I want to resize my encrypted btrfs root partition to be able to also install Windows 11 alongside Manjaro.
Is there any easy way to do this? I have seen forum posts about this, but all of them involve backing up and restoring data.
inxi --admin --verbosity=7 --filter --width ✔
Kernel: 6.0.8-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.0-x86_64
root=UUID=4ee418e8-ca35-4a5f-9a96-1eb3cf16f3b0 rw rootflags=subvol=@ rhgb
quiet mitigations=off "acpi_osi=Windows 2022" quiet
cryptdevice=UUID=9a915a82-f1ac-4fda-a713-befca1c3f997:luks-9a915a82-f1ac-4fda-a713-befca1c3f997
root=/dev/mapper/luks-9a915a82-f1ac-4fda-a713-befca1c3f997
udev.log_priority=3 loglevel=0 udev.log_level=3 nowatchdog nmi_watchdog=0
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 wm: kwin_wayland vt: 2
Type: Laptop System: HP product: HP Laptop 15s-eq2xxx v: N/A
Mobo: HP model: 887A v: 59.20 serial: <superuser required> UEFI: AMI
v: F.26 date: 08/29/2022
ID-1: BAT0 charge: 34.1 Wh (80.2%) condition: 42.5/42.5 Wh (100.0%)
volts: 12.1 min: 11.3 model: HP Primary type: Li-ion serial: <filter>
status: discharging
RAM: total: 14.96 GiB used: 6.62 GiB (44.3%)
Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608103
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1399 high: 1400 min/max: 1400/4056 boost: disabled
scaling: driver: acpi-cpufreq governor: powersave cores: 1: 1400 2: 1400
3: 1400 4: 1399 5: 1400 6: 1397 7: 1397 8: 1400 9: 1400 10: 1400 11: 1395
12: 1400 bogomips: 50325
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: retbleed status: Vulnerable
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
usercopy barriers only; no swapgs barriers
Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled,
PBRSB-eIBRS: Not affected
Device-1: AMD Lucienne vendor: Hewlett-Packard driver: amdgpu v: kernel
arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:164c
class-ID: 0300 temp: 32.0 C
Device-2: Chicony HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 1-3:2 chip-ID: 04f2:b6f1 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.5
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 res: 1476x830 size: N/A modes: N/A
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: AMD Radeon Graphics (renoir LLVM
14.0.6 DRM 3.48 6.0.8-1-MANJARO) direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
driver: snd_rn_pci_acp3x v: kernel
alternate: snd_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_rpl_pci_acp6x,snd_sof_amd_renoir
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound API: ALSA v: k6.0.8-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.59 running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 01:00.0
chip-ID: 10ec:c821 class-ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-4:3 chip-ID: 0bda:b00e class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 6 state: up address: see --recommends
Device-1: luks-9a915a82-f1ac-4fda-a713-befca1c3f997 maj-min: 254:0
type: LUKS dm: dm-0 size: 931.21 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 931.22 GiB
Local Storage: total: 931.51 GiB used: 362.48 GiB (38.9%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 38.9 C scheme: GPT
ID-1: / raw-size: 931.21 GiB size: 731.02 GiB (78.50%)
used: 362.18 GiB (49.5%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-9a915a82-f1ac-4fda-a713-befca1c3f997 label: N/A
uuid: 4ee418e8-ca35-4a5f-9a96-1eb3cf16f3b0
used: 299.4 MiB (100.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 90B7-5322
ID-3: /home raw-size: 931.21 GiB size: 731.02 GiB (78.50%)
ID-4: /var/cache raw-size: 931.21 GiB size: 731.02 GiB (78.50%)
ID-5: /var/log raw-size: 931.21 GiB size: 731.02 GiB (78.50%)
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-2: 1-2:10 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2817 class-ID: 0900
Device-1: 1-2.2:11 info: USB OPTICAL MOUSE type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 30fa:0400 class-ID: 0301
Device-2: 1-3:2 info: Chicony HP TrueVision HD Camera type: Video
Device-3: 1-4:3 info: Realtek Bluetooth Radio type: Bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA chip-ID: 0bda:b00e
Hub-3: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-4: 2-2:5 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.2 speed: 5 Gb/s
chip-ID: 2109:0817 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-6: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 33.5 C mobo: N/A gpu: amdgpu temp: 32.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 0
Processes: 420 Uptime: 1d 13h 25m wakeups: 9009 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: 1668 pm: nix-default pkgs: 47 pm: nix-sys pkgs: 0 pm: nix-usr
pkgs: 2 pm: pacman pkgs: 1616 libs: 444 tools: pamac pm: flatpak pkgs: 3
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.23
