Random reboots daily
My computer reboots once every day at random
Any idea where to check for why it reboots?
journalctl for the reboot:
Can you try another kernel?
E.g.: 5.4.x
Can try 5.4 to see if that works better. But do you see anything wrong in the log?
There seems to be nothing to worry about the log before
-- Boot 496e0e49479046c892c4fad4540ddc7d --
What is the command you used to generate the log?
Could you run inxi --faazi and post the output between
output here
so it shows like this example, that way users can also see your hardware
System:    Kernel: 5.10.13-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
This way other users might spot something about your hardware + the log might make it easier to see what it is wrong. The log is rather long, it might be good to filter it a bit so only errors show: example: journalctl --since=today --priority=3 & sudo dmesg -l emerg,alert,crit,err,warn Please also post the output like the example:
output here
Yes, the last update borked mine (after ten minutes maximum it became unuseable), so I called up my GRUB and selected the 5.4 kernel - all is sweet again.
The log is from
journalctl --since=ā€œ1 hour agoā€
inxi -faazi         22 ✘
CPU:       Info: Quad Core model: Intel Core i3-9300T bits: 64 type: MCP arch: Kaby Lake note: check family: 6
           model-id: 9E (158) stepping: B (11) microcode: DE L2 cache: 8 MiB bogomips: 25610
           Speed: 900 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 900 2: 900 3: 900 4: 900
           Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art avx avx2 bmi1 bmi2 bts clflush
           clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
           flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt
           invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
           pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
           smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
           vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
           Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
           Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Network:   Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel port: 3000 bus ID: 00:14.3
           chip ID: 8086:a370 class ID: 0280
           IF: wlp0s20f3 state: down mac: <filter>
           Device-2: Intel Ethernet I219-LM vendor: Hewlett-Packard driver: e1000e v: kernel port: efa0 bus ID: 00:1f.6
           chip ID: 8086:15bb class ID: 0200
           IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
I had this problem for while now so its not something that started after the last update
It’s a problem with i915 driver. I assume you have nvidia optimus laptop. If you switch to nvidia completely, problem will be gone. However, experience is terrible. I heard that kernel 5.11 has a fix for this issue but Manjaro didn’t release it yet.
Edit: you can also try to boot with ā€œnomodesetā€ however, manjaro won’t boot with that. You have to switch to ubuntu.
No I dont have an Nvidia optimus laptop. Its an HP Elitedesk with only intel
Now it happened again. I’m on Linux manjaro 5.11.1-1-MANJARO
Mar 09 16:56:42 manjaro gnome-shell[817]: Ignoring excess values in shadow definition
Mar 09 16:56:42 manjaro gsd-usb-protect[1659]: Error calling USBGuard DBus to change the protection after a screensaver event: GDBus.Error:org.freedesktop.D>
Mar 09 16:56:42 manjaro rtkit-daemon[1202]: Supervising 6 threads of 3 processes of 1 users.
Mar 09 16:56:42 manjaro rtkit-daemon[1202]: Successfully made thread 61081 of process 1187 owned by '1000' RT at priority 5.
Mar 09 16:56:42 manjaro rtkit-daemon[1202]: Supervising 7 threads of 3 processes of 1 users.
Mar 09 16:56:42 manjaro kernel: ------------[ cut here ]------------
Mar 09 16:56:42 manjaro kernel: WARNING: CPU: 0 PID: 1187 at sound/pci/hda/patch_hdmi.c:2133 hdmi_pcm_close+0x1c8/0x1d0 [snd_hda_codec_hdmi]
Mar 09 16:56:42 manjaro kernel: Modules linked in: tun rfcomm cmac algif_hash algif_skcipher af_alg bnep joydev mousedev btusb btrtl btbcm btintel bluetooth>
Mar 09 16:56:42 manjaro kernel:  iwlwifi snd_pcm_dmaengine i915 ofpart snd_pcm cmdlinepart intel_uncore intel_spi_pci pcspkr intel_spi snd_timer spi_nor cfg>
Mar 09 16:56:42 manjaro kernel: CPU: 0 PID: 1187 Comm: pulseaudio Tainted: G        W         5.11.1-1-MANJARO #1
Mar 09 16:56:42 manjaro kernel: Hardware name: HP HP EliteDesk 800 G5 Desktop Mini/8595, BIOS R21 Ver. 02.07.01 10/19/2020
Mar 09 16:56:42 manjaro kernel: RIP: 0010:hdmi_pcm_close+0x1c8/0x1d0 [snd_hda_codec_hdmi]
Mar 09 16:56:42 manjaro kernel: Code: 4c 89 e7 b9 07 0f 00 00 e8 a5 7c 09 00 0f b7 33 b9 07 07 00 00 31 d2 83 e0 bf 4c 89 e7 41 89 c0 e8 cd 7b 09 00 e9 5a f>
Mar 09 16:56:42 manjaro kernel: RSP: 0018:ffffaf33418e3e18 EFLAGS: 00010246
Mar 09 16:56:42 manjaro kernel: RAX: ffff9ef713099600 RBX: 0000000000000000 RCX: 0000000000000000
Mar 09 16:56:42 manjaro kernel: RDX: 0000000000000000 RSI: 0000000000000002 RDI: 0000000000000003
Mar 09 16:56:42 manjaro kernel: RBP: ffff9ef719e56000 R08: ffff9ef713099600 R09: 0000000000000028
Mar 09 16:56:42 manjaro kernel: R10: ffff9ef708b87480 R11: 0000000000000000 R12: ffff9ef71c3e8800
Mar 09 16:56:42 manjaro kernel: R13: ffff9ef711e311d8 R14: ffff9ef71e38ef08 R15: ffff9ef711e31000
Mar 09 16:56:42 manjaro kernel: FS:  00007f9e102fd800(0000) GS:ffff9efa1f600000(0000) knlGS:0000000000000000
Mar 09 16:56:42 manjaro kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Mar 09 16:56:42 manjaro kernel: CR2: 000055a3854a95d0 CR3: 000000013cd7c004 CR4: 00000000003706f0
Mar 09 16:56:42 manjaro kernel: Call Trace:
Mar 09 16:56:42 manjaro kernel:  azx_pcm_close+0x75/0xf0 [snd_hda_codec]
Mar 09 16:56:42 manjaro kernel:  snd_pcm_release_substream.part.0+0x40/0xd0 [snd_pcm]
Mar 09 16:56:42 manjaro kernel:  snd_pcm_release+0x4e/0xb0 [snd_pcm]
Mar 09 16:56:42 manjaro kernel:  __fput+0x85/0x230
Mar 09 16:56:42 manjaro kernel:  task_work_run+0x5c/0x90
Mar 09 16:56:42 manjaro kernel:  exit_to_user_mode_prepare+0x158/0x160
Mar 09 16:56:42 manjaro kernel:  syscall_exit_to_user_mode+0x23/0x50
Mar 09 16:56:42 manjaro kernel:  entry_SYSCALL_64_after_hwframe+0x44/0xa9
Mar 09 16:56:42 manjaro kernel: RIP: 0033:0x7f9e10d0dcdb
Mar 09 16:56:42 manjaro kernel: Code: 8b 15 99 71 0c 00 f7 d8 64 89 02 48 c7 c0 ff ff ff ff eb 89 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa b8 0b 00 00 0>
Mar 09 16:56:42 manjaro kernel: RSP: 002b:00007ffd37fa6f88 EFLAGS: 00000202 ORIG_RAX: 000000000000000b
Mar 09 16:56:42 manjaro kernel: RAX: 0000000000000000 RBX: 00005614d2ef2578 RCX: 00007f9e10d0dcdb
Mar 09 16:56:42 manjaro kernel: RDX: 0000000000000010 RSI: 0000000000001000 RDI: 00007f9e0bced000
Mar 09 16:56:42 manjaro kernel: RBP: 00005614d2d535e0 R08: 0000000000000000 R09: 0000000000000010
Mar 09 16:56:42 manjaro kernel: R10: 0000000000000007 R11: 0000000000000202 R12: 0000000000000000
Mar 09 16:56:42 manjaro kernel: R13: 00005614d2d6bff0 R14: 00005614d2f4b530 R15: 00005614d2d3f720
Mar 09 16:56:42 manjaro kernel: ---[ end trace f734f08db8dceb2d ]---
Mar 09 16:56:42 manjaro rtkit-daemon[1202]: Successfully made thread 61082 of process 1187 owned by '1000' RT at priority 5.
