I recently returned to Manjaro after running Pop_os for a while. I moved to Pop_os because I had problems with that my computer reboots at random.
Now after I’m back to Manjaro I keep having problem with that my computer reboot.
Pop_os was rock solid. No problem.
Can anyone help me how to fix this?
I have an old thread that I started last time I had the some problem with this computer but I never got any help there.
Creating duplicate threads does not help the cause and is bad forum etiquette. Now that everything is in one place, it’s a lot easier to review your logs and such.
One thing you still haven’t provided is your full system info as outlined here:
journalctl --since="2 hours ago" --priority=3 & sudo dmesg -l emerg,alert,crit,err,warn ✔ 4s
[2] 3717
[2] + suspended (tty output) journalctl --since="2 hours ago" --priority=3
[ 0.147483] x86/cpu: SGX disabled by BIOS.
[ 0.157082] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.159498] ACPI: PRMT not present
[ 0.690332] ata2.00: supports DRM functions and may not be fully accessible
[ 0.693541] ata2.00: supports DRM functions and may not be fully accessible
[ 1.012813] usb: port power management may be unreliable
[ 1.821351] hid-generic 0003:045E:0823.0004: No inputs registered, leaving
[ 2.577407] sd 2:0:0:0: [sdb] No Caching mode page found
[ 2.577415] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[ 2.975085] sd 3:0:0:0: [sdc] No Caching mode page found
[ 2.975090] sd 3:0:0:0: [sdc] Assuming drive cache: write through
[ 6.761882] acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 6.761963] acpi PNP0C14:02: duplicate WMI GUID 2B814318-4BE8-4707-9D84-A190A859B5D0 (first instance was on PNP0C14:00)
[ 6.761965] acpi PNP0C14:02: duplicate WMI GUID 41227C2D-80E1-423F-8B8E-87E32755A0EB (first instance was on PNP0C14:00)
[ 6.761967] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 7.091194] iwlwifi 0000:00:14.3: WRT: Overriding region id 0
[ 7.091197] iwlwifi 0000:00:14.3: WRT: Overriding region id 1
[ 7.091199] iwlwifi 0000:00:14.3: WRT: Overriding region id 2
[ 7.091200] iwlwifi 0000:00:14.3: WRT: Overriding region id 3
[ 7.091200] iwlwifi 0000:00:14.3: WRT: Overriding region id 4
[ 7.091201] iwlwifi 0000:00:14.3: WRT: Overriding region id 6
[ 7.091202] iwlwifi 0000:00:14.3: WRT: Overriding region id 8
[ 7.091203] iwlwifi 0000:00:14.3: WRT: Overriding region id 9
[ 7.091203] iwlwifi 0000:00:14.3: WRT: Overriding region id 10
[ 7.091204] iwlwifi 0000:00:14.3: WRT: Overriding region id 11
[ 7.091205] iwlwifi 0000:00:14.3: WRT: Overriding region id 15
[ 7.091206] iwlwifi 0000:00:14.3: WRT: Overriding region id 16
[ 7.091207] iwlwifi 0000:00:14.3: WRT: Overriding region id 18
[ 7.091207] iwlwifi 0000:00:14.3: WRT: Overriding region id 19
[ 7.091208] iwlwifi 0000:00:14.3: WRT: Overriding region id 20
[ 7.091209] iwlwifi 0000:00:14.3: WRT: Overriding region id 21
[ 7.091210] iwlwifi 0000:00:14.3: WRT: Overriding region id 28
[ 7.282172] thermal thermal_zone2: failed to read out thermal zone (-61)
[ 7.284079] hp_wmi: query 0x4 returned error 0x5
[ 7.285951] hp_wmi: query 0xd returned error 0x5
[ 7.293037] hp_wmi: query 0x1b returned error 0x5
[ 8.100319] scsi 2:0:0:1: Wrong diagnostic page; asked for 1 got 8
[ 8.100331] scsi 2:0:0:1: Failed to get diagnostic page 0x1
[ 8.100338] scsi 2:0:0:1: Failed to bind enclosure -19
[ 9.944779] Bluetooth: hci0: MSFT filter_enable is already on
[ 12.064742] kauditd_printk_skb: 46 callbacks suppressed
[ 12.413190] CIFS: No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3.1.1), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3.1.1 (or even SMB3 or SMB2.1) specify vers=1.0 on mount.
[ 13.414756] Bluetooth: hci0: MSFT filter_enable is already on
[ 19.013422] kauditd_printk_skb: 9 callbacks suppressed
[ 324.256289] snd_hda_codec_hdmi hdaudioC0D2: HDMI: pin NID 0x5 not registered
[ 2515.250666] snd_hda_codec_hdmi hdaudioC0D2: HDMI: pin NID 0x5 not registered
[ 2517.228747] snd_hda_codec_hdmi hdaudioC0D2: HDMI: pin NID 0x5 not registered
[ 2518.151178] snd_hda_codec_hdmi hdaudioC0D2: HDMI: pin NID 0x5 not registered
Using a mainline kernel that’s currently in an early RC (Release Candidate) stage will probably exasperate the problem, not solve it. Use either the latest stable or an LTS (Long Term Release) kernel.
That’s not what I asked for and you already posted that earlier; hence why I asked for full system details. See the tutorial I posted and edit your post to include those details.
EDIT: I said edit your post, not create a new one. I’ve done it for you.
