That’s what I did yesterday and steam is still running with this output
steam.sh[85809]: Running Steam on manjarolinux 24.0.3 64-bit
steam.sh[85809]: STEAM_RUNTIME is enabled automatically
setup.sh[85882]: Steam runtime environment up-to-date!
steam.sh[85809]: Steam client's requirements are satisfied
[2024-07-07 17:54:00] Startup - updater built Jun 20 2024 17:13:49
[2024-07-07 17:54:00] Startup - Steam Client launched with: '/home/master/.local/share/Steam/ubuntu12_32/steam' '-srt-logger-opened'
07/07 17:54:00 minidumps folder is set to /tmp/dumps
07/07 17:54:00 Init: Installing breakpad exception handler for appid(steam)/version(1718904662)/tid(85938)
[2024-07-07 17:54:01] Loading cached metrics from disk (/home/master/.local/share/Steam/package/steam_client_metrics.bin)
[2024-07-07 17:54:01] Using the following download hosts for Public, Realm steamglobal
[2024-07-07 17:54:01] 1. https://client-update.akamai.steamstatic.com, /, Realm 'steamglobal', weight was 1000, source = 'update_hosts_cached.vdf'
[2024-07-07 17:54:01] 2. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 1, source = 'update_hosts_cached.vdf'
[2024-07-07 17:54:01] 3. https://cdn.steamstatic.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2024-07-07 17:54:01] Verifying installation...
[2024-07-07 17:54:01] Verification complete
UpdateUI: skip show logo
Steam logging initialized: directory: /home/master/.local/share/Steam/logs
XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xe712ddc0
XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xe712c500
CAppInfoCacheReadFromDiskThread took 60 milliseconds to initialize
Steam Runtime Launch Service: starting steam-runtime-launcher-service
Steam Runtime Launch Service: steam-runtime-launcher-service is running pid 86058
bus_name=com.steampowered.PressureVessel.LaunchAlongsideSteam
/usr/share/themes/Breeze/gtk-2.0/widgets/entry:70: error: unexpected identifier 'direction', expected character '}'
/usr/share/themes/Breeze/gtk-2.0/widgets/styles:36: error: invalid string constant "combobox_entry", expected valid string constant
BRefreshApplicationsInLibrary 1: 1ms
BuildCompleteAppOverviewChange: 320 apps
RegisterForAppOverview 1: 9ms
RegisterForAppOverview 2: 9ms
wine: using kernel write watches, use_kernel_writewatch 1.
fsync: up and running.
chdir "/home/master/.local/share/Steam/steamapps/common/Red Dead Redemption 2"
ERROR: ld.so: object '/home/master/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
ERROR: ld.so: object '/home/master/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
Adding process 87392 for gameID 1174180
Adding process 87393 for gameID 1174180
Adding process 87394 for gameID 1174180
Adding process 87539 for gameID 1174180
ProtonFixes[87539] INFO: Running protonfixes
ProtonFixes[87539] INFO: Running checks
ProtonFixes[87539] INFO: All checks successful
ProtonFixes[87539] INFO: Using global defaults for "Red Dead Redemption 2" (1174180)
ProtonFixes[87539] INFO: Using global protonfix for "Red Dead Redemption 2" (1174180)
ProtonFixes[87539] INFO: Adding argument -fullscreen -vulkan
ProtonFixes[87539] INFO: Adding env: SteamGameId=1174180
Adding process 87558 for gameID 1174180
Adding process 87559 for gameID 1174180
Adding process 87560 for gameID 1174180
Adding process 87563 for gameID 1174180
Adding process 87569 for gameID 1174180
Adding process 87573 for gameID 1174180
Adding process 87590 for gameID 1174180
Adding process 87664 for gameID 1174180
Adding process 87672 for gameID 1174180
Adding process 87723 for gameID 1174180
Setting breakpad minidump AppID = 1174180
Steam_SetMinidumpSteamID: Caching Steam ID: 76561198018035752 [API loaded no]
Adding process 87754 for gameID 1174180
Adding process 87765 for gameID 1174180
Adding process 87876 for gameID 1174180
Missing interface adapter for SteamController008 UGC
Adding process 87887 for gameID 1174180
Adding process 87939 for gameID 1174180
Fossilize INFO: Overriding serialization path: "/home/master/.local/share/Steam/steamapps/shadercache/1174180/fozpipelinesv6/steamapprun_pipeline_cache".