Mar 09 16:56:42 manjaro gsd-media-keys[1616]: Unable to get default sink
-- Boot 1ce83393d7ab4bc5980a68a6320992bf --
Mar 09 17:00:48 manjaro kernel: Linux version 5.11.1-1-MANJARO (builduser@LEGION) (gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Tue Feb 23>
Mar 09 17:00:48 manjaro kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64 root=UUID=3814721c-83c2-4527-890f-dd000caf568b ro quiet udev.log_priority>
Mar 09 17:00:48 manjaro kernel: KERNEL supported cpus:
Mar 09 17:00:48 manjaro kernel:   Intel GenuineIntel
Mar 09 17:00:48 manjaro kernel:   AMD AuthenticAMD
Mar 09 17:00:48 manjaro kernel:   Hygon HygonGenuine
Mar 09 17:00:48 manjaro kernel:   Centaur CentaurHauls
Mar 09 17:00:48 manjaro kernel:   zhaoxin   Shanghai
Mar 09 17:00:48 manjaro kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Mar 09 17:00:48 manjaro kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Mar 09 17:00:48 manjaro kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Mar 09 17:00:48 manjaro kernel: x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
Mar 09 17:00:48 manjaro kernel: x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
Mar 09 17:00:48 manjaro kernel: x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
Mar 09 17:00:48 manjaro kernel: x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
Mar 09 17:00:48 manjaro kernel: x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
Mar 09 17:00:48 manjaro kernel: x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
Mar 09 17:00:48 manjaro kernel: BIOS-provided physical RAM map:
Mar 09 17:00:48 manjaro kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
Mar 09 17:00:48 manjaro kernel: BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
Mar 09 17:00:48 manjaro kernel: BIOS-e820: [mem 0x0000000000100000-0x00000000b70f1fff] usable
Mar 09 17:00:48 manjaro kernel: BIOS-e820: [mem 0x00000000b70f2000-0x00000000b70f2fff] reserved
Mar 09 17:00:48 manjaro kernel: BIOS-e820: [mem 0x00000000b70f3000-0x00000000b7903fff] usable
Mar 09 17:00:48 manjaro kernel: BIOS-e820: [mem 0x00000000b7904000-0x00000000b7904fff] reserved
Mar 09 17:00:48 manjaro kernel: BIOS-e820: [mem 0x00000000b7905000-0x00000000c26aafff] usable
Mar 09 17:00:48 manjaro kernel: BIOS-e820: [mem 0x00000000c26ab000-0x00000000c2baafff] type 20
Mar 09 17:00:48 manjaro kernel: BIOS-e820: [mem 0x00000000c2bab000-0x00000000c398efff] reserved
Mar 09 17:00:48 manjaro kernel: BIOS-e820: [mem 0x00000000c398f000-0x00000000c3b8efff] ACPI NVS
Mar 09 17:00:48 manjaro kernel: BIOS-e820: [mem 0x00000000c3b8f000-0x00000000c3c0efff] ACPI data
Mar 09 17:00:48 manjaro kernel: BIOS-e820: [mem 0x00000000c3c0f000-0x00000000c3c0ffff] usable
Mar 09 17:00:48 manjaro kernel: BIOS-e820: [mem 0x00000000c3c10000-0x00000000cc7fffff] reserved
Mar 09 17:00:48 manjaro kernel: BIOS-e820: [mem 0x00000000fe010000-0x00000000fe010fff] reserved
Mar 09 17:00:48 manjaro kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
Mar 09 17:00:48 manjaro kernel: BIOS-e820: [mem 0x0000000100000000-0x000000042f7fffff] usable
Mar 09 17:00:48 manjaro kernel: NX (Execute Disable) protection: active
It seems like this issue is very old.
Check out possible solutions mentioned here:
https://bugs.archlinux.org/task/53227
Have been running on kernel 5.4 for a while now without reboots. Switched to 5.11 yesterday and tonight I left the computer on and it rebooted during the night
I have never seen it reboot. Look like it happens when it tries to enter suspend
And another reboot
Apr 21 10:33:22 manjaro dbus-daemon[349]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.125' (uid=1000 pid=2277 comm="/usr/lib/chromium/chromium ")
Apr 21 10:33:22 manjaro audit: BPF prog-id=24 op=LOAD
Apr 21 10:33:22 manjaro audit: BPF prog-id=25 op=LOAD
Apr 21 10:33:22 manjaro systemd[1]: Starting Hostname Service...
Apr 21 10:33:22 manjaro kernel: audit: type=1334 audit(1618994002.029:209): prog-id=24 op=LOAD
Apr 21 10:33:22 manjaro kernel: audit: type=1334 audit(1618994002.029:210): prog-id=25 op=LOAD
Apr 21 10:33:22 manjaro dbus-daemon[349]: [system] Successfully activated service 'org.freedesktop.hostname1'
Apr 21 10:33:22 manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 21 10:33:22 manjaro systemd[1]: Started Hostname Service.
Apr 21 10:33:22 manjaro kernel: audit: type=1130 audit(1618994002.103:211): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 21 10:33:27 manjaro tracker-miner-f[1882]: g_hash_table_contains: assertion 'hash_table != NULL' failed
Apr 21 10:33:27 manjaro dbus-daemon[690]: [session uid=1000 pid=690] Activating via systemd: service name='org.freedesktop.Tracker3.Miner.Extract' unit='tracker-extract-3.service' requested by ':1.100' (uid=1000 pid=1882 comm="/usr/lib/tracker>
Apr 21 10:33:27 manjaro systemd[673]: Starting Tracker metadata extractor...
Apr 21 10:33:27 manjaro tracker-extract[51405]: tracker-extract-3 running as org.freedesktop.Tracker3.Miner.Extract. The service will exit when org.freedesktop.Tracker3.Miner.Files disappears from the bus.
Apr 21 10:33:27 manjaro dbus-daemon[690]: [session uid=1000 pid=690] Successfully activated service 'org.freedesktop.Tracker3.Miner.Extract'
Apr 21 10:33:27 manjaro systemd[673]: Started Tracker metadata extractor.
Apr 21 10:33:32 manjaro dbus-daemon[690]: [session uid=1000 pid=690] Activating service name='org.gnome.evince.Daemon' requested by ':1.322' (uid=1000 pid=51419 comm="evince /home/niclas/Documents/TG-FactSheet--191016")
Apr 21 10:33:32 manjaro dbus-daemon[690]: [session uid=1000 pid=690] Successfully activated service 'org.gnome.evince.Daemon'
Apr 21 10:33:32 manjaro org.gnome.Nautilus[51419]: ! SyncTeX Error : No file?
Apr 21 10:33:38 manjaro systemd[673]: tracker-extract-3.service: Succeeded.
Apr 21 10:33:52 manjaro systemd[1]: systemd-hostnamed.service: Succeeded.
