Bus 001 Device 008: ID 050d:0013 Belkin Components F8T013 Bluetooth Adapter
Is the device, and it’s the first time I’ve tried to use any bluetooth device on this Manjaro Gnome desktop computer (system info below).
I’ve checked bluez and blueman are installed and worked through this guide: How to Troubleshoot Bluetooth in Manjaro but can’t get further than this:
[nick@nick-pc-3 ~]$ sudo rfkill list
[sudo] password for nick:
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
[nick@nick-pc-3 ~]$ sudo systemctl status bluetooth
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor>
Active: active (running) since Fri 2022-01-07 09:24:03 CET; 1h 4min ago
Docs: man:bluetoothd(8)
Main PID: 53969 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 19017)
Memory: 2.0M
CPU: 13ms
CGroup: /system.slice/bluetooth.service
└─53969 /usr/lib/bluetooth/bluetoothd
Jan 07 09:24:03 nick-pc-3 systemd[1]: Starting Bluetooth service...
Jan 07 09:24:03 nick-pc-3 bluetoothd[53969]: Bluetooth daemon 5.62
Jan 07 09:24:03 nick-pc-3 systemd[1]: Started Bluetooth service.
Jan 07 09:24:03 nick-pc-3 bluetoothd[53969]: Starting SDP server
Jan 07 09:24:03 nick-pc-3 bluetoothd[53969]: src/rfkill.c:rfkill_init() Failed >
Jan 07 09:24:03 nick-pc-3 bluetoothd[53969]: Bluetooth management interface 1.1>
lines 1-18/18 (END)
as I don’t fully understand the output, in particular the “failed” line.
When I first plug the adapter in, a bluetooth icon with a red cross appears on my top indicator bar and when I right-click and choose “Start bluetooth” from the drop-down menu, the icon vanishes. (The blue light remains on on the usb adapter.)
When I go into the Bluetooth section of “Settings” it tells me “Bluetooth Turned Off” but the on-off toggle button on the top bar appears to be malfunctioning as even though in the “On” position (to the right) it still says “Bluetooth Turned Off” in the central area and when I toggle the button to the left it turns on “Aeroplane Mode”.
How should I troubleshoot this issue and get Bluetooth working correctly with this adapter?
System info:
[nick@nick-pc-3 ~]$ inxi --admin --verbosity=7 --filter --width
Kernel: 5.10.89-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=57cffb90-5793-4e09-a6e1-47090124a251 rw quiet
resume=UUID=9eccf73c-846e-41c2-9df8-92166a2a4579
Desktop: GNOME 41.2 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.0
Type: Desktop Mobo: ASUSTeK model: PRIME Z370-A v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 0606
date: 12/12/2017
RAM: total: 15.5 GiB used: 3.3 GiB (21.3%)
RAM Report:
unknown-error: Unknown dmidecode error. Unable to generate data.
Info: model: Intel Core i7-8700 bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEA
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 799 high: 800 min/max: 800/4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 799 8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 76831
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp
hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good rtm sdbg sep
smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: Intel CometLake-S GT2 [UHD Graphics 630] vendor: ASUSTeK
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e92 class-ID: 0380
Device-2: NVIDIA GP107 [GeForce GTX 1050 Ti] driver: nvidia v: 495.44
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1c82
class-ID: 0300
Device-3: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-5.4.1:6 chip-ID: 046d:082d
class-ID: 0102 serial: <filter>
Display: x11 server: X.org 1.21.1.2 compositor: gnome-shell driver:
loaded: nvidia resolution: <missing: xdpyinfo>
Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Sound Server-1: ALSA v: k5.10.89-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: no
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Belkin F8T013 Bluetooth Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-12:8 chip-ID: 050d:0013 class-ID: fe01
Report: bt-adapter ID: hci0 rfk-id: 1 state: up address: N/A
Local Storage: total: 1.38 TiB used: 780.73 GiB (55.4%)
model: MZVKW512HMJP-00000 size: 476.94 GiB block-size: physical: 512 B
rev: CXA7500Q temp: 44.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 37.9 C scheme: GPT
ID-1: / raw-size: 459.55 GiB size: 451.34 GiB (98.21%)
used: 227.25 GiB (50.3%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2 label: N/A uuid: 57cffb90-5793-4e09-a6e1-47090124a251
used: 264 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: 12D3-6A4D
ID-3: /run/media/nick/Data raw-size: 931.51 GiB size: 915.89 GiB (98.32%)
used: 553.48 GiB (60.4%) fs: ext4 block-size: 4096 B dev: /dev/nvme1n1p1
maj-min: 259:5 label: Data uuid: d7449928-d30a-4479-bb48-f02d4213b325
ID-1: swap-1 type: partition size: 17.09 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 9eccf73c-846e-41c2-9df8-92166a2a4579
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Hub-2: 1-5:2 info: NEC HighSpeed Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 0409:005a class-ID: 0900
Hub-3: 1-5.4:4 info: NEC HighSpeed Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-5.4.1:6 info: Logitech HD Pro Webcam C920 type: Video,Audio
power: 500mA chip-ID: 046d:082d class-ID: 0102 serial: <filter>
Device-2: 1-12:8 info: Belkin F8T013 Bluetooth Adapter type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s power: 100mA
Device-3: 1-13:3 info: Jing-Mold Enterprise USB Keyboard
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 100mA chip-ID: 05af:8277 class-ID: 0301
Device-4: 1-14:5 info: Microsoft IntelliMouse Optical type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 045e:0029 class-ID: 0301
Hub-4: 2-0:1 info: Super-speed hub ports: 10 rev: 3.0 speed: 5 Gb/s
Device-1: 2-2:2 info: SanDisk Ultra Dual type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 896mA
chip-ID: 0781:5590 class-ID: 0806 serial: <filter>
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 42 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 20%
Processes: 363 Uptime: 1h 6m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 2027 pacman: 2010 lib: 468
flatpak: 0 snap: 17 Shell: Bash v: 5.1.12 running-in: gnome-terminal
inxi: 3.3.11
[nick@nick-pc-3 ~]$
