Recovering from an interupted update
In following the How To on this subject I have failed to make progress. The following is where it seems to fail after command: ‘update-grub’
[manjaro /]# update-grub
ERROR: mkdir /var/lock/dmraid
grub-probe: error: cannot find a GRUB drive for /dev/sdb1.  Check your device.map.
done
then:-
[manjaro /]# exit
exit
 --> umount: [/mnt/boot/efi]
 --> umount: [/mnt]
[manjaro ~]#
upon reboot my system goes to grub rescue
My system still will not boot. Any ideas anyone?
You have no kernel installed at the moment, due to the interrupted update.
Install a kernel when in chroot:
pacman -Syu linux66 (or whatever version you like)
mkinitcpio -P
update-grub
this time, the command output from the last command should have a few more lines
telling you that it found at least one kernel and the corresponding initrd
No progress.
I still get ‘grub_is_lockdown’
and
grub rescue
in chroot I get:
Mounting (ManjaroLinux) [/dev/sda2]
 --> mount: [/mnt]
 --> mount: [/mnt/boot/efi]
still in chroot I get:
[manjaro /]# mhwd-kernel -li
Currently running: 6.10.13-3-MANJARO (linux610)
   * linux510
   * linux515
   * linux54
   * linux61
   * linux611
   * linux66
then:
Found linux image: /boot/vmlinuz-6.6-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.6-x86_64.img
Found initrd fallback image: /boot/initramfs-6.6-x86_64-fallback.img
done
then:
[manjaro /]#  test -d /sys/firmware/efi && echo efi || echo bios
efi
then:
[manjaro /]# lsblk -f
NAME   FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0
loop1
loop2
loop3
sda
|-sda1                          299.1M     0% /boot/efi
|-sda2                           15.6G    80% /
`-sda3
sdb
|-sdb1
`-sdb2
sr0
Hi @Fastship
I understand that you have not been active in the forum for some 4 years, however, there are forum requirements in presentation that should be adhered to.
In this instance I have edited both your posts accordingly. In future, you are expected to do this yourself.
As an infrequent forum user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
The Update Announcements should be checked frequently for important update related information.
These announcements contain a Known Issues and Solutions section and should generally be checked before posting a request for support.
System information will usually go some way toward helping others to help you. The output of the following command will provide this:
inxi --admin --verbosity=8 --filter --no-host --width
[manjaro /]# inxi --admin --verbosity=8 --filter --no-host --width
12System:
  12Kernel 6.10.13-3-MANJARO 12arch x86_64 12bits 64 12compiler gcc 12v 14.2.1
    12clocksource tsc 12avail hpet,acpi_pm 12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64
    lang=en_US keytable=us tz=UTC misobasedir=manjaro
    misolabel=MANJARO_KDEM_2412 quiet systemd.show_status=1 splash driver=free
    nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
  12Desktop KDE Plasma 12v ERR-101 12tk Qt 12v N/A 12dm N/A 12Distro Manjaro
    12base Arch Linux
12Machine:
  12Type Desktop 12System Dell 12product OptiPlex 3020 12v 01 12serial <filter12Chassis
    12type 15 12serial <filter>
  12Mobo Dell 12model 0WMJ54 12v A01 12serial <filter12part-nu OptiPlex 3020
    12uuid 4c4c4544-0042-5a10-8047-c4c04f4b3532 12UEFI Dell 12v A08 12date 05/07/2015
12Battery:
  12Message No system battery data found. Is one present?
12Memory:
  12System RAM 12total 8 GiB 12available 7.68 GiB 12used 2.8 GiB (36.4%) 12igpu 32 MiB
  12Array-1 12capacity 16 GiB 12slots 2 12modules 2 12EC None 12max-module-size 8 GiB
    12note est.