Apr 21 10:33:52 manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 21 10:33:52 manjaro kernel: audit: type=1131 audit(1618994032.163:212): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 21 10:33:52 manjaro audit: BPF prog-id=25 op=UNLOAD
Apr 21 10:33:52 manjaro audit: BPF prog-id=24 op=UNLOAD
Apr 21 10:33:52 manjaro kernel: audit: type=1334 audit(1618994032.276:213): prog-id=25 op=UNLOAD
Apr 21 10:33:52 manjaro kernel: audit: type=1334 audit(1618994032.276:214): prog-id=24 op=UNLOAD
Apr 21 10:33:56 manjaro gnome-shell[735]: libinput error: event3  - Microsoft MicrosoftĀ® Classic IntelliMouseĀ®: client bug: event processing lagging behind by 28ms, your system is too slow
Apr 21 10:34:29 manjaro gnome-shell[735]: libinput error: event3  - Microsoft MicrosoftĀ® Classic IntelliMouseĀ®: client bug: event processing lagging behind by 11ms, your system is too slow
Apr 21 10:34:29 manjaro gnome-shell[735]: libinput error: event3  - Microsoft MicrosoftĀ® Classic IntelliMouseĀ®: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
Apr 21 10:35:23 manjaro gnome-shell[735]: libinput error: event4  - Chicony HP Elite USB Keyboard: client bug: event processing lagging behind by 17ms, your system is too slow
Apr 21 10:35:39 manjaro gnome-shell[735]: libinput error: event4  - Chicony HP Elite USB Keyboard: client bug: event processing lagging behind by 30ms, your system is too slow
Apr 21 10:35:39 manjaro gnome-shell[735]: libinput error: event4  - Chicony HP Elite USB Keyboard: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
Apr 21 10:38:02 manjaro gnome-shell[51752]: libpng warning: iCCP: known incorrect sRGB profile
Apr 21 10:39:12 manjaro gnome-shell[51960]: Fontconfig error: Cannot load default config file: No such file: (null)
Apr 21 10:39:18 manjaro gnome-shell[51989]: Fontconfig error: Cannot load default config file: No such file: (null)
Apr 21 10:39:22 manjaro gnome-shell[52015]: Fontconfig error: Cannot load default config file: No such file: (null)
Apr 21 10:39:53 manjaro gnome-shell[52118]: Fontconfig error: Cannot load default config file: No such file: (null)
Apr 21 10:40:08 manjaro gnome-shell[52161]: Fontconfig error: Cannot load default config file: No such file: (null)
Apr 21 10:44:21 manjaro gnome-shell[735]: clutter_actor_set_allocation_internal: assertion '!isnan (box->x1) && !isnan (box->x2) && !isnan (box->y1) && !isnan (box->y2)' failed
Apr 21 10:44:21 manjaro gnome-shell[735]: ../mutter/clutter/clutter/clutter-actor.c:9589: Actor 'StDrawingArea' tried to allocate a size of -2147483648.00 x -2147483648.00
Apr 21 10:44:21 manjaro gnome-shell[735]: ../mutter/clutter/clutter/clutter-actor.c:9589: Actor 'StBin' tried to allocate a size of -2147483648.00 x -2147483648.00
Apr 21 10:44:48 manjaro gnome-shell[825]: Key repeat discarded, Wayland compositor doesn't seem to be processing events fast enough!
Apr 21 11:07:52 manjaro gsd-usb-protect[1195]: Error calling USBGuard DBus to change the protection after a screensaver event: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Apr 21 11:07:53 manjaro kernel: snd_hda_codec_hdmi hdaudioC0D2: HDMI: pin NID 0x5 not registered
-- Boot f37528a2ed544c8081f34295575d3c0d --
Apr 21 11:09:33 manjaro kernel: Linux version 5.11.10-1-MANJARO (builduser@LEGION) (gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Thu Mar 25 17:14:55 UTC 2021
Apr 21 11:09:33 manjaro kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64 root=UUID=3814721c-83c2-4527-890f-dd000caf568b ro quiet udev.log_priority=3
Apr 21 11:09:33 manjaro kernel: KERNEL supported cpus:
Apr 21 11:09:33 manjaro kernel:   Intel GenuineIntel
Apr 21 11:09:33 manjaro kernel:   AMD AuthenticAMD
Apr 21 11:09:33 manjaro kernel:   Hygon HygonGenuine
Apr 21 11:09:33 manjaro kernel:   Centaur CentaurHauls
Apr 21 11:09:33 manjaro kernel:   zhaoxin   Shanghai
Apr 21 11:09:33 manjaro kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Apr 21 11:09:33 manjaro kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Apr 21 11:09:33 manjaro kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Apr 21 11:09:33 manjaro kernel: x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
Apr 21 11:09:33 manjaro kernel: x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
Apr 21 11:09:33 manjaro kernel: x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
Apr 21 11:09:33 manjaro kernel: x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
Apr 21 11:09:33 manjaro kernel: x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
Apr 21 11:09:33 manjaro kernel: x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
Apr 21 11:09:33 manjaro kernel: BIOS-provided physical RAM map:
Apr 21 11:09:33 manjaro kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
Apr 21 11:09:33 manjaro kernel: BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
Apr 21 11:09:33 manjaro kernel: BIOS-e820: [mem 0x0000000000100000-0x00000000b70f1fff] usable
Apr 21 11:09:33 manjaro kernel: BIOS-e820: [mem 0x00000000b70f2000-0x00000000b70f2fff] reserved
Apr 21 11:09:33 manjaro kernel: BIOS-e820: [mem 0x00000000b70f3000-0x00000000b7903fff] usable
Apr 21 11:09:33 manjaro kernel: BIOS-e820: [mem 0x00000000b7904000-0x00000000b7904fff] reserved
Apr 21 11:09:33 manjaro kernel: BIOS-e820: [mem 0x00000000b7905000-0x00000000c26aafff] usable
Apr 21 11:09:33 manjaro kernel: BIOS-e820: [mem 0x00000000c26ab000-0x00000000c2baafff] type 20
Apr 21 11:09:33 manjaro kernel: BIOS-e820: [mem 0x00000000c2bab000-0x00000000c398efff] reserved
Apr 21 11:09:33 manjaro kernel: BIOS-e820: [mem 0x00000000c398f000-0x00000000c3b8efff] ACPI NVS
Apr 21 11:09:33 manjaro kernel: BIOS-e820: [mem 0x00000000c3b8f000-0x00000000c3c0efff] ACPI data
Apr 21 11:09:33 manjaro kernel: BIOS-e820: [mem 0x00000000c3c0f000-0x00000000c3c0ffff] usable
Apr 21 11:09:33 manjaro kernel: BIOS-e820: [mem 0x00000000c3c10000-0x00000000cc7fffff] reserved
Apr 21 11:09:33 manjaro kernel: BIOS-e820: [mem 0x00000000fe010000-0x00000000fe010fff] reserved
Apr 21 11:09:33 manjaro kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
Apr 21 11:09:33 manjaro kernel: BIOS-e820: [mem 0x0000000100000000-0x000000042f7fffff] usable
Apr 21 11:09:33 manjaro kernel: NX (Execute Disable) protection: active
Apr 21 11:09:33 manjaro kernel: efi: EFI v2.60 by HP
Apr 21 11:09:33 manjaro kernel: efi: ACPI=0xc3c0e000 ACPI 2.0=0xc3c0e014 TPMFinalLog=0xc3b59000 SMBIOS=0xc2e75000 ESRT=0xc2e8a598 MEMATTR=0xb2d78018
Apr 21 11:09:33 manjaro kernel: SMBIOS 3.1 present.
Apr 21 11:09:33 manjaro kernel: DMI: HP HP EliteDesk 800 G5 Desktop Mini/8595, BIOS R21 Ver. 02.08.00 12/28/2020
Apr 21 11:09:33 manjaro kernel: tsc: Detected 3200.000 MHz processor
Apr 21 11:09:33 manjaro kernel: tsc: Detected 3199.980 MHz TSC
Apr 21 11:09:33 manjaro kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Apr 21 11:09:33 manjaro kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
Apr 21 11:09:33 manjaro kernel: last_pfn = 0x42f800 max_arch_pfn = 0x400000000
Apr 21 11:09:33 manjaro kernel: MTRR default type: write-back
Apr 21 11:09:33 manjaro kernel: MTRR fixed ranges enabled:
Apr 21 11:09:33 manjaro kernel:   00000-9FFFF write-back
Apr 21 11:09:33 manjaro kernel:   A0000-BFFFF uncachable
Apr 21 11:09:33 manjaro kernel:   C0000-FFFFF write-protect
Apr 21 11:09:33 manjaro kernel: MTRR variable ranges enabled:
Apr 21 11:09:33 manjaro kernel:   0 base 00E0000000 mask 7FE0000000 uncachable
Apr 21 11:09:33 manjaro kernel:   1 base 00D0000000 mask 7FF0000000 uncachable
Apr 21 11:09:33 manjaro kernel:   2 base 00C8000000 mask 7FF8000000 uncachable
Apr 21 11:09:33 manjaro kernel:   3 base 2000000000 mask 6000000000 uncachable
Apr 21 11:09:33 manjaro kernel:   4 base 1000000000 mask 7000000000 uncachable
Apr 21 11:09:33 manjaro kernel:   5 base 0800000000 mask 7800000000 uncachable
Apr 21 11:09:33 manjaro kernel:   6 base 4000000000 mask 4000000000 uncachable
Apr 21 11:09:33 manjaro kernel:   7 disabled
Apr 21 11:09:33 manjaro kernel:   8 disabled
Apr 21 11:09:33 manjaro kernel:   9 disabled
Apr 21 11:09:33 manjaro kernel: x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
Apr 21 11:09:33 manjaro kernel: last_pfn = 0xc3c10 max_arch_pfn = 0x400000000
Apr 21 11:09:33 manjaro kernel: esrt: Reserving ESRT space from 0x00000000c2e8a598 to 0x00000000c2e8a5d0.