Adding process 88040 for gameID 1174180
Adding process 88093 for gameID 1174180
Adding process 88108 for gameID 1174180
Adding process 88112 for gameID 1174180
Adding process 88124 for gameID 1174180
Adding process 88291 for gameID 1174180
Adding process 88300 for gameID 1174180
wine: Read access denied for device L"\\??\\F:\\", FS volume label and serial are not available.
wine: Read access denied for device L"\\??\\G:\\", FS volume label and serial are not available.
Adding process 88675 for gameID 1174180
GameOverlay: started '/home/master/.local/share/Steam/ubuntu12_32/gameoverlayui' (pid 88715) for game process 88675
07/07 17:55:06 minidumps folder is set to /tmp/dumps
07/07 17:55:06 Init: Installing breakpad exception handler for appid(gameoverlayui)/version(20240620171414)/tid(88715)
07/07 17:55:06 Init: Installing breakpad exception handler for appid(gameoverlayui)/version(1.0)/tid(88715)
Adding process 88728 for gameID 1174180
GameOverlay: started '/home/master/.local/share/Steam/ubuntu12_32/gameoverlayui' (pid 88855) for game process 88675
07/07 17:55:08 minidumps folder is set to /tmp/dumps
07/07 17:55:08 Init: Installing breakpad exception handler for appid(gameoverlayui)/version(20240620171414)/tid(88855)
07/07 17:55:08 Init: Installing breakpad exception handler for appid(gameoverlayui)/version(1.0)/tid(88855)
GameOverlay: started '/home/master/.local/share/Steam/ubuntu12_32/gameoverlayui' (pid 88856) for game process 88675
07/07 17:55:08 Init: Installing breakpad exception handler for appid(gameoverlayui)/version(20240620171414)/tid(88856)
07/07 17:55:08 Init: Installing breakpad exception handler for appid(gameoverlayui)/version(1.0)/tid(88856)
GameOverlay: started '/home/master/.local/share/Steam/ubuntu12_32/gameoverlayui' (pid 88857) for game process 88675
07/07 17:55:08 Init: Installing breakpad exception handler for appid(gameoverlayui)/version(20240620171414)/tid(88857)
07/07 17:55:08 Init: Installing breakpad exception handler for appid(gameoverlayui)/version(1.0)/tid(88857)
GameOverlay: started '/home/master/.local/share/Steam/ubuntu12_32/gameoverlayui' (pid 88858) for game process 88675
07/07 17:55:08 Init: Installing breakpad exception handler for appid(gameoverlayui)/version(20240620171414)/tid(88858)
07/07 17:55:08 Init: Installing breakpad exception handler for appid(gameoverlayui)/version(1.0)/tid(88858)
GameOverlay: started '/home/master/.local/share/Steam/ubuntu12_32/gameoverlayui' (pid 88859) for game process 88675
07/07 17:55:08 Init: Installing breakpad exception handler for appid(gameoverlayui)/version(20240620171414)/tid(88859)
07/07 17:55:08 Init: Installing breakpad exception handler for appid(gameoverlayui)/version(1.0)/tid(88859)
GameOverlay: started '/home/master/.local/share/Steam/ubuntu12_32/gameoverlayui' (pid 88860) for game process 88675
07/07 17:55:08 Init: Installing breakpad exception handler for appid(gameoverlayui)/version(20240620171414)/tid(88860)
07/07 17:55:08 Init: Installing breakpad exception handler for appid(gameoverlayui)/version(1.0)/tid(88860)
Adding process 88894 for gameID 1174180
Adding process 88911 for gameID 1174180
Adding process 88938 for gameID 1174180
Adding process 88948 for gameID 1174180
Adding process 88951 for gameID 1174180
reaping pid: 88855 -- gameoverlayui
reaping pid: 88856 -- gameoverlayui
reaping pid: 88857 -- gameoverlayui
reaping pid: 88858 -- gameoverlayui
reaping pid: 88859 -- gameoverlayui
[2024-07-07 17:56:03] Background update loop checking for update. . .
