Hi,  here  my first post on new forum.
I  have installed successfully the driver rtl8188eus from (https://github.com/aircrack-ng/rtl8188eus.git) for a Tp link wn722n wifi adapter.
lsusb recognize the adapter the I’ve tried to use for connecting to internet but
sudo iw dev wlan1 scan
gives me
command failed: No such device (-19)
Some months ago I used successfully on the the same system and I remember there was some kind of gui appearing when the wifi adapter was connected and I could use it to connect to internet via the adapter, the I had to format the system and now I have no idea how to use it again. Hope somebody can help. Thanks a lot
iwconfig output where wlan0 is my internal wifi card and wlan1 is the adapter:
wlan0     IEEE 802.11  ESSID:"portobello"
          Mode:Managed  Frequency:2.412 GHz  Access Point: 00:37:B7:0A:26:EE
          Bit Rate=130 Mb/s   Tx-Power=22 dBm
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Power Management:on
          Link Quality=49/70  Signal level=-61 dBm
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:2  Invalid misc:98   Missed beacon:0
wlan1     unassociated  ESSID:""  Nickname:"<WIFI@REALTEK>"
          Mode:Auto  Frequency=2.412 GHz  Access Point: Not-Associated
          Sensitivity:0/0
          Retry:off   RTS thr:off   Fragment thr:off
          Power Management:off
          Link Quality:0  Signal level:0  Noise level:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
inxi -Fxxxza --no-host :
System:    Kernel: 5.9.1-1-MANJARO x86_64 bits: 64 compiler: N/A
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=25cd00b7-5e78-4989-a540-b52f6235b902 rw quiet
           udev.log_priority=3
           Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4 dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine:   Type: Laptop System: Dell product: Latitude E5450 v: N/A serial: <filter> Chassis: type: 9 serial: <filter>
           Mobo: Dell model: 0MVKK7 v: A00 serial: <filter> UEFI: Dell v: A10 date: 09/01/2015
Battery:   ID-1: BAT0 charge: 15.1 Wh condition: 27.9/51.7 Wh (54%) volts: 7.5/7.6 model: Samsung SDI DELL 1KY05D9
           type: Li-poly serial: <filter> status: Discharging
CPU:       Topology: Dual Core model: Intel Core i7-5600U bits: 64 type: MT MCP arch: Broadwell family: 6 model-id: 3D (61)
           stepping: 4 microcode: 2F L2 cache: 4096 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 20760
           Speed: 1875 MHz min/max: 500/3200 MHz Core speeds (MHz): 1: 2594 2: 2596 3: 2594 4: 2594
           Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
           Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
           Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Graphics:  Device-1: Intel HD Graphics 5500 vendor: Dell driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:1616
           Device-2: NVIDIA GM108M [GeForce 840M] vendor: Dell driver: N/A alternate: nouveau bus ID: 03:00.0
           chip ID: 10de:1341
           Device-3: Sunplus Innovation type: USB driver: uvcvideo bus ID: 1-1.6:4 chip ID: 1bcf:2b8d
           Display: x11 server: X.Org 1.20.9 driver: modesetting unloaded: intel alternate: fbdev,vesa display ID: :0.0
           screens: 1
           Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
           Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.2x6.9") diag: 355mm (14")
           OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa 20.1.8 direct render: Yes
Audio:     Device-1: Intel Broadwell-U Audio vendor: Dell driver: snd_hda_intel v: kernel bus ID: 00:03.0 chip ID: 8086:160c
           Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Dell driver: snd_hda_intel v: kernel bus ID: 00:1b.0
           chip ID: 8086:9ca0
           Sound Server: ALSA v: k5.9.1-1-MANJARO
Network:   Device-1: Intel Ethernet I218-LM vendor: Dell driver: e1000e v: kernel port: f080 bus ID: 00:19.0
           chip ID: 8086:15a2
           IF: eth0 state: down mac: <filter>
           Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel port: f040 bus ID: 02:00.0 chip ID: 8086:095a
           Device-3: TP-Link TL-WN722N v2/v3 [Realtek RTL8188EUS] type: USB driver: r8188eu bus ID: 2-2:2 chip ID: 2357:010c
           serial: <filter>
           IF: wlan1 state: down mac: <filter>
Drives:    Local Storage: total: 238.47 GiB used: 196.27 GiB (82.3%)
           ID-1: /dev/sda vendor: Samsung model: SSD PM851 2.5 7mm 256GB size: 238.47 GiB block size: physical: 512 B
           logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 8D0Q scheme: GPT
Partition: ID-1: / raw size: 238.18 GiB size: 233.44 GiB (98.01%) used: 196.27 GiB (84.1%) fs: ext4 dev: /dev/sda2
Swap:      Kernel: swappiness: 60 (default) cache pressure: 100 (default)
           ID-1: swap-1 type: file size: 4.00 GiB used: 0 KiB (0.0%) priority: -2 file: /swapfile
Sensors:   System Temperatures: cpu: 52.0 C mobo: 40.0 C sodimm: 39.0 C
           Fan Speeds (RPM): cpu: 0
Info:      Processes: 212 Uptime: 34m Memory: 7.67 GiB used: 2.68 GiB (34.9%) Init: systemd v: 246 Compilers: gcc: 10.2.0
           clang: 10.0.1 Packages: pacman: 1364 lib: 363 flatpak: 0 Shell: fish v: 3.1.2 running in: server inxi: 3.1.05