  12Device-1 DIMM1 12type DDR3 12detail synchronous 12size 4 GiB 12speed 1600 MT/s
    12volts N/A 12width (bits) 12data 64 12total 64 12manufacturer Hynix/Hyundai
    12part-no HMT451U6BFR8A-PB 12serial <filter>
  12Device-2 DIMM2 12type DDR3 12detail synchronous 12size 4 GiB 12speed 1600 MT/s
12PCI Slots:
  12Slot 1 12type PCIe 12status available 12info J6B2X16 12length short 12volts 3.3
    12bus-ID 00:01.0
  12Slot 2 12type PCIe 12status available 12info J6B1X16 12length long 12volts 3.3
    12bus-ID 00:1c.2
12CPU:
  12Info 12model Intel Core i5-4590 12socket BGA1155 12bits 64 12type MCP 12arch Haswell
    12gen core 4 12level v3 12note check 12built 2013-15 12process Intel 22nm 12family 6
    12model-id 0x3C (60) 12stepping 3 12microcode 0x28
  12Topology 12cpus 1x 12dies 1 12clusters 4 12cores 4 12smt <unsupported12cache
    12L1 256 KiB 12desc d-4x32 KiB; i-4x32 KiB 12L2 1024 KiB 12desc 4x256 KiB 12L3 6 MiB
    12desc 1x6 MiB
  12Speed (MHz) 12avg 800 12min/max 800/3700 12base/boost 3300/3800 12scaling
    12driver intel_cpufreq 12governor schedutil 12volts 1.2 V 12ext-clock 100 MHz 12cores
    121 800 122 800 123 800 124 800 12bogomips 26351
  12Flags abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
    bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
    fsgsbase fxsr ht ibpb ibrs ida invpcid lahf_lm lm mca mce md_clear mmx
    monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
    pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good
    sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
    tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic
    xsave xsaveopt xtopology xtpr
  12Vulnerabilities
  12Type gather_data_sampling 12status Not affected
  12Type itlb_multihit 12status KVM: VMX disabled
  12Type l1tf 12mitigation PTE Inversion; VMX: conditional cache flushes, SMT
    disabled
  12Type mds 12mitigation Clear CPU buffers; SMT disabled
  12Type meltdown 12mitigation PTI
  12Type mmio_stale_data 12status Unknown: No mitigations
  12Type reg_file_data_sampling 12status Not affected
  12Type retbleed 12status Not affected
  12Type spec_rstack_overflow 12status Not affected
  12Type spec_store_bypass 12mitigation Speculative Store Bypass disabled via
  12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer
  12Type spectre_v2 12mitigation Retpolines; IBPB: conditional; IBRS_FW; STIBP:
  12Type srbds 12mitigation Microcode
  12Type tsx_async_abort 12status Not affected
12Graphics:
  12Device-1 Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
    12vendor Dell 12driver i915 12v kernel 12arch Gen-7.5 12process Intel 22nm 12built 2013
    12ports 12active VGA-1 12empty DP-1,HDMI-A-1 12bus-ID 00:02.0 12chip-ID 8086:0412
    12class-ID 0300
  12Display 12server X.org 12v 1.21.1.14 12with Xwayland 12v 24.1.4 12driver 12X
    12loaded modesetting 12alternate fbdev,vesa 12dri crocus 12gpu i915 12display-ID :0
  12Monitor-1 VGA-1 12model Dell E2014H 12serial <filter12built 2015 12res 1600x900
    12dpi 94 12gamma 1.2 12chroma 12red 12x 0.643 12y 0.337 12green 12x 0.314 12y 0.631 12blue
    12x 0.157 12y 0.059 12white 12x 0.314 12y 0.329 12size 432x240mm (17.01x9.45")
    12diag 494mm (19.5") 12ratio 16:9 12modes 1600x900, 1280x1024, 1152x864,
    1024x768, 800x600, 640x480, 720x400
  12API EGL 12v 1.5 12hw 12drv intel crocus 12platforms 12device 0 12drv crocus 12device 1
    12drv swrast 12gbm 12drv crocus 12surfaceless 12drv crocus 12inactive wayland,x11
  12API OpenGL 12v 4.6 12compat-v 4.5 12vendor mesa 12v 24.2.7-arch1.1 12note incomplete
    (EGL sourced) 12renderer Mesa Intel HD Graphics 4600 (HSW GT2), llvmpipe
    (LLVM 18.1.8 256 bits)
  12API Vulkan 12Message No Vulkan data available.
