Is the Raspberry Pi Zero W (not to be confused with Zero 2 W) supported?
only aarc64 is supported - that excludes Pi Zero W which is armv6l
I see. Thanks for the info.
So 32-bit CPUs are not supported, correct?
Is there a 32-bit version of Manjaro OS?
No, there is not.
Is the Pi Zero W available for sale anywhere? I need to replace a broken one.
