Raspberry Pi 3 image
Where is the Raspberry Pi 3 image now? Will the Pi 4 image work on a Pi 3?
Yes you can use it.
Has it the boot flies.
bcm2710-rpi-3-b.dtb
bcm2710-rpi-3-b-plus.dtb
The Raspberry Pi 4 image, should be able to boot on the Raspberry Pi 3.
Thanks @Strit you have just answered the question I was just about to ask on the forum.
Are you known for your psychic abilities? :slight_smile:
:+1:
