I tried to upgrade system using pacman:
sudo pacman -Syu
and it failed because of some conflicts:
warning: deepin-desktop-base: local (3:2019.07.10-1) is newer than community (2:2021.5.07-1)
warning: deepin-wallpapers: local (2:1.7.7-1) is newer than community (1:1.7.7-2)
:: Replace lib32-libcanberra-pulse with multilib/lib32-libcanberra? [Y/n]
:: Replace libcanberra-pulse with extra/libcanberra? [Y/n]
warning: pamac-cli: local (10.1.2-0.1) is newer than extra (10.0.6-2)
warning: pamac-common: local (10.1.2-0.1) is newer than extra (10.0.6-2)
warning: pamac-gtk: local (10.1.2-0.1) is newer than extra (10.0.6-2)
:: Replace python-dbus with extra/dbus-python? [Y/n] n
:: Replace python-dbus-common with extra/dbus-python? [Y/n] n
:: Replace qca with extra/qca-qt5? [Y/n]
resolving dependencies...
:: installing lib32-libcanberra (0.30+2+gc0620e4-4) breaks dependency 'lib32-libcanberra=0.30+2+gc0620e4-3' required by lib32-libcanberra-gstreamer
:: installing libcanberra (0.30+2+gc0620e4-4) breaks dependency 'libcanberra=0.30+2+gc0620e4-3' required by libcanberra-gstreamer
I searched and found out just below packages are dependent on libcanberra-*
and python-dbus-*
- gespeaker
- oblogout
- libcanberra-gstreamer
- lib32-libcanberra-gstreamer
And since no other packages had these 4 packages as their dependency and also I don’t need them, So I decided to remove them and their dependencies completely:
sudo pacman -Rns oblogout gespeaker libcanberra-gstreamer lib32-libcanberra-gstreamer
Now I am sure there is no more conflicts but when I try to upgrade my system, pacman
still asks me to replace the removed packages :
$ sudo pacman -Syu
core is up to date
extra is up to date
community is up to date
multilib is up to date
::Starting full system upgrade...
My problem: There is no python-dbus
installed on my system but why pacman
still asks me to replace it? How can I tell pacman
there is no package to replace? Should I press ‘Y’ or ‘N’ while I don’t want them to be installed on my system again?
