I changed my Graphics driver from Nvidia to Video-Linux by using the GUI Manjaro Settings Manager. But the Nvidia Drivers are still installed. I did put a # in the right file and reboot.
Typing in mhwd -li -d --pci I got:
ATTACHED: PCI
VERSION: 2018.05.04
INFO: Standard open source drivers.
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300 0380 0302
VENDORIDS: 1002 8086 10de
ATTACHED: PCI
VERSION: 2020.11.30
INFO: Closed source NVIDIA drivers for linux.
PRIORITY: 4
FREEDRIVER: false
DEPENDS: -
CONFLICTS: video*nvidia*
CLASSIDS: 0300 0302
VENDORIDS: 10de
With inxi -G This:
Device-1: NVIDIA GK104 [GeForce GTX 760] driver: nvidia v: 460.56
Display: server: X.Org 1.20.10 driver: loaded: nvidia unloaded: nouveau
resolution: 2560x1600~60Hz
OpenGL: renderer: GeForce GTX 760/PCIe/SSE2 v: 4.6.0 NVIDIA 460.56
So which driver is in use? I’m having a Issue with Games that started with my GTX 970 and that was solved by putting back my GTX 760. Now that Card doing the same thing.
The Display Signal keeps getting lost when playing a game. However those that don’t use 3D work fine, but I had to set Fallout Classic to 1024x768 from 2560x1600 to prevent this. Fallout 2 Classic is doing the same thing with no way to set the Resolution.
I’m about to remove the video card and use the Intel 4600 iGPU on my Haswell i5.
