I have ASUS FX505DT and after new update my wifi driver seems to be not working.
This output comes sometimes when wifi driver is working after few restarts:
β― inxi -Nazy
vendor: ASUSTeK driver: r8169 v: kernel port: e000 bus-ID: 02:00.0
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8822ce v: N/A modules: rtw88_8822ce port: d000
bus-ID: 04:00.0 chip-ID: 10ec:c822 class-ID: 0280
otherwise this comes:
β― inxi -Nazy
System: Kernel: 5.12.1-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64 root=UUID=3ce01a3b-83f7-4801-8527-2e7c9847b9fb rw quiet apparmor=1
Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Laptop System: ASUSTeK product: TUF Gaming FX505DT_FX505DT v: 1.0 serial: <filter>
Mobo: ASUSTeK model: FX505DT v: 1.0 serial: <filter> UEFI: American Megatrends v: FX505DT.316 date: 01/28/2021
Battery: ID-1: BAT0 charge: 12.9 Wh (33.4%) condition: 38.6/48.1 Wh (80.2%) volts: 12.2 min: 11.7 model: FX50442
type: Li-ion serial: N/A status: Charging
CPU: Info: Quad Core model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx bits: 64 type: MT MCP arch: Zen/Zen+
note: check family: 17 (23) model-id: 18 (24) stepping: 1 microcode: 8108102 cache: L2: 2 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 33552
Speed: 1373 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz): 1: 1373 2: 1560 3: 1349 4: 1330 5: 1265
6: 1227 7: 1671 8: 1476
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Graphics: Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK driver: nvidia v: 460.73.01
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Picasso vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 04:00.0
chip-ID: 1002:15d8 class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo bus-ID: 3-1:2 chip-ID: 13d3:56a2
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: amdgpu,ati,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 120 dpi: 142 size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.40.0 5.12.1-2-MANJARO LLVM 11.1.0) v: 4.6 Mesa 21.0.3
direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.12.1-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.26 running: no
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: e000
bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: enp4s0f3u2 state: unknown speed: N/A duplex: N/A mac: <filter>
Bluetooth: Device-1: OPPO SDM710-MTP _SN:76C74055 type: USB driver: rndis_host v: kernel bus-ID: 1-2:5 chip-ID: 22d9:276a
class-ID: 0a00 serial: <filter>
Device-2: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 1-4:3 chip-ID: 13d3:3548
Report: ID: hci0 rfk-id: 0 state: up address: N/A
Drives: Local Storage: total: 476.94 GiB used: 60.34 GiB (12.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2200V MTFDHBA512TCK size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: P1MA0V4 scheme: GPT
Partition: ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%) used: 60.34 GiB (12.9%) fs: ext4 dev: /dev/nvme0n1p2
maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
Swap: Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2 file: /swapfile
Sensors: System Temperatures: cpu: 57.4 C mobo: 57.0 C gpu: amdgpu temp: 57.0 C
Fan Speeds (RPM): cpu: 2700
Info: Processes: 263 Uptime: 3m wakeups: 1 Memory: 7.28 GiB used: 1.53 GiB (21.0%) Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: 1315 pacman: 1312 lib: 363 flatpak: 0 snap: 3 Shell: Zsh v: 5.8
running-in: yakuake inxi: 3.3.04
