Hi,
I think have been dumb, again.
I installed via Pamac xdg-utils-terminal-true-git to try to resolve an issue with PIA update requesting a terminal compatible with x-terminal-emulator after reading this
It didn’t work so I uninstalled xdg-utils-terminal-true-git but was horrified to watch loads of other things being uninstalled
The log is below
Is there an easy way to get back to the state before my mishap?
Thanks
[2020-12-17T08:21:38+0000] [ALPM] removed xdg-utils (1.1.3+19+g9816ebb-1)
[2020-12-17T08:21:38+0000] [ALPM] installed xdg-utils-terminal-true-git (r772.4aa0178-1)
[2020-12-17T08:21:38+0000] [ALPM] transaction completed
[2020-12-17T08:21:38+0000] [ALPM] running '30-systemd-update.hook'...
[2020-12-17T08:22:58+0000] [ALPM] running 'gconf-remove.hook'...
[2020-12-17T08:22:58+0000] [ALPM] transaction started
[2020-12-17T08:22:59+0000] [ALPM] removed kio (5.76.0-1)
[2020-12-17T08:23:00+0000] [ALPM] removed kvantum-manjaro (0.13.5-1)
[2020-12-17T08:23:00+0000] [ALPM] removed qt5-websockets (5.15.2-1)
[2020-12-17T08:23:00+0000] [ALPM] removed beanshell (2.0b6-3)
[2020-12-17T08:23:01+0000] [ALPM] removed kwallet (5.76.0-1)
[2020-12-17T08:23:01+0000] [ALPM] removed knotifications (5.76.0-1)
[2020-12-17T08:23:01+0000] [ALPM] removed libdbusmenu-qt5 (0.9.3+16.04.20160218-5)
[2020-12-17T08:23:01+0000] [ALPM] removed qt5-webkit (5.212.0alpha4-8)
[2020-12-17T08:23:01+0000] [ALPM] removed phonon-qt4 (4.10.3-1)
[2020-12-17T08:23:02+0000] [ALPM] removed mcomix-git (r1495.486f02e-1)
[2020-12-17T08:23:40+0000] [ALPM] removed qt5-wayland (5.15.2-1)
[2020-12-17T08:23:40+0000] [ALPM] removed solid (5.76.0-1)
[2020-12-17T08:23:41+0000] [ALPM] removed gramps (2:5.1.3-1)
[2020-12-17T08:23:42+0000] [ALPM] removed calibre (5.6.0-1)
[2020-12-17T08:23:42+0000] [ALPM] removed python-pyqtwebengine (5.15.2-1)
[2020-12-17T08:23:42+0000] [ALPM] removed catfish (1.4.13-3)
[2020-12-17T08:23:43+0000] [ALPM] removed qt5-script (5.15.2-1)
[2020-12-17T08:23:43+0000] [ALPM] removed menulibre (2.2.1-2)
[2020-12-17T08:23:44+0000] [ALPM] removed filezilla (3.46.3-1)
[2020-12-17T08:23:44+0000] [ALPM] removed qpdfview (0.4.18-2)
[2020-12-17T08:23:44+0000] [ALPM] removed kid3-qt (3.8.4-1)
[2020-12-17T08:23:44+0000] [ALPM] removed kjobwidgets (5.76.0-1)
[2020-12-17T08:23:44+0000] [ALPM] removed ktextwidgets (5.76.0-1)
[2020-12-17T08:23:44+0000] [ALPM] removed kcompletion (5.76.0-1)
[2020-12-17T08:23:44+0000] [ALPM] removed sonnet (5.76.0-1)
[2020-12-17T08:23:44+0000] [ALPM] removed jdk8-openjdk (8.u265-1)
[2020-12-17T08:23:45+0000] [ALPM] removed jre8-openjdk (8.u265-1)
[2020-12-17T08:23:45+0000] [ALPM] removed kid3-common (3.8.4-1)
[2020-12-17T08:23:45+0000] [ALPM] removed qt5-tools (5.15.2-1)
[2020-12-17T08:23:45+0000] [ALPM] removed kbookmarks (5.76.0-1)
[2020-12-17T08:23:45+0000] [ALPM] removed kxmlgui (5.76.0-1)
[2020-12-17T08:23:45+0000] [ALPM] removed kglobalaccel (5.76.0-1)
[2020-12-17T08:23:45+0000] [ALPM] removed kiconthemes (5.76.0-1)
[2020-12-17T08:23:45+0000] [ALPM] removed kitemviews (5.76.0-1)
[2020-12-17T08:23:45+0000] [ALPM] removed kconfigwidgets (5.76.0-1)
