when I start a video call the green light turns on but the image is black
v4l2-ctl --list-devices:
USB Camera: USB Camera (usb-0000:00:14.0-7): /dev/video0 /dev/video1
after closing video app:
sudo rmmod uvcvideo && sudo modprobe uvcvideo
rmmod: ERROR: Module uvcvideo is in use
how can I get it working?
pobrn
11 November 2020 19:12
2
Please run ffplay /dev/video0, ffplay /dev/video1 and check if you get the same result
pobrn:
ffplay /dev/video1
/dev/video0: Device or resource busy
pobrn
11 November 2020 19:23
4
Please run fuser /dev/video0. It’ll say something like
/dev/video0: 606564m
now take that number and run readlink /proc/606564/exe, and it’ll tell you the name of the program which has the device open, close it, and then try ffplay again.
pobrn:
ffplay /dev/video0
closed the app that showed up, green light still on, ffplay /dev/video0 still showing busy
edit: ok force closed app in activity monitor & green light turned off`
ffplay /dev/video0 turns camera on and doesnt give “busy” error but camera app still shows black screen
edit 2: works!
system
Closed
26 November 2020 19:25
6