12Audio:
  12Device-1 Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio 12vendor Dell
    12driver snd_hda_intel 12v kernel 12bus-ID 00:03.0 12chip-ID 8086:0c0c 12class-ID 0403
  12Device-2 Intel 8 Series/C220 Series High Definition Audio 12vendor Dell
    12driver snd_hda_intel 12v kernel 12bus-ID 00:1b.0 12chip-ID 8086:8c20 12class-ID 0403
  12API ALSA 12v k6.10.13-3-MANJARO 12status kernel-api 12with aoss 12type oss-emulator
    12tools alsactl,alsamixer,amixer
  12Server-1 JACK 12v 1.9.22 12status off 12tools N/A
  12Server-2 PipeWire 12v 1.2.7 12status off 12with pipewire-media-session 12status off
    12tools pw-cli
  12Server-3 PulseAudio 12v 17.0 12status off 12with 121 pulseaudio-alsa 12type plugin
    122 pulseaudio-jack 12type module 12tools pacat,pactl
12Network:
  12Device-1 Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
    12vendor Dell 12driver r8169 12v kernel 12pcie 12gen 1 12speed 2.5 GT/s 12lanes 1 12port e000
    12bus-ID 02:00.0 12chip-ID 10ec:8168 12class-ID 0200
  12IF enp2s0 12state up 12speed 1000 Mbps 12duplex full 12mac <filter>
  12IP v4 <filter12type dynamic noprefixroute 12scope global 12broadcast <filter>
  12IP v6 <filter12type dynamic noprefixroute 12scope global
  12IP v6 <filter12type noprefixroute 12scope link
  12Info 12services No services found.
  12WAN IP <filter>
12Bluetooth:
  12Message No bluetooth data found.
12Logical:
  12Message No logical block device data found.
12RAID:
  12Message No RAID data found.
12Drives:
  12Local Storage 12total 126.49 GiB 12used 86.7 GiB (68.5%)
  12ID-1 /dev/sda 12maj-min 8:0 12vendor Samsung 12model SSD PM871 2.5 7mm 128GB
    12family based SSDs 12size 119.24 GiB 12block-size 12physical 512 B 12logical 512 B
    12sata 3.1 12speed 6.0 Gb/s 12tech SSD 12serial <filter12fw-rev 2D0Q
  12SMART yes 12state enabled 12health PASSED 12cycles 7429 12read 6.69 TiB
    12written 5.69 TiB
  12ID-2 /dev/sdb 12maj-min 8:16 12vendor Kingston 12model DataTraveler 112
    12size 7.25 GiB 12block-size 12physical 512 B 12logical 512 B 12type USB 12rev 2.0
    12spd 480 Mb/s 12lanes 1 12mode 2.0 12tech N/A 12serial <filter12fw-rev 1.00
  12SMART Message Unknown USB bridge. Flash drive/Unsupported enclosure?
  12Optical-1 /dev/sr0 12vendor HL-DT-ST 12model DVD+-RW GTA0N 12rev A1B0
    12dev-links cdrom
  12Features 12speed 24 12multisession yes 12audio yes 12dvd yes
    12rw cd-r,cd-rw,dvd-r,dvd-ram 12state running
12Partition:
  12ID-1 / 12raw-size 110.15 GiB 12size 107.86 GiB (97.92%) 12used 86.7 GiB (80.4%)
    12fs ext4 12block-size 4096 B 12dev /dev/sda2 12maj-min 8:2 12label N/A
    12uuid 49a0df49-ece4-459e-b760-0fd7ac361e9e
  12ID-2 /boot/efi 12raw-size 300 MiB 12size 299.4 MiB (99.80%) 12used 304 KiB (0.1%)
    12fs vfat 12block-size 512 B 12dev /dev/sda1 12maj-min 8:1 12label N/A 12uuid D710-63B5
12Swap:
  12Alert No swap data was found.