[2024-07-07 17:56:03] Checking for available updates...
[2024-07-07 17:56:03] Downloading manifest: https://client-update.akamai.steamstatic.com/steam_client_ubuntu12?t=3780553960
[2024-07-07 17:56:03] Manifest download: send request
[2024-07-07 17:56:03] Manifest download: waiting for download to finish
[2024-07-07 17:56:04] Manifest download: finished
[2024-07-07 17:56:04] Download skipped: /steam_client_ubuntu12?t=3780553960 version 1718904662, installed version 1718904662, existing pending version 0
[2024-07-07 17:56:04] Nothing to do
reaping pid: 88860 -- gameoverlayui
Adding process 89168 for gameID 1174180
Adding process 89248 for gameID 1174180
(process:88715): GLib-GObject-CRITICAL **: 21:04:10.141: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Adding process 108559 for gameID 1174180
pid 87561 != 87560, skipping destruction (fork without exec?)
Game 1174180 created interface STEAMAPPS_INTERFACE_VERSION008 / Apps
Game 1174180 created interface STEAMUSERSTATS_INTERFACE_VERSION011 / UserStats
Game 1174180 created interface SteamController004 / Controller
Game 1174180 created interface SteamFriends015 / Friends
Game 1174180 created interface SteamUser019 / User
Game 1174180 created interface SteamUtils008 / Utils
Game 1174180 method call count for IClientUserStats::RequestUserStats : 1
Game 1174180 method call count for IClientUserStats::GetAchievement : 30
Game 1174180 method call count for IClientUserStats::GetStat : 51
Game 1174180 method call count for IClientAppManager::GetCurrentLanguage : 8906
Game 1174180 method call count for IClientAppManager::BIsDlcEnabled : 1
Game 1174180 method call count for IClientUtils::RecordSteamInterfaceCreation : 10
Game 1174180 method call count for IClientUtils::GetAppID : 12
Game 1174180 method call count for IClientFriends::SetRichPresence : 48
Game 1174180 method call count for IClientFriends::GetPersonaName : 1
Game 1174180 method call count for IClientUser::BIsSubscribedApp : 2
Game 1174180 method call count for IClientUser::EndAuthSession : 1
Game 1174180 method call count for IClientUser::GetAuthSessionTicket : 2
Game 1174180 method call count for IClientUser::GetSteamID : 4
Game 1174180 method call count for IClientUser::BLoggedOn : 2
Uploaded AppInterfaceStats to Steam
Removing process 108559 for gameID 1174180
Removing process 89248 for gameID 1174180
Removing process 89168 for gameID 1174180
Removing process 88951 for gameID 1174180
Removing process 88948 for gameID 1174180
Removing process 88938 for gameID 1174180
Removing process 88911 for gameID 1174180
Removing process 88894 for gameID 1174180
Removing process 88728 for gameID 1174180
Removing process 88675 for gameID 1174180
Removing process 88300 for gameID 1174180
Removing process 88291 for gameID 1174180
Removing process 88124 for gameID 1174180
Removing process 88112 for gameID 1174180
Removing process 88108 for gameID 1174180
Removing process 88093 for gameID 1174180
Removing process 88040 for gameID 1174180
Removing process 87939 for gameID 1174180
Removing process 87887 for gameID 1174180
Removing process 87876 for gameID 1174180
Removing process 87765 for gameID 1174180
Removing process 87754 for gameID 1174180
Removing process 87723 for gameID 1174180
Removing process 87672 for gameID 1174180
Removing process 87664 for gameID 1174180
Removing process 87590 for gameID 1174180
Removing process 87573 for gameID 1174180
Removing process 87569 for gameID 1174180
Removing process 87563 for gameID 1174180
Removing process 87560 for gameID 1174180
Removing process 87559 for gameID 1174180
Removing process 87558 for gameID 1174180
Removing process 87539 for gameID 1174180
Removing process 87394 for gameID 1174180
Removing process 87393 for gameID 1174180
Removing process 87392 for gameID 1174180
reaping pid: 88715 -- gameoverlayui
[2024-07-08 06:51:03] Background update loop checking for update. . .