[2020-12-17T08:23:45+0000] [ALPM] removed kwidgetsaddons (5.76.0-1)
[2020-12-17T08:23:45+0000] [ALPM] removed kguiaddons (5.76.0-1)
[2020-12-17T08:23:45+0000] [ALPM] removed kcodecs (5.76.0-1)
[2020-12-17T08:23:45+0000] [ALPM] removed qt5-translations (5.15.2-1)
[2020-12-17T08:23:45+0000] [ALPM] removed barrier (2.3.3-1)
[2020-12-17T08:23:46+0000] [ALPM] removed qt5-sensors (5.15.2-1)
[2020-12-17T08:23:46+0000] [ALPM] removed manjaro-settings-manager-notifier (0.5.6-10)
[2020-12-17T08:23:46+0000] [ALPM] removed manjaro-settings-manager (0.5.6-10)
[2020-12-17T08:23:46+0000] [ALPM] removed kauth (5.76.0-1)
[2020-12-17T08:23:46+0000] [ALPM] removed polkit-qt5 (0.113.0-2)
[2020-12-17T08:23:46+0000] [ALPM] removed kitemmodels (5.76.0-1)
[2020-12-17T08:23:46+0000] [ALPM] removed manjaro-xfce-settings (20200811-1)
[2020-12-17T08:23:46+0000] [ALPM] removed qt5ct (1.1-1)
[2020-12-17T08:23:46+0000] [ALPM] removed qt5-styleplugins (5.0.0.20170311-25)
[2020-12-17T08:23:46+0000] [ALPM] removed attica (5.76.0-1)
[2020-12-17T08:23:46+0000] [ALPM] removed poppler-qt5 (20.10.0-1)
[2020-12-17T08:23:47+0000] [ALPM] removed kded (5.76.0-1)
[2020-12-17T08:23:47+0000] [ALPM] removed kservice (5.76.0-1)
[2020-12-17T08:23:47+0000] [ALPM] removed kcrash (5.76.0-1)
[2020-12-17T08:23:47+0000] [ALPM] removed kdbusaddons (5.76.0-1)
[2020-12-17T08:23:47+0000] [ALPM] removed kconfig (5.76.0-1)
[2020-12-17T08:23:47+0000] [ALPM] removed qt5-xmlpatterns (5.15.2-1)
[2020-12-17T08:23:47+0000] [ALPM] removed manjaro-pulse (20200126-1)
[2020-12-17T08:23:47+0000] [ALPM] removed pulseaudio-equalizer (14.0-1)
[2020-12-17T08:23:47+0000] [ALPM] removed python-pyqt5 (5.15.2-1)
[2020-12-17T08:23:47+0000] [ALPM] removed python2-pyqt4 (4.12.3-4)
[2020-12-17T08:23:47+0000] [ALPM] removed pyqt4-common (4.12.3-4)
[2020-12-17T08:23:48+0000] [ALPM] removed qt4 (4.8.7-29.1)
[2020-12-17T08:23:48+0000] [ALPM] removed karchive (5.76.0-1)
[2020-12-17T08:23:48+0000] [ALPM] removed qt5-speech (5.15.2-1)
[2020-12-17T08:23:48+0000] [ALPM] removed ki18n (5.76.0-1)
[2020-12-17T08:23:48+0000] [ALPM] removed vlc (3.0.11.1-6)
[2020-12-17T08:23:49+0000] [ALPM] removed kvantum-theme-matchama (20191118-1)
[2020-12-17T08:23:49+0000] [ALPM] removed kvantum-qt5 (0.17.0-1)
[2020-12-17T08:23:49+0000] [ALPM] removed kwindowsystem (5.76.0-1)
[2020-12-17T08:23:49+0000] [ALPM] removed qt5-svg (5.15.2-1)
[2020-12-17T08:23:49+0000] [ALPM] removed qt5-multimedia (5.15.2-1)
[2020-12-17T08:23:49+0000] [ALPM] removed kcoreaddons (5.76.0-1)
[2020-12-17T08:23:49+0000] [ALPM] removed qt5-x11extras (5.15.2-1)
[2020-12-17T08:23:49+0000] [ALPM] removed qt5-webengine (5.15.2-1)
[2020-12-17T08:23:50+0000] [ALPM] removed qt5-webchannel (5.15.2-1)
[2020-12-17T08:23:50+0000] [ALPM] removed qt5-location (5.15.2-1)
[2020-12-17T08:23:50+0000] [ALPM] removed pyside2 (5.15.2-1)
[2020-12-17T08:23:50+0000] [ALPM] removed qt5-declarative (5.15.2-1)
[2020-12-17T08:23:51+0000] [ALPM] removed qt5-base (5.15.2-1)
[2020-12-17T08:23:51+0000] [ALPM] removed xdg-utils-terminal-true-git (r772.4aa0178-1)
[2020-12-17T08:23:51+0000] [ALPM] transaction completed
