I got some crazy issues with my Gnome-Manjaro.
The WIFI hardware is randomly NOT recognized by the system. After several (random amount of) reboots it works.
With the parallel Win10 Install it is always recognized.
Anyone knows this issue?
I’m having the exact same issue so I figured Id post here instead of making a new thread. To describe the issue a little further whenever the system goes into hibernate or is shut off the subsequent boot up shows that the “WIFI Hardware” has been deactivated and the network settings force Airplane Mode. For me personally ive found that just powering down and then bringing back up the system will fix the issue but the issue is still present.
Since it was requested by the ADMIN earlier ill post the information found running
$ inxi -Fazy
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=a0dc96b7-4706-45c1-b187-b4ec3c70bbac ro quiet splash apparmor=1
Desktop: GNOME 3.38.2 tk: GTK 3.24.24 wm: gnome-shell
dm: GDM 3.38.2.1, LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: Hewlett-Packard product: HP Pavilion 15 Notebook PC
v: 0973120000405F10000620180 serial: <filter> Chassis: type: 10
serial: <filter>
Mobo: Hewlett-Packard model: 2293 v: 78.21 serial: <filter> UEFI: Insyde
v: F.36 date: 02/02/2015
ID-1: BAT0 charge: 23.2 Wh condition: 36.5/36.5 Wh (100%) volts: 15.3/14.8
model: Hewlett-Packard Primary type: Li-ion serial: N/A status: Discharging
Info: Dual Core model: Intel Core i5-5200U bits: 64 type: MT MCP
arch: Broadwell family: 6 model-id: 3D (61) stepping: 4 microcode: 2F
L2 cache: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 17566
Speed: 2253 MHz min/max: 500/2700 MHz Core speeds (MHz): 1: 2253 2: 2249
3: 2518 4: 2406
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Device-1: Intel HD Graphics 5500 vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:1616
Device-2: Suyin HP Truevision HD type: USB driver: uvcvideo bus ID: 1-3:2
chip ID: 064e:c341 serial: <filter>
Display: wayland server: X. org 1.20.10 compositor: gnome-shell driver: i915
note: n/a (using device driver) - try sudo/root display ID: 0
OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa 20.3.1
direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 00:03.0 chip ID: 8086:160c
Device-2: Intel Wildcat Point-LP High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:9ca0
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Intel Wireless 3160 driver: iwlwifi v: kernel port: 5040
bus ID: 08:00.0 chip ID: 8086:08b3
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: 3000 bus ID: 09:00.0 chip ID: 10ec:8136
Local Storage: total: 931.51 GiB used: 58.37 GiB (6.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD100
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 2C
ID-1: / raw size: 931.22 GiB size: 915.6 GiB (98.32%) used: 58.37 GiB (6.4%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 47.0 C mobo: N/A
Processes: 224 Uptime: 32m wakeups: 2 Memory: 7.7 GiB used: 2.62 GiB (34.1%)
Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages: 1442 pacman: 1426
lib: 423 flatpak: 5 snap: 11 Shell: Zsh v: 5.8 running in: gnome-terminal
inxi: 3.2.01
Hopefully this helps with regards to fixing the issue!.