[2024-07-08 06:51:03] Downloading manifest: https://client-update.akamai.steamstatic.com/steam_client_ubuntu12?t=3825908648
[2024-07-08 06:51:03] Manifest download: send request
[2024-07-08 06:51:03] Manifest download: waiting for download to finish
[2024-07-08 06:51:09] Manifest download: finished
[2024-07-08 06:51:09] Download skipped by HTTP 304 Not Modified
[2024-07-08 06:51:09] Nothing to do
BRefreshApplicationsInLibrary 1: 0ms
I thought it would output to the terminal with these launch options.
Proton version was experimental when it started. Then tried 8 and 9 and the most recent 9GE. Didn’t make a difference.
Thx for the hint, but it didn’t.
Here is the log. It got a bit big so I posted it in a pastebin. Especially towards the end I bought something via the ledger and it did the same thing very often. When I start the game the flickering is visible after I hit enter and the gray clouds over the black and white pictures vanish.
Here is the terminal output from the same run as the log.
steam.sh[139935]: Running Steam on manjarolinux 24.0.3 64-bit
steam.sh[139935]: STEAM_RUNTIME is enabled automatically
setup.sh[140008]: Steam runtime environment up-to-date!
steam.sh[139935]: Steam client's requirements are satisfied
[2024-07-08 17:59:32] Startup - updater built Jun 20 2024 17:13:49
[2024-07-08 17:59:32] Startup - Steam Client launched with: '/home/master/.local/share/Steam/ubuntu12_32/steam' '-srt-logger-opened'
07/08 17:59:32 minidumps folder is set to /tmp/dumps
07/08 17:59:32 Init: Installing breakpad exception handler for appid(steam)/version(1718904662)/tid(140064)
[2024-07-08 17:59:33] Loading cached metrics from disk (/home/master/.local/share/Steam/package/steam_client_metrics.bin)
[2024-07-08 17:59:33] Using the following download hosts for Public, Realm steamglobal
[2024-07-08 17:59:33] 1. https://client-update.akamai.steamstatic.com, /, Realm 'steamglobal', weight was 1000, source = 'update_hosts_cached.vdf'
[2024-07-08 17:59:33] 2. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 1, source = 'update_hosts_cached.vdf'
[2024-07-08 17:59:33] 3. https://cdn.steamstatic.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2024-07-08 17:59:33] Verifying installation...