12Unmounted:
  12ID-1 /dev/sda3 12maj-min 8:3 12size 8.8 GiB 12fs swap 12label N/A
    12uuid a065a7b9-4eba-473e-84b4-7911eaa80b66
  12ID-2 /dev/sdb1 12maj-min 8:17 12size 3.25 GiB 12fs N/A 12label MANJARO_KDEM_2412
    12uuid 2024-11-04-04-22-58-00
  12ID-3 /dev/sdb2 12maj-min 8:18 12size 4 MiB 12fs N/A 12label MISO_EFI 12uuid 89C2-D29B
12USB:
  12Hub-1 1-0:1 12info full speed or root hub 12ports 2 12rev 2.0
    12speed 480 Mb/s (57.2 MiB/s) 12lanes 1 12mode 2.0 12chip-ID 1d6b:0002 12class-ID 0900
  12Hub-2 1-1:2 12info Intel Integrated Rate Matching Hub 12ports 4 12rev 2.0
    12speed 480 Mb/s (57.2 MiB/s) 12lanes 1 12mode 2.0 12chip-ID 8087:8008 12class-ID 0900
  12Hub-3 2-0:1 12info full speed or root hub 12ports 2 12rev 2.0
  12Hub-4 2-1:2 12info Intel Integrated Rate Matching Hub 12ports 6 12rev 2.0
    12speed 480 Mb/s (57.2 MiB/s) 12lanes 1 12mode 2.0 12chip-ID 8087:8000 12class-ID 0900
  12Hub-5 3-0:1 12info hi-speed hub with single TT 12ports 10 12rev 2.0
  12Device-1 3-5:2 12info Dell KB212-B Quiet Key Keyboard 12type keyboard
    12driver hid-generic,usbhid 12interfaces 1 12rev 1.1 12speed 1.5 Mb/s (183 KiB/s)
    12lanes 1 12mode 1.0 12power 100mA 12chip-ID 413c:2107 12class-ID 0301
  12Device-2 3-6:3 12info Lite-On USB Optical Mouse 12type mouse
    12driver hid-generic,usbhid 12interfaces 1 12rev 2.0 12speed 1.5 Mb/s (183 KiB/s)
    12lanes 1 12mode 1.0 12power 100mA 12chip-ID 04ca:0061 12class-ID 0301
  12Device-3 3-10:4 12info Kingston DataTraveler 112 4GB Pen Drive
    12type mass storage 12driver usb-storage 12interfaces 1 12rev 2.0
    12speed 480 Mb/s (57.2 MiB/s) 12lanes 1 12mode 2.0 12power 100mA 12chip-ID 0951:162a
    12class-ID 0806 12serial <filter>
  12Hub-6 4-0:1 12info super-speed hub 12ports 2 12rev 3.0 12speed 5 Gb/s (596.0 MiB/s)
    12lanes 1 12mode 3.2 gen-1x1 12chip-ID 1d6b:0003 12class-ID 0900
12Sensors:
  12System Temperatures 12cpu 25.0 C 12mobo N/A
  12Fan Speeds (rpm) N/A
12Repos:
  12Packages 12pm pacman 12pkgs 1652 12libs 450 12tools pamac,yay
  12Active pacman repo servers in /etc/pacman.d/mirrorlist
    121 https: //mirror.23m.com/manjaro/stable/$repo/$arch
    122 http: //manjaro.grena.ge/stable/$repo/$arch
    123 https: //edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    124 https: //mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    125 https: //manjarolinux-mirror.cloud.mu/stable/$repo/$arch
12Processes:
  12Message No process data available.
