 0x000055ace584d2b4 n/a (baloo_file + 0xd2b4)
#7 0x00007f5a01313152 __libc_start_main (libc.so.6 + 0x28152)
#8 0x000055ace584d4be n/a (baloo_file + 0xd4be)
Stack trace of thread 933:
#5 0x00007f5a018a3d22 _ZN7QThread4execEv (libQt5Core.so.5 + 0xccd22)
#6 0x00007f5a01d79098 n/a (libQt5DBus.so.5 + 0x17098)
#7 0x00007f5a018a4f0f n/a (libQt5Core.so.5 + 0xcdf0f)
#8 0x00007f5a008db3e9 start_thread (libpthread.so.0 + 0x93e9)
#9 0x00007f5a013eb293 __clone (libc.so.6 + 0x100293)
Stack trace of thread 938:
#0 0x00007f5a013e2c96 pselect (libc.so.6 + 0xf7c96)
#1 0x00007f59ffaf9524 n/a (libusbmuxd-2.0.so.6 + 0x2524)
#2 0x00007f59ffafa8a9 n/a (libusbmuxd-2.0.so.6 + 0x38a9)
#3 0x00007f5a008db3e9 start_thread (libpthread.so.0 + 0x93e9)
#4 0x00007f5a013eb293 __clone (libc.so.6 + 0x100293)
Jan 08 03:22:38 merin pulseaudio[953]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org>
Jan 08 03:22:39 merin systemd-coredump[1171]: Failed to send coredump datagram: Connection reset by peer