[2024-07-08 17:59:33] Verification complete
XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xe100adc0
XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xe1009500
CAppInfoCacheReadFromDiskThread took 57 milliseconds to initialize
Steam Runtime Launch Service: steam-runtime-launcher-service is running pid 140177
Adding process 141824 for gameID 1174180
Adding process 141825 for gameID 1174180
Adding process 141826 for gameID 1174180
Adding process 141930 for gameID 1174180
ProtonFixes[141930] INFO: Running protonfixes
ProtonFixes[141930] INFO: Running checks
ProtonFixes[141930] INFO: All checks successful
ProtonFixes[141930] INFO: Using global defaults for "Red Dead Redemption 2" (1174180)
ProtonFixes[141930] INFO: Using global protonfix for "Red Dead Redemption 2" (1174180)
ProtonFixes[141930] INFO: Adding argument -fullscreen -vulkan
ProtonFixes[141930] INFO: Adding env: SteamGameId=1174180
Adding process 141932 for gameID 1174180
Adding process 141933 for gameID 1174180
Adding process 141934 for gameID 1174180
Adding process 141937 for gameID 1174180
Adding process 141939 for gameID 1174180
Adding process 141942 for gameID 1174180
Adding process 141952 for gameID 1174180
Adding process 142052 for gameID 1174180
Adding process 142066 for gameID 1174180
Adding process 142111 for gameID 1174180
Adding process 142171 for gameID 1174180
Adding process 142174 for gameID 1174180
Adding process 142209 for gameID 1174180
Adding process 142220 for gameID 1174180
Adding process 142250 for gameID 1174180
Adding process 142439 for gameID 1174180
Adding process 142472 for gameID 1174180
Adding process 142488 for gameID 1174180
Adding process 142495 for gameID 1174180
Adding process 142504 for gameID 1174180
Adding process 142579 for gameID 1174180
pid 141935 != 141934, skipping destruction (fork without exec?)
Game 1174180 created interface STEAMUSERSTATS_INTERFACE_VERSION012 / UserStats
Game 1174180 created interface SteamController008 /
Game 1174180 created interface SteamController008 / UGC
Game 1174180 created interface SteamFriends017 / Friends
Game 1174180 created interface SteamInput006 /
Game 1174180 created interface SteamUser022 / User
Game 1174180 created interface SteamUtils010 /
Game 1174180 created interface SteamUtils010 / Utils
Game 1174180 method call count for IClientAppManager::GetCurrentLanguage : 1
Game 1174180 method call count for IClientAppManager::GetAppStateInfo : 1
Game 1174180 method call count for IClientAppManager::GetAvailableLanguages : 1
Game 1174180 method call count for IClientUtils::RecordSteamInterfaceCreation : 11
Game 1174180 method call count for IClientUtils::GetSteamUILanguage : 1
Game 1174180 method call count for IClientUtils::GetAppID : 13
Game 1174180 method call count for IClientUser::GetAuthSessionTicketV2 : 1
Game 1174180 method call count for IClientUser::GetSteamID : 2
Game 1174180 method call count for IClientUser::BLoggedOn : 1
Removing process 142579 for gameID 1174180
Removing process 142504 for gameID 1174180
Removing process 142495 for gameID 1174180
Removing process 142488 for gameID 1174180
Removing process 142472 for gameID 1174180
Removing process 142439 for gameID 1174180
Removing process 142250 for gameID 1174180
Removing process 142220 for gameID 1174180
Removing process 142209 for gameID 1174180
Removing process 142174 for gameID 1174180
Removing process 142171 for gameID 1174180
Removing process 142111 for gameID 1174180
Removing process 142066 for gameID 1174180
Removing process 142052 for gameID 1174180
Removing process 141952 for gameID 1174180
Removing process 141942 for gameID 1174180
Removing process 141939 for gameID 1174180
Removing process 141937 for gameID 1174180
Removing process 141934 for gameID 1174180
Removing process 141933 for gameID 1174180
Removing process 141932 for gameID 1174180
Removing process 141930 for gameID 1174180
Removing process 141826 for gameID 1174180
Removing process 141825 for gameID 1174180
Removing process 141824 for gameID 1174180
Adding process 143264 for gameID 1174180
Adding process 143265 for gameID 1174180
Adding process 143266 for gameID 1174180