12Info:
  12Processes 0 12Power 12uptime 58m 12states freeze,mem,disk 12suspend deep 12avail s2idle
    12wakeups 0 12hibernate platform 12avail shutdown, reboot, suspend, test_resume
    12image 3.03 GiB 12Init systemd 12v 256 12default graphical 12tool systemctl
  12Compilers 12clang 18.1.8 12gcc 14.2.1 12Client systemd 12inxi 3.3.36
I suspect this would be what you’re looking for:
No. I applied that ‘How To’ solution as indicated in my opening post.
:bangbang: Tip :bangbang:
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
As I’m a moderator on the forum, I have taken the liberty of doing this for you, this time.
Will do. Thanks for pointing that out.
While I recognise your attempt to conform, for long code or command output, a scollable preformatted text box is usually preferred; it saves others from having to scroll to Antarctica and back to find something relevant.
The </> button will create a preformatted text box. From that point, just paste the text content between the two rows of (3) backtick characters, like this:
[assume this is your great wall of text]
That is a new one - you didn’t have this before.
From your posted command output it is clear that you now have linux66 correctly in place.
I do not know what the message:
grub_is_lockdown
means
(if I had to guess I’d think of secure boot active in UEFI settings first).
Someone else might know.
Your posted inxi information is almost unreadable as you might have noticed yourself.
Can you do the same command, but from outside chroot
when done inside chroot, the output looks horrible like this - not your fault.
Just boot and do it before you enter chroot.
Boot into a live eenvironment, enter a chroot environment and install this script:
pamac install install-grub
And afterwards, while still in the chroot environment, reinstall grub with:
install-grub
exit the chroot environment and reboot.
Where is your $ESP actually mounted;
at /boot/efi or /boot?
lsblk -o list
[manjaro /]# pamac install install-grub
Preparing...
Warning: install-grub-2:2.12-3 is up to date -- skipping
Nothing to do.
[manjaro /]# install-grub
WARNING: EFI directory not found! Grub couldn't be installed.
[manjaro /]#
[manjaro /]# lsblk -o list
lsblk: unknown column: list
sudo lsblk -o list
if outside chroot
hmmm…that is odd…
OK, from within the chroot environment, run the following and provide the output:
cat /etc/fstab
And
lsblk
  ~  inxi --admin --verbosity=8 --filter --no-host --width                              1 ✘  8m 7s 
  Kernel: 6.10.13-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
    misobasedir=manjaro misolabel=MANJARO_KDEM_2412 quiet
    systemd.show_status=1 splash driver=free nouveau.modeset=1 i915.modeset=1
    radeon.modeset=1
  Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
  Type: Desktop System: Dell product: OptiPlex 3020 v: 01
    serial: <superuser required> Chassis: type: 15 serial: <superuser required>
  Mobo: Dell model: 0WMJ54 v: A01 serial: <superuser required>
    part-nu: OptiPlex 3020 uuid: <superuser required> UEFI: Dell v: A08
    date: 05/07/2015
  System RAM: total: 8 GiB available: 7.68 GiB used: 2.37 GiB (30.9%)
  Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
  Device-1: DIMM1 type: DDR3 detail: synchronous size: 4 GiB speed: 1600 MT/s
    volts: N/A width (bits): data: 64 total: 64 manufacturer: Hynix/Hyundai
    part-no: HMT451U6BFR8A-PB serial: <filter>
  Device-2: DIMM2 type: DDR3 detail: synchronous size: 4 GiB speed: 1600 MT/s
  Info: model: Intel Core i5-4590 bits: 64 type: MCP arch: Haswell gen: core 4
    level: v3 note: check built: 2013-15 process: Intel 22nm family: 6
    model-id: 0x3C (60) stepping: 3 microcode: 0x28
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 smt: <unsupported> cache:
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 798 min/max: 800/3700 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 798 2: 798 3: 798 4: 798 bogomips: 26350
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
    disabled
    STIBP: disabled; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
    vendor: Dell driver: i915 v: kernel arch: Gen-7.5 process: Intel 22nm
    built: 2013 ports: active: VGA-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:0412 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: crocus gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.65x9.37")
    s-diag: 485mm (19.11")
  Monitor-1: VGA-1 model: Dell E2014H serial: <filter> built: 2015
    res: 1600x900 hz: 60 dpi: 94 gamma: 1.2 chroma: red: x: 0.643 y: 0.337 green:
    x: 0.314 y: 0.631 blue: x: 0.157 y: 0.059 white: x: 0.314 y: 0.329
    size: 432x240mm (17.01x9.45") diag: 494mm (19.5") ratio: 16:9
    modes: 1600x900, 1280x1024, 1152x864, 1024x768, 800x600, 640x480, 720x400
  API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
    device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus x11:
    drv: crocus inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.4-arch1.0.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4600 (HSW GT2)
    device-ID: 8086:0412 memory: 1.46 GiB unified: yes
  API: Vulkan v: 1.3.295 layers: N/A device: 0 type: integrated-gpu
    name: Intel HD Graphics 4600 (HSW GT2) driver: mesa intel v: 24.2.4-arch1.0.1
    device-ID: 8086:0412 surfaces: xcb,xlib
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Dell
    driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c
    class-ID: 0403
  Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Dell
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
    class-ID: 0403
  API: ALSA v: k6.10.13-3-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
    vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 126.49 GiB used: 0 KiB (0.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD PM871 2.5 7mm 128GB
