As you can see in the screenshot there is this black bar in between of my screenshot. It’s because I have a dual monitor setup. Is there any way to remove this or is this a job for Photoshop?
Check Nvidia X Server Settings and/or the system Settings > Display and Monitor > Display Configuration
And make sure they match and that there is no gap between Monitors in the Layout of the Screen.
In case of dual GPU, well, you might consider [HowTo] Provide System Information and share it with us.
It was the System Settings > Display and Monitor, thanks!