Apr 21 11:09:33 manjaro kernel: check: Scanning 1 areas for low memory corruption
Apr 21 11:09:33 manjaro kernel: Using GB pages for direct mapping
Apr 21 11:09:33 manjaro kernel: Secure boot disabled
Apr 21 11:09:33 manjaro kernel: RAMDISK: [mem 0x36b2d000-0x3758dfff]
Apr 21 11:09:33 manjaro kernel: ACPI: Early table checksum verification disabled
Apr 21 11:09:33 manjaro kernel: ACPI: RSDP 0x00000000C3C0E014 000024 (v02 HPQOEM)
Apr 21 11:09:33 manjaro kernel: ACPI: XSDT 0x00000000C3BD4188 0000F4 (v01 HPQOEM SLIC-BPC 00000000 INTL 20160422)
Apr 21 11:09:33 manjaro kernel: ACPI: FACP 0x00000000C3C05000 000114 (v06 HPQOEM SLIC-BPC 00000000 HP   00000001)
Apr 21 11:09:33 manjaro kernel: ACPI: DSDT 0x00000000C3BE2000 01F476 (v02 HPQOEM 8595     00000000 INTL 20160527)
Apr 21 11:09:33 manjaro kernel: ACPI: FACS 0x00000000C3B55000 000040
Apr 21 11:09:33 manjaro kernel: ACPI: SSDT 0x00000000C3C0C000 00012A (v02 HP     ShmTable 00000001 INTL 20160527)
Apr 21 11:09:33 manjaro kernel: ACPI: SSDT 0x00000000C3C0A000 001B60 (v02 CpuRef CpuSsdt  00003000 INTL 20160527)
Apr 21 11:09:33 manjaro kernel: ACPI: SSDT 0x00000000C3C09000 0009CF (v02 CtdpB  CtdpB    00001000 INTL 20160527)
Apr 21 11:09:33 manjaro kernel: ACPI: MSDM 0x00000000C3C08000 000055 (v03 HPQOEM SLIC-BPC 00000000 HP   00000001)
Apr 21 11:09:33 manjaro kernel: ACPI: SLIC 0x00000000C3C07000 000176 (v01 HPQOEM SLIC-BPC 00000001 HP   00000001)
Apr 21 11:09:33 manjaro kernel: ACPI: WSMT 0x00000000C3C06000 000028 (v01 HPQOEM 8595     00000001 HP   00000001)
Apr 21 11:09:33 manjaro kernel: ACPI: HPET 0x00000000C3C04000 000038 (v01 HPQOEM 8595     00000001 HP   00000001)
Apr 21 11:09:33 manjaro kernel: ACPI: APIC 0x00000000C3C03000 00012C (v03 HPQOEM 8595     00000001 HP   00000001)
Apr 21 11:09:33 manjaro kernel: ACPI: MCFG 0x00000000C3C02000 00003C (v01 HPQOEM 8595     00000001 HP   00000001)
Apr 21 11:09:33 manjaro kernel: ACPI: SSDT 0x00000000C3BE1000 000734 (v01 HPQOEM PtidDevc 00001000 INTL 20160527)
Apr 21 11:09:33 manjaro kernel: ACPI: SSDT 0x00000000C3BE0000 000E5B (v02 HPQOEM HP_XHC_P 00000000 INTL 20160527)
Apr 21 11:09:33 manjaro kernel: ACPI: SSDT 0x00000000C3BDC000 003147 (v02 SaSsdt SaSsdt   00003000 INTL 20160527)
Apr 21 11:09:33 manjaro kernel: ACPI: LPIT 0x00000000C3BDB000 000094 (v01 INTEL  CFL      20170001 INTL 20160422)
Apr 21 11:09:33 manjaro kernel: ACPI: WSMT 0x00000000C3BDA000 000028 (v01 INTEL  CFL      20170001 INTL 20160422)
Apr 21 11:09:33 manjaro kernel: ACPI: SSDT 0x00000000C3BD9000 0003CE (v02 INTEL  Tpm2Tabl 00001000 INTL 20160527)
Apr 21 11:09:33 manjaro kernel: ACPI: TPM2 0x00000000C3BD8000 000034 (v04 INTEL  CFL      20170001 INTL 20160422)
Apr 21 11:09:33 manjaro kernel: ACPI: UEFI 0x00000000C3B4E000 000042 (v01 INTEL  CFL      20170001 INTL 20160422)
Apr 21 11:09:33 manjaro kernel: ACPI: OEML 0x00000000C3BD7000 000028 (v03 INTEL  CFL      20170001 INTL 20160422)
Apr 21 11:09:33 manjaro kernel: ACPI: SSDT 0x00000000C3BD6000 0003DF (v02 Intel  UcsiAcpi 00001000 INTL 20160527)
Apr 21 11:09:33 manjaro kernel: ACPI: SSDT 0x00000000C3BC6000 00D379 (v01 HP     HPINDTWL 00001000 INTL 20160527)
Apr 21 11:09:33 manjaro kernel: ACPI: SSDT 0x00000000C3C0D000 000032 (v01 HP     HPCONDEV 00001000 INTL 20160527)
Apr 21 11:09:33 manjaro kernel: ACPI: SSDT 0x00000000C3BC5000 000069 (v01 HP     HPCAHWID 00001000 INTL 20160527)
Apr 21 11:09:33 manjaro kernel: ACPI: ASF! 0x00000000C3BC4000 0000A0 (v32 HPQOEM  UYAMIHC 20170001 INTL 20160422)
Apr 21 11:09:33 manjaro kernel: ACPI: DMAR 0x00000000C3BD5000 0000C8 (v01 INTEL  CFL      00000002      01000013)
Apr 21 11:09:33 manjaro kernel: ACPI: FPDT 0x00000000C3BC3000 000044 (v01 INTEL  CFL      20170001 INTL 20160422)
Apr 21 11:09:33 manjaro kernel: ACPI: Local APIC address 0xfee00000
Apr 21 11:09:33 manjaro kernel: No NUMA configuration found
Apr 21 11:09:33 manjaro kernel: Faking a node at [mem 0x0000000000000000-0x000000042f7fffff]
Apr 21 11:09:33 manjaro kernel: NODE_DATA(0) allocated [mem 0x42f7fc000-0x42f7fffff]
Apr 21 11:09:33 manjaro kernel: Zone ranges:
Apr 21 11:09:33 manjaro kernel:   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
Apr 21 11:09:33 manjaro kernel:   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
Apr 21 11:09:33 manjaro kernel:   Normal   [mem 0x0000000100000000-0x000000042f7fffff]
Apr 21 11:09:33 manjaro kernel:   Device   empty
Apr 21 11:09:33 manjaro kernel: Movable zone start for each node
Apr 21 11:09:33 manjaro kernel: Early memory node ranges
Apr 21 11:09:33 manjaro kernel:   node   0: [mem 0x0000000000001000-0x000000000009efff]
Apr 21 11:09:33 manjaro kernel:   node   0: [mem 0x0000000000100000-0x00000000b70f1fff]
Apr 21 11:09:33 manjaro kernel:   node   0: [mem 0x00000000b70f3000-0x00000000b7903fff]
Apr 21 11:09:33 manjaro kernel:   node   0: [mem 0x00000000b7905000-0x00000000c26aafff]
Apr 21 11:09:33 manjaro kernel:   node   0: [mem 0x00000000c3c0f000-0x00000000c3c0ffff]
Apr 21 11:09:33 manjaro kernel:   node   0: [mem 0x0000000100000000-0x000000042f7fffff]
Apr 21 11:09:33 manjaro kernel: Initmem setup node 0 [mem 0x0000000000001000-0x000000042f7fffff]
Apr 21 11:09:33 manjaro kernel: On node 0 totalpages: 4136520
Apr 21 11:09:33 manjaro kernel:   DMA zone: 64 pages used for memmap
Apr 21 11:09:33 manjaro kernel:   DMA zone: 22 pages reserved
Apr 21 11:09:33 manjaro kernel:   DMA zone: 3998 pages, LIFO batch:0
Apr 21 11:09:33 manjaro kernel:   DMA zone: 28770 pages in unavailable ranges
Apr 21 11:09:33 manjaro kernel:   DMA32 zone: 12379 pages used for memmap
Apr 21 11:09:33 manjaro kernel:   DMA32 zone: 792234 pages, LIFO batch:63
Apr 21 11:09:33 manjaro kernel:   DMA32 zone: 22870 pages in unavailable ranges
Apr 21 11:09:33 manjaro kernel:   Normal zone: 52192 pages used for memmap
Apr 21 11:09:33 manjaro kernel:   Normal zone: 3340288 pages, LIFO batch:63
Apr 21 11:09:33 manjaro kernel:   Normal zone: 2048 pages in unavailable ranges
Apr 21 11:09:33 manjaro kernel: Reserving Intel graphics memory at [mem 0xc8800000-0xcc7fffff]
Apr 21 11:09:33 manjaro kernel: ACPI: PM-Timer IO Port: 0x1808
Apr 21 11:09:33 manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
Apr 21 11:09:33 manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
Apr 21 11:09:33 manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
Apr 21 11:09:33 manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
Apr 21 11:09:33 manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
Apr 21 11:09:33 manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
Apr 21 11:09:33 manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