    size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 2D0Q scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: DataTraveler 112
    size: 7.25 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
    spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 1.00
    scheme: MBR
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD+-RW GTA0N rev: A1B0
    dev-links: cdrom
  Message: No partition data found.
  ID-1: /dev/sda1 maj-min: 8:1 size: 300 MiB fs: vfat label: N/A
    uuid: D710-63B5
  ID-2: /dev/sda2 maj-min: 8:2 size: 110.15 GiB fs: ext4 label: N/A
    uuid: 49a0df49-ece4-459e-b760-0fd7ac361e9e
  ID-3: /dev/sda3 maj-min: 8:3 size: 8.8 GiB fs: swap label: N/A
    uuid: a065a7b9-4eba-473e-84b4-7911eaa80b66
  ID-4: /dev/sdb1 maj-min: 8:17 size: 3.25 GiB fs: iso9660
  ID-5: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: 89C2-D29B
  Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8008
  Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8000
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 10 rev: 2.0
  Device-1: 3-5:2 info: Dell KB212-B Quiet Key Keyboard type: keyboard
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 100mA chip-ID: 413c:2107 class-ID: 0301
  Device-2: 3-6:3 info: Lite-On USB Optical Mouse type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 100mA chip-ID: 04ca:0061 class-ID: 0301
  Device-3: 3-10:4 info: Kingston DataTraveler 112 4GB Pen Drive
    type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
    chip-ID: 0951:162a class-ID: 0806 serial: <filter>
  Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.0
  System Temperatures: cpu: 31.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1189 libs: 319 tools: pamac
    1: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    2: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    3: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    4: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    5: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    6: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    7: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://mirrors.netix.net/manjaro/stable/$repo/$arch
    9: https://mirrors2.manjaro.org/stable/$repo/$arch
    10: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    11: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    12: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    13: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    14: https://mirrors.piconets.webwerks.in/manjaro-mirror/stable/$repo/$arch
    15: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    16: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    17: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    18: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    19: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    20: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
    21: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    22: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    23: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    24: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    25: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    26: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    27: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    28: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
    29: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
    30: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    31: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    32: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    33: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    34: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    35: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
    36: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
    37: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    38: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    39: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    40: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    41: https://mirror.funami.tech/manjaro/stable/$repo/$arch
    42: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    43: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    44: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    45: https://repos.silknet.com/manjaro/stable/$repo/$arch
    46: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    47: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    48: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    49: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
    50: https://mirror.bardia.tech/manjaro/stable/$repo/$arch
    51: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    52: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    53: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
    54: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
    55: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    56: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    57: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    58: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    59: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    60: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    61: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    62: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    63: http://manjaro.mirror.ac.za/stable/$repo/$arch
    64: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    65: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    66: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