Adding process 143366 for gameID 1174180
ProtonFixes[143366] INFO: Running protonfixes
ProtonFixes[143366] INFO: Running checks
ProtonFixes[143366] INFO: All checks successful
ProtonFixes[143366] INFO: Using global defaults for "Red Dead Redemption 2" (1174180)
ProtonFixes[143366] INFO: Using global protonfix for "Red Dead Redemption 2" (1174180)
ProtonFixes[143366] INFO: Adding argument -fullscreen -vulkan
ProtonFixes[143366] INFO: Adding env: SteamGameId=1174180
Adding process 143367 for gameID 1174180
Adding process 143368 for gameID 1174180
Adding process 143369 for gameID 1174180
Adding process 143372 for gameID 1174180
Adding process 143374 for gameID 1174180
Adding process 143377 for gameID 1174180
Adding process 143387 for gameID 1174180
Adding process 143401 for gameID 1174180
Adding process 143409 for gameID 1174180
Adding process 143424 for gameID 1174180
Adding process 143441 for gameID 1174180
Adding process 143444 for gameID 1174180
Adding process 143451 for gameID 1174180
Adding process 143462 for gameID 1174180
Adding process 143488 for gameID 1174180
Adding process 143567 for gameID 1174180
Adding process 143584 for gameID 1174180
Adding process 143599 for gameID 1174180
Adding process 143603 for gameID 1174180
Adding process 143614 for gameID 1174180
Adding process 143714 for gameID 1174180
Adding process 143723 for gameID 1174180
[2024-07-08 18:01:35] Background update loop checking for update. . .
[2024-07-08 18:01:35] Checking for available updates...
[2024-07-08 18:01:35] Downloading manifest: https://client-update.akamai.steamstatic.com/steam_client_ubuntu12?t=2560121414
[2024-07-08 18:01:35] Manifest download: send request
[2024-07-08 18:01:35] Manifest download: waiting for download to finish
[2024-07-08 18:01:36] Manifest download: finished
[2024-07-08 18:01:36] Download skipped: /steam_client_ubuntu12?t=2560121414 version 1718904662, installed version 1718904662, existing pending version 0
[2024-07-08 18:01:36] Nothing to do
Adding process 143808 for gameID 1174180
Adding process 143901 for gameID 1174180
Adding process 144061 for gameID 1174180
Adding process 144078 for gameID 1174180
Adding process 144099 for gameID 1174180
Adding process 144107 for gameID 1174180
Adding process 144110 for gameID 1174180
Adding process 144405 for gameID 1174180
Adding process 144530 for gameID 1174180
Adding process 147265 for gameID 1174180
Game 1174180 method call count for IClientAppManager::GetCurrentLanguage : 625
Game 1174180 method call count for IClientFriends::SetRichPresence : 9
Removing process 147265 for gameID 1174180
Removing process 144530 for gameID 1174180
Removing process 144405 for gameID 1174180
Removing process 144110 for gameID 1174180
Removing process 144107 for gameID 1174180
Removing process 144099 for gameID 1174180
Removing process 144078 for gameID 1174180
Removing process 144061 for gameID 1174180
Removing process 143901 for gameID 1174180
Removing process 143808 for gameID 1174180
Removing process 143723 for gameID 1174180
Removing process 143714 for gameID 1174180
Removing process 143614 for gameID 1174180
Removing process 143603 for gameID 1174180
Removing process 143599 for gameID 1174180
Removing process 143584 for gameID 1174180
Removing process 143567 for gameID 1174180
Removing process 143488 for gameID 1174180
Removing process 143462 for gameID 1174180
Removing process 143451 for gameID 1174180
Removing process 143444 for gameID 1174180
Removing process 143441 for gameID 1174180
Removing process 143424 for gameID 1174180
Removing process 143409 for gameID 1174180
Removing process 143401 for gameID 1174180
Removing process 143387 for gameID 1174180
Removing process 143377 for gameID 1174180
Removing process 143374 for gameID 1174180
Removing process 143372 for gameID 1174180
Removing process 143369 for gameID 1174180
Removing process 143368 for gameID 1174180
Removing process 143367 for gameID 1174180
Removing process 143366 for gameID 1174180
Removing process 143266 for gameID 1174180
Removing process 143265 for gameID 1174180
Removing process 143264 for gameID 1174180