Apr 21 11:09:33 manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
Apr 21 11:09:33 manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
Apr 21 11:09:33 manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
Apr 21 11:09:33 manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
Apr 21 11:09:33 manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
Apr 21 11:09:33 manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
Apr 21 11:09:33 manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
Apr 21 11:09:33 manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
Apr 21 11:09:33 manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
Apr 21 11:09:33 manjaro kernel: IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
Apr 21 11:09:33 manjaro kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Apr 21 11:09:33 manjaro kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Apr 21 11:09:33 manjaro kernel: ACPI: IRQ0 used by override.
Apr 21 11:09:33 manjaro kernel: ACPI: IRQ9 used by override.
Apr 21 11:09:33 manjaro kernel: Using ACPI (MADT) for SMP configuration information
Apr 21 11:09:33 manjaro kernel: ACPI: HPET id: 0x8086a201 base: 0xfed00000
Apr 21 11:09:33 manjaro kernel: TSC deadline timer available
Apr 21 11:09:33 manjaro kernel: smpboot: Allowing 4 CPUs, 0 hotplug CPUs
Apr 21 11:09:33 manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
Apr 21 11:09:33 manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
Apr 21 11:09:33 manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0xb70f2000-0xb70f2fff]
Apr 21 11:09:33 manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0xb7904000-0xb7904fff]
Apr 21 11:09:33 manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0xc26ab000-0xc2baafff]
Apr 21 11:09:33 manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0xc2bab000-0xc398efff]
Apr 21 11:09:33 manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0xc398f000-0xc3b8efff]
Apr 21 11:09:33 manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0xc3b8f000-0xc3c0efff]
Apr 21 11:09:33 manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0xc3c10000-0xcc7fffff]
Apr 21 11:09:33 manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0xcc800000-0xfe00ffff]
Apr 21 11:09:33 manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0xfe010000-0xfe010fff]
Apr 21 11:09:33 manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xfeffffff]
Apr 21 11:09:33 manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
Apr 21 11:09:33 manjaro kernel: [mem 0xcc800000-0xfe00ffff] available for PCI devices
Apr 21 11:09:33 manjaro kernel: Booting paravirtualized kernel on bare hardware
Apr 21 11:09:33 manjaro kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
Apr 21 11:09:33 manjaro kernel: setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:4 nr_node_ids:1
Apr 21 11:09:33 manjaro kernel: percpu: Embedded 56 pages/cpu s192512 r8192 d28672 u524288
Apr 21 11:09:33 manjaro kernel: pcpu-alloc: s192512 r8192 d28672 u524288 alloc=1*2097152
Apr 21 11:09:33 manjaro kernel: pcpu-alloc: [0] 0 1 2 3
Apr 21 11:09:33 manjaro kernel: Built 1 zonelists, mobility grouping on.  Total pages: 4071863
Apr 21 11:09:33 manjaro kernel: Policy zone: Normal
Apr 21 11:09:33 manjaro kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64 root=UUID=3814721c-83c2-4527-890f-dd000caf568b ro quiet udev.log_priority=3
Apr 21 11:09:33 manjaro kernel: Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
Apr 21 11:09:33 manjaro kernel: Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
Apr 21 11:09:33 manjaro kernel: mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
Apr 21 11:09:33 manjaro kernel: Memory: 16029788K/16546080K available (14344K kernel code, 2090K rwdata, 5076K rodata, 1780K init, 3984K bss, 516032K reserved, 0K cma-reserved)
Apr 21 11:09:33 manjaro kernel: random: get_random_u64 called from __kmem_cache_create+0x26/0x530 with crng_init=0
Apr 21 11:09:33 manjaro kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Apr 21 11:09:33 manjaro kernel: Kernel/User page tables isolation: enabled
Apr 21 11:09:33 manjaro kernel: ftrace: allocating 43414 entries in 170 pages
Apr 21 11:09:33 manjaro kernel: ftrace: allocated 170 pages with 4 groups
Apr 21 11:09:33 manjaro kernel: rcu: Preemptible hierarchical RCU implementation.
Apr 21 11:09:33 manjaro kernel: rcu:         RCU dyntick-idle grace-period acceleration is enabled.
Apr 21 11:09:33 manjaro kernel: rcu:         RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
Apr 21 11:09:33 manjaro kernel: rcu:         RCU priority boosting: priority 1 delay 500 ms.
Apr 21 11:09:33 manjaro kernel:         Trampoline variant of Tasks RCU enabled.
Apr 21 11:09:33 manjaro kernel:         Rude variant of Tasks RCU enabled.
Apr 21 11:09:33 manjaro kernel:         Tracing variant of Tasks RCU enabled.
Apr 21 11:09:33 manjaro kernel: rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
Apr 21 11:09:33 manjaro kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
Apr 21 11:09:33 manjaro kernel: NR_IRQS: 20736, nr_irqs: 1024, preallocated irqs: 16
Apr 21 11:09:33 manjaro kernel: Console: colour dummy device 80x25
Apr 21 11:09:33 manjaro kernel: printk: console [tty0] enabled
Apr 21 11:09:33 manjaro kernel: ACPI: Core revision 20201113
Apr 21 11:09:33 manjaro kernel: clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
Apr 21 11:09:33 manjaro kernel: APIC: Switch to symmetric I/O mode setup
Apr 21 11:09:33 manjaro kernel: DMAR: Host address width 39
Apr 21 11:09:33 manjaro kernel: DMAR: DRHD base: 0x000000fed90000 flags: 0x0
Apr 21 11:09:33 manjaro kernel: DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
Apr 21 11:09:33 manjaro kernel: DMAR: DRHD base: 0x000000fed91000 flags: 0x1
Apr 21 11:09:33 manjaro kernel: DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
Apr 21 11:09:33 manjaro kernel: DMAR: RMRR base: 0x000000c381e000 end: 0x000000c383dfff
Apr 21 11:09:33 manjaro kernel: DMAR: RMRR base: 0x000000c8000000 end: 0x000000cc7fffff
Apr 21 11:09:33 manjaro kernel: DMAR: RMRR base: 0x000000c386f000 end: 0x000000c38eefff
Apr 21 11:09:33 manjaro kernel: DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
Apr 21 11:09:33 manjaro kernel: DMAR-IR: HPET id 0 under DRHD base 0xfed91000
Apr 21 11:09:33 manjaro kernel: DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
Apr 21 11:09:33 manjaro kernel: DMAR-IR: Enabled IRQ remapping in x2apic mode
Apr 21 11:09:33 manjaro kernel: x2apic enabled
Apr 21 11:09:33 manjaro kernel: Switched APIC routing to cluster x2apic.
