I am running Mabox Linux at the moment, and I will ask about this in those forums as well, but since it is 99% Manjaro and I cannot find any Mabox-specific packages that would be updating grub to boot into the latest kernel after a system update:
Anyone have any idea why, after a system upgrade (and reboot, because-- I mean, doesn’t everyone reboot after system upgrades? ), grub will boot the latest kernel version I have installed, whether or not I was using it before the update.
Right now I have 5.4 and 5.10 installed, and I have been running 5.4. After an update/reboot, if I don’t hit the grub menu before it disappears, it will boot into 5.10. I don’t know grub well enough to figure out if GRUB_DEFAULT is reset somehow in the update-grub that is run with kernel installs, but my /etc/defaults/grub config looks the same as I have left it.
So… anyone know why this happens? Or where I might look for a clue?
Did you run? sudo update-grub
Then at boot time press Esc or Shift to get into the Grub menu and select the desired kernel too boot from? Then next time will boot from it.
Would running it after a system update (when kernels and/or grub are updated) keep it from “forgetting” the last kernel I booted into–since I have grub configured to recall that?
This is not exactly a major problem, of course. I have more than one kernel installed precisely because sometimes one is better with some audio or graphics tool, and so I do switch them at the grub menu from time to time.
It’s just one of those things that will keep me scrolling through grub/UEFI docs until I figure it out.
Thanks, @stephane. I have no problem getting the grub menu to show. Perhaps setting the timeout value for longer than it takes to get a cup of coffee during a reboot might not be a bad idea in my case though.