    67: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    68: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    69: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    70: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    71: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    72: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    73: http://manjaro.mirrors.theom.nz/manjaro/stable/$repo/$arch
    74: https://mirror.23m.com/manjaro/stable/$repo/$arch
    75: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    76: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    77: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    78: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    79: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
    80: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    81: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    82: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    83: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    84: https://linorg.usp.br/manjaro/stable/$repo/$arch
    85: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    86: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    87: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    88: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    89: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    90: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    91: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    92: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    93: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    94: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    95: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    96: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    97: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    98: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    99: https://manjaro.kurdy.org/stable/$repo/$arch
    100: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    101: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    102: https://manjaro.ynh.ovh/stable/$repo/$arch
    103: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    104: http://manjaro.grena.ge/stable/$repo/$arch
    105: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    106: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    107: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    108: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    109: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    110: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    111: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    112: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    113: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    114: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    115: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    116: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    117: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    118: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
    119: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    120: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    121: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    122: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    123: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    124: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
    125: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    126: https://mirror.seahost.de/manjaro/stable/$repo/$arch
    127: https://mirror.init7.net/manjaro/stable/$repo/$arch
    128: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    129: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    130: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    131: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 191
  1: cpu: 16.3% command: firefox pid: 1644 mem: 423.1 MiB (5.3%)
  2: cpu: 12.2% command: firefox pid: 1809 mem: 281.6 MiB (3.5%)
  3: cpu: 3.6% command: kwin_x11 pid: 1161 mem: 173.0 MiB (2.2%)
  4: cpu: 2.9% command: Xorg pid: 1072 mem: 83.9 MiB (1.0%)
  5: cpu: 0.8% command: plasmashell pid: 1210 mem: 280.5 MiB (3.5%)
  Memory top: 5 of 191
  1: mem: 423.1 MiB (5.3%) command: firefox pid: 1644 cpu: 16.3%
  2: mem: 281.6 MiB (3.5%) command: firefox pid: 1809 cpu: 12.2%
  3: mem: 280.5 MiB (3.5%) command: plasmashell pid: 1210 cpu: 0.8%
  4: mem: 220.6 MiB (2.8%) command: konsole pid: 2401 cpu: 0.2%
  5: mem: 199.1 MiB (2.5%) command: firefox pid: 2246 cpu: 0.7%
  Processes: 191 Power: uptime: 11m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 3.03 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: N/A Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.36
   ~  sudo lsblk -o list         INT ✘
[manjaro /]# cat /etc/fstab
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
UUID=D710-63B5                            /boot/efi      vfat    umask=0077 0 2
UUID=49a0df49-ece4-459e-b760-0fd7ac361e9e /              ext4    defaults,noatime 0 1
UUID=a065a7b9-4eba-473e-84b4-7911eaa80b66 swap           swap    defaults,noatime 0 0
tmpfs                                     /tmp           tmpfs   defaults,noatime,mode=1777 0 0
[manjaro /]# lsblk
NAME   MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
loop0    7:0    0 158.2M  1 loop
loop1    7:1    0 728.5M  1 loop
loop2    7:2    0   1.4G  1 loop
loop3    7:3    0 834.6M  1 loop
sda      8:0    0 119.2G  0 disk
|-sda1   8:1    0   300M  0 part /boot/efi
|-sda2   8:2    0 110.1G  0 part /
`-sda3   8:3    0   8.8G  0 part
sdb      8:16   1   7.3G  0 disk
|-sdb1   8:17   1   3.3G  0 part
`-sdb2   8:18   1     4M  0 part
sr0     11:0    1  1024M  0 rom