Apr 21 11:09:33 manjaro kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
Apr 21 11:09:33 manjaro kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2e2036ff8d5, max_idle_ns: 440795275316 ns
Apr 21 11:09:33 manjaro kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 6402.62 BogoMIPS (lpj=10666600)
Apr 21 11:09:33 manjaro kernel: pid_max: default: 32768 minimum: 301
Apr 21 11:09:33 manjaro kernel: LSM: Security Framework initializing
Apr 21 11:09:33 manjaro kernel: Yama: becoming mindful.
Apr 21 11:09:33 manjaro kernel: Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
Apr 21 11:09:33 manjaro kernel: Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
Apr 21 11:09:33 manjaro kernel: mce: CPU0: Thermal monitoring enabled (TM1)
Apr 21 11:09:33 manjaro kernel: process: using mwait in idle threads
Apr 21 11:09:33 manjaro kernel: Last level iTLB entries: 4KB 128, 2MB 8, 4MB 8
Apr 21 11:09:33 manjaro kernel: Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
Apr 21 11:09:33 manjaro kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
Apr 21 11:09:33 manjaro kernel: Spectre V2 : Mitigation: Full generic retpoline
Apr 21 11:09:33 manjaro kernel: Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
Apr 21 11:09:33 manjaro kernel: Spectre V2 : Enabling Restricted Speculation for firmware calls
Apr 21 11:09:33 manjaro kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
Apr 21 11:09:33 manjaro kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
Apr 21 11:09:33 manjaro kernel: SRBDS: Mitigation: Microcode
Apr 21 11:09:33 manjaro kernel: MDS: Mitigation: Clear CPU buffers
Apr 21 11:09:33 manjaro kernel: Freeing SMP alternatives memory: 36K
Apr 21 11:09:33 manjaro kernel: smpboot: Estimated ratio of average max frequency by base frequency (times 1024): 1120
Apr 21 11:09:33 manjaro kernel: smpboot: CPU0: Intel(R) Core(TM) i3-9300T CPU @ 3.20GHz (family: 0x6, model: 0x9e, stepping: 0xb)
Apr 21 11:09:33 manjaro kernel: Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
Apr 21 11:09:33 manjaro kernel: ... version:                4
Apr 21 11:09:33 manjaro kernel: ... bit width:              48
Apr 21 11:09:33 manjaro kernel: ... generic registers:      8
Apr 21 11:09:33 manjaro kernel: ... value mask:             0000ffffffffffff
Apr 21 11:09:33 manjaro kernel: ... max period:             00007fffffffffff
Apr 21 11:09:33 manjaro kernel: ... fixed-purpose events:   3
Apr 21 11:09:33 manjaro kernel: ... event mask:             00000007000000ff
Apr 21 11:09:33 manjaro kernel: rcu: Hierarchical SRCU implementation.
Apr 21 11:09:33 manjaro kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
Apr 21 11:09:33 manjaro kernel: smp: Bringing up secondary CPUs ...
Apr 21 11:09:33 manjaro kernel: x86: Booting SMP configuration:
Apr 21 11:09:33 manjaro kernel: .... node  #0, CPUs:      #1 #2 #3
Apr 21 11:09:33 manjaro kernel: smp: Brought up 1 node, 4 CPUs
Apr 21 11:09:33 manjaro kernel: smpboot: Max logical packages: 1
Apr 21 11:09:33 manjaro kernel: smpboot: Total of 4 processors activated (25610.50 BogoMIPS)
Apr 21 11:09:33 manjaro kernel: devtmpfs: initialized
Apr 21 11:09:33 manjaro kernel: x86/mm: Memory block size: 128MB
Apr 21 11:09:33 manjaro kernel: PM: Registering ACPI NVS region [mem 0xc398f000-0xc3b8efff] (2097152 bytes)
Apr 21 11:09:33 manjaro kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
Apr 21 11:09:33 manjaro kernel: futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
Apr 21 11:09:33 manjaro kernel: pinctrl core: initialized pinctrl subsystem
Apr 21 11:09:33 manjaro kernel: PM: RTC time: 09:09:31, date: 2021-04-21
Apr 21 11:09:33 manjaro kernel: NET: Registered protocol family 16
Apr 21 11:09:33 manjaro kernel: DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
Apr 21 11:09:33 manjaro kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
Apr 21 11:09:33 manjaro kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
Apr 21 11:09:33 manjaro kernel: audit: initializing netlink subsys (disabled)
Apr 21 11:09:33 manjaro kernel: audit: type=2000 audit(1618996171.033:1): state=initialized audit_enabled=0 res=1
Apr 21 11:09:33 manjaro kernel: thermal_sys: Registered thermal governor 'fair_share'
Apr 21 11:09:33 manjaro kernel: thermal_sys: Registered thermal governor 'bang_bang'
Apr 21 11:09:33 manjaro kernel: thermal_sys: Registered thermal governor 'step_wise'
Apr 21 11:09:33 manjaro kernel: thermal_sys: Registered thermal governor 'user_space'
Apr 21 11:09:33 manjaro kernel: thermal_sys: Registered thermal governor 'power_allocator'
Apr 21 11:09:33 manjaro kernel: cpuidle: using governor ladder
Apr 21 11:09:33 manjaro kernel: cpuidle: using governor menu
Apr 21 11:09:33 manjaro kernel: ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
Apr 21 11:09:33 manjaro kernel: ACPI: bus type PCI registered
And now it robooted/crashed again. Did an update to latest stable 5.10 kernel, but still the same problem
Another reboot on 5.10
This is not useable. Have to start looking at an other distro
Now it crashed on kernel 5.4. Dont think it has done that before
I dont think its that bug. My computer has never crashed while I been using it. Only when I’m afk. Can leave and when I come back it has rebooted
Also I’m not on a Skylake CPU. My computer has a i3-9300T and thats a Kaby Lake CPU
Another reboot. Computer was idle. But I saw from the sofa that it rebooted
Output of: journalctl --since=ā€œ1 hour agoā€ --priority=3 & sudo dmesg -l emerg,alert,crit,err,warn
[    0.243669] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    1.119378] usb: port power management may be unreliable
[    1.459278] ata2.00: supports DRM functions and may not be fully accessible
[    1.462816] ata2.00: supports DRM functions and may not be fully accessible
[    1.606755] hid-generic 0003:045E:0823.0002: No inputs registered, leaving
[    3.197054] wmi_bus wmi_bus-PNP0C14:02: WQZZ data block query control method not found
[    3.561489] proc: Bad value for 'hidepid'
[    3.612761] proc: Bad value for 'hidepid'
[    3.697475] hp_wmi: query 0x4 returned error 0x5
[    3.705989] proc: Bad value for 'hidepid'
[    3.716326] hp_wmi: query 0xd returned error 0x5
[    3.727055] hp_wmi: query 0x1b returned error 0x5
[    4.030124] thermal thermal_zone3: failed to read out thermal zone (-61)
[    6.231256] kauditd_printk_skb: 35 callbacks suppressed
[    7.228582] proc: Bad value for 'hidepid'
[    7.612599] No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3 (or SMB2.1) specify vers=1.0 on mount.
[   14.011151] kauditd_printk_skb: 5 callbacks suppressed
I have an other thread where I ask for help with my computer that reboots when idle. But I dont get any help there so I’m gonna try again in a new thread.
My computer just rebooted 2 time last 3 hours. Happened while it has idle Ia am not using it.
