Hello, i couldn’t find any ultrawide manjaro wallpapers, so i thought i would make a request, maybe somebody has the time and joy in making some? I really love the manjaro-cat, but it is just in a too small resolution for my new monitor to look glorious as it could be #firstworldproblems
Or maybe someone has a link to the original sources for the manjaro wallpapers, and i could render them myself i guess (assuming they are some sort of render files)
Yes i have, but i haven’t seen 21:9 wallpapers. The problem with the 16:9 ones is, that either the resolution gets poor, because you have to zoom in to fit to width, an therefore you loose pixels in the height, or content gets cut from the top and bottom, and they don’t look as originally intended anymore.
That is not a good idea in my opinion, because 1. it will distort the image and 2. it would still be horror for the sharpness because it would just bloat the pixels.
That one is the creation of @muser that seems no longer activates around. You will have to ask permission to make a different iteration of that wallpaper.