I really need help fixing this
I run on a HP Elitedesk with a Manjaro Gnome fully updated
This is the logs from the latest reboot
> May 05 15:08:10 manjaro gnome-shell[1310]: [1310:1318:0505/150810.160162:ERROR:ssl_client_socket_impl.cc(947)] handshake failed; returned -1, SSL error code 1, net_error -202
> May 05 15:09:11 manjaro gnome-shell[1310]: [1310:1318:0505/150911.134469:ERROR:ssl_client_socket_impl.cc(947)] handshake failed; returned -1, SSL error code 1, net_error -202
> May 05 15:11:13 manjaro gnome-shell[1310]: [1310:1318:0505/151113.090472:ERROR:ssl_client_socket_impl.cc(947)] handshake failed; returned -1, SSL error code 1, net_error -202
> May 05 15:11:13 manjaro gnome-shell[1310]: [1310:1318:0505/151113.099350:ERROR:ssl_client_socket_impl.cc(947)] handshake failed; returned -1, SSL error code 1, net_error -202
> May 05 15:12:14 manjaro gnome-shell[1310]: [1310:1318:0505/151214.069600:ERROR:ssl_client_socket_impl.cc(947)] handshake failed; returned -1, SSL error code 1, net_error -202
> May 05 15:13:15 manjaro gnome-shell[1310]: [1310:1318:0505/151315.033641:ERROR:ssl_client_socket_impl.cc(947)] handshake failed; returned -1, SSL error code 1, net_error -202
> May 05 15:13:43 manjaro gnome-shell[1310]: [1310:1318:0505/151343.008302:ERROR:ssl_client_socket_impl.cc(947)] handshake failed; returned -1, SSL error code 1, net_error -202
> May 05 15:15:17 manjaro gnome-shell[1310]: [1310:1318:0505/151517.105782:ERROR:ssl_client_socket_impl.cc(947)] handshake failed; returned -1, SSL error code 1, net_error -202
> May 05 15:16:18 manjaro gnome-shell[1310]: [1310:1318:0505/151618.250692:ERROR:ssl_client_socket_impl.cc(947)] handshake failed; returned -1, SSL error code 1, net_error -202
> May 05 15:16:18 manjaro gnome-shell[1310]: [1310:1318:0505/151618.266704:ERROR:ssl_client_socket_impl.cc(947)] handshake failed; returned -1, SSL error code 1, net_error -202
> May 05 15:16:18 manjaro gnome-shell[1310]: [1310:1318:0505/151618.283694:ERROR:ssl_client_socket_impl.cc(947)] handshake failed; returned -1, SSL error code 1, net_error -202
> May 05 15:17:19 manjaro gnome-shell[1310]: [1310:1318:0505/151719.054366:ERROR:ssl_client_socket_impl.cc(947)] handshake failed; returned -1, SSL error code 1, net_error -202
> May 05 15:18:20 manjaro gnome-shell[1310]: [1310:1318:0505/151820.013396:ERROR:ssl_client_socket_impl.cc(947)] handshake failed; returned -1, SSL error code 1, net_error -202
> May 05 15:19:21 manjaro gnome-shell[1310]: [1310:1318:0505/151921.047486:ERROR:ssl_client_socket_impl.cc(947)] handshake failed; returned -1, SSL error code 1, net_error -202
> May 05 15:19:42 manjaro gnome-shell[674]: Ignoring excess values in shadow definition
> May 05 15:19:42 manjaro kernel: snd_hda_codec_hdmi hdaudioC0D2: HDMI: pin nid 5 not registered
> May 05 15:19:42 manjaro gnome-shell[674]: Bogus presentation time 0 travelled back in time, using current time.
> May 05 15:20:22 manjaro gnome-shell[1310]: [1310:1318:0505/152022.056476:ERROR:ssl_client_socket_impl.cc(947)] handshake failed; returned -1, SSL error code 1, net_error -202
> -- Boot eaa8503143d34484bfd09bfd5a6f3672 --
> May 05 15:22:24 manjaro kernel: Linux version 5.10.32-1-MANJARO (builduser@LEGION) (gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP Wed Apr 21 14:54:10 UTC 2021
> May 05 15:22:24 manjaro kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=3814721c-83c2-4527-890f-dd000caf568b ro quiet udev.log_priority=3
> May 05 15:22:24 manjaro kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
> May 05 15:22:24 manjaro kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
> May 05 15:22:24 manjaro kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
> May 05 15:22:24 manjaro kernel: x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
> May 05 15:22:24 manjaro kernel: x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
> May 05 15:22:24 manjaro kernel: x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
> May 05 15:22:24 manjaro kernel: x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
> May 05 15:22:24 manjaro kernel: x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
> May 05 15:22:24 manjaro kernel: x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
> May 05 15:22:24 manjaro kernel: BIOS-provided physical RAM map:
> May 05 15:22:24 manjaro kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
> May 05 15:22:24 manjaro kernel: BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
> May 05 15:22:24 manjaro kernel: BIOS-e820: [mem 0x0000000000100000-0x00000000b70f1fff] usable
> May 05 15:22:24 manjaro kernel: BIOS-e820: [mem 0x00000000b70f2000-0x00000000b70f2fff] reserved
> May 05 15:22:24 manjaro kernel: BIOS-e820: [mem 0x00000000b70f3000-0x00000000b7903fff] usable
> May 05 15:22:24 manjaro kernel: BIOS-e820: [mem 0x00000000b7904000-0x00000000b7904fff] reserved
> May 05 15:22:24 manjaro kernel: BIOS-e820: [mem 0x00000000b7905000-0x00000000c26aafff] usable
> May 05 15:22:24 manjaro kernel: BIOS-e820: [mem 0x00000000c26ab000-0x00000000c2baafff] type 20
> May 05 15:22:24 manjaro kernel: BIOS-e820: [mem 0x00000000c2bab000-0x00000000c398efff] reserved
> May 05 15:22:24 manjaro kernel: BIOS-e820: [mem 0x00000000c398f000-0x00000000c3b8efff] ACPI NVS
> May 05 15:22:24 manjaro kernel: BIOS-e820: [mem 0x00000000c3b8f000-0x00000000c3c0efff] ACPI data
> May 05 15:22:24 manjaro kernel: BIOS-e820: [mem 0x00000000c3c0f000-0x00000000c3c0ffff] usable
> May 05 15:22:24 manjaro kernel: BIOS-e820: [mem 0x00000000c3c10000-0x00000000cc7fffff] reserved
> May 05 15:22:24 manjaro kernel: BIOS-e820: [mem 0x00000000fe010000-0x00000000fe010fff] reserved
> May 05 15:22:24 manjaro kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
> May 05 15:22:24 manjaro kernel: BIOS-e820: [mem 0x0000000100000000-0x000000042f7fffff] usable
> May 05 15:22:24 manjaro kernel: NX (Execute Disable) protection: active
> May 05 15:22:24 manjaro kernel: efi: EFI v2.60 by HP
> May 05 15:22:24 manjaro kernel: efi: ACPI=0xc3c0e000 ACPI 2.0=0xc3c0e014 TPMFinalLog=0xc3b59000 SMBIOS=0xc2e75000 ESRT=0xc2e8a598 MEMATTR=0xb335c018
> May 05 15:22:24 manjaro kernel: SMBIOS 3.1 present.
> May 05 15:22:24 manjaro kernel: DMI: HP HP EliteDesk 800 G5 Desktop Mini/8595, BIOS R21 Ver. 02.08.00 12/28/2020
> May 05 15:22:24 manjaro kernel: tsc: Detected 3200.000 MHz processor
> May 05 15:22:24 manjaro kernel: tsc: Detected 3199.980 MHz TSC
> May 05 15:22:24 manjaro kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
> May 05 15:22:24 manjaro kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
> May 05 15:22:24 manjaro kernel: last_pfn = 0x42f800 max_arch_pfn = 0x400000000
> May 05 15:22:24 manjaro kernel: MTRR default type: write-back
> May 05 15:22:24 manjaro kernel: MTRR fixed ranges enabled:
> May 05 15:22:24 manjaro kernel:   00000-9FFFF write-back
> May 05 15:22:24 manjaro kernel:   A0000-BFFFF uncachable
> May 05 15:22:24 manjaro kernel:   C0000-FFFFF write-protect
> May 05 15:22:24 manjaro kernel: MTRR variable ranges enabled:
> May 05 15:22:24 manjaro kernel:   0 base 00E0000000 mask 7FE0000000 uncachable
> May 05 15:22:24 manjaro kernel:   1 base 00D0000000 mask 7FF0000000 uncachable
> May 05 15:22:24 manjaro kernel:   2 base 00C8000000 mask 7FF8000000 uncachable
> May 05 15:22:24 manjaro kernel:   3 base 2000000000 mask 6000000000 uncachable
> May 05 15:22:24 manjaro kernel:   4 base 1000000000 mask 7000000000 uncachable
> May 05 15:22:24 manjaro kernel:   5 base 0800000000 mask 7800000000 uncachable
> May 05 15:22:24 manjaro kernel:   6 base 4000000000 mask 4000000000 uncachable
> May 05 15:22:24 manjaro kernel:   7 disabled
> May 05 15:22:24 manjaro kernel:   8 disabled
> May 05 15:22:24 manjaro kernel:   9 disabled
> May 05 15:22:24 manjaro kernel: x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
> May 05 15:22:24 manjaro kernel: last_pfn = 0xc3c10 max_arch_pfn = 0x400000000
> May 05 15:22:24 manjaro kernel: esrt: Reserving ESRT space from 0x00000000c2e8a598 to 0x00000000c2e8a5d0.
> May 05 15:22:24 manjaro kernel: check: Scanning 1 areas for low memory corruption
> May 05 15:22:24 manjaro kernel: Using GB pages for direct mapping
> May 05 15:22:24 manjaro kernel: Secure boot disabled
> May 05 15:22:24 manjaro kernel: RAMDISK: [mem 0x36b2f000-0x3758efff]
> May 05 15:22:24 manjaro kernel: ACPI: Early table checksum verification disabled
> May 05 15:22:24 manjaro kernel: ACPI: RSDP 0x00000000C3C0E014 000024 (v02 HPQOEM)
> May 05 15:22:24 manjaro kernel: ACPI: XSDT 0x00000000C3BD4188 0000FC (v01 HPQOEM SLIC-BPC 00000000 INTL 20160422)
> May 05 15:22:24 manjaro kernel: ACPI: FACP 0x00000000C3C05000 000114 (v06 HPQOEM SLIC-BPC 00000000 HP   00000001)
> May 05 15:22:24 manjaro kernel: ACPI: DSDT 0x00000000C3BE2000 01F476 (v02 HPQOEM 8595     00000000 INTL 20160527)
> May 05 15:22:24 manjaro kernel: ACPI: FACS 0x00000000C3B55000 000040
> May 05 15:22:24 manjaro kernel: ACPI: SSDT 0x00000000C3C0C000 00012A (v02 HP     ShmTable 00000001 INTL 20160527)
> May 05 15:22:24 manjaro kernel: ACPI: SSDT 0x00000000C3C0A000 001B60 (v02 CpuRef CpuSsdt  00003000 INTL 20160527)
> May 05 15:22:24 manjaro kernel: ACPI: SSDT 0x00000000C3C09000 0009CF (v02 CtdpB  CtdpB    00001000 INTL 20160527)
> May 05 15:22:24 manjaro kernel: ACPI: MSDM 0x00000000C3C08000 000055 (v03 HPQOEM SLIC-BPC 00000000 HP   00000001)
> May 05 15:22:24 manjaro kernel: ACPI: SLIC 0x00000000C3C07000 000176 (v01 HPQOEM SLIC-BPC 00000001 HP   00000001)
> May 05 15:22:24 manjaro kernel: ACPI: WSMT 0x00000000C3C06000 000028 (v01 HPQOEM 8595     00000001 HP   00000001)
> May 05 15:22:24 manjaro kernel: ACPI: HPET 0x00000000C3C04000 000038 (v01 HPQOEM 8595     00000001 HP   00000001)
> May 05 15:22:24 manjaro kernel: ACPI: APIC 0x00000000C3C03000 00012C (v03 HPQOEM 8595     00000001 HP   00000001)
> May 05 15:22:24 manjaro kernel: ACPI: MCFG 0x00000000C3C02000 00003C (v01 HPQOEM 8595     00000001 HP   00000001)
> May 05 15:22:24 manjaro kernel: ACPI: SSDT 0x00000000C3BE1000 000734 (v01 HPQOEM PtidDevc 00001000 INTL 20160527)
> May 05 15:22:24 manjaro kernel: ACPI: SSDT 0x00000000C3BE0000 000E5B (v02 HPQOEM HP_XHC_P 00000000 INTL 20160527)
> May 05 15:22:24 manjaro kernel: ACPI: SSDT 0x00000000C3BDC000 003147 (v02 SaSsdt SaSsdt   00003000 INTL 20160527)
> May 05 15:22:24 manjaro kernel: ACPI: LPIT 0x00000000C3BDB000 000094 (v01 INTEL  CFL      20170001 INTL 20160422)
> May 05 15:22:24 manjaro kernel: ACPI: WSMT 0x00000000C3BDA000 000028 (v01 INTEL  CFL      20170001 INTL 20160422)
> May 05 15:22:24 manjaro kernel: ACPI: SSDT 0x00000000C3BD9000 0003CE (v02 INTEL  Tpm2Tabl 00001000 INTL 20160527)
> May 05 15:22:24 manjaro kernel: ACPI: TPM2 0x00000000C3BD8000 000034 (v04 INTEL  CFL      20170001 INTL 20160422)
> May 05 15:22:24 manjaro kernel: ACPI: UEFI 0x00000000C3B4E000 000042 (v01 INTEL  CFL      20170001 INTL 20160422)
> May 05 15:22:24 manjaro kernel: ACPI: OEML 0x00000000C3BD7000 000028 (v03 INTEL  CFL      20170001 INTL 20160422)
> May 05 15:22:24 manjaro kernel: ACPI: SSDT 0x00000000C3BD6000 0003DF (v02 Intel  UcsiAcpi 00001000 INTL 20160527)
> May 05 15:22:24 manjaro kernel: ACPI: SSDT 0x00000000C3BC6000 00D379 (v01 HP     HPINDTWL 00001000 INTL 20160527)
> May 05 15:22:24 manjaro kernel: ACPI: SSDT 0x00000000C3C0D000 000032 (v01 HP     HPCONDEV 00001000 INTL 20160527)
> May 05 15:22:24 manjaro kernel: ACPI: SSDT 0x00000000C3BC5000 000069 (v01 HP     HPCAHWID 00001000 INTL 20160527)
> May 05 15:22:24 manjaro kernel: ACPI: ASF! 0x00000000C3BC4000 0000A0 (v32 HPQOEM  UYAMIHC 20170001 INTL 20160422)
> May 05 15:22:24 manjaro kernel: ACPI: DMAR 0x00000000C3BD5000 0000C8 (v01 INTEL  CFL      00000002      01000013)
> May 05 15:22:24 manjaro kernel: ACPI: FPDT 0x00000000C3BC3000 000044 (v01 INTEL  CFL      20170001 INTL 20160422)
> May 05 15:22:24 manjaro kernel: ACPI: BGRT 0x00000000C3BC2000 000038 (v01 INTEL  CFL      20170001 INTL 20160422)
> May 05 15:22:24 manjaro kernel: ACPI: Reserving FACP table memory at [mem 0xc3c05000-0xc3c05113]
> May 05 15:22:24 manjaro kernel: ACPI: Reserving DSDT table memory at [mem 0xc3be2000-0xc3c01475]
> May 05 15:22:24 manjaro kernel: ACPI: Reserving FACS table memory at [mem 0xc3b55000-0xc3b5503f]
> May 05 15:22:24 manjaro kernel: ACPI: Reserving SSDT table memory at [mem 0xc3c0c000-0xc3c0c129]
> May 05 15:22:24 manjaro kernel: ACPI: Reserving SSDT table memory at [mem 0xc3c0a000-0xc3c0bb5f]
> May 05 15:22:24 manjaro kernel: ACPI: Reserving SSDT table memory at [mem 0xc3c09000-0xc3c099ce]
> May 05 15:22:24 manjaro kernel: ACPI: Reserving MSDM table memory at [mem 0xc3c08000-0xc3c08054]
> May 05 15:22:24 manjaro kernel: ACPI: Reserving SLIC table memory at [mem 0xc3c07000-0xc3c07175]
> May 05 15:22:24 manjaro kernel: ACPI: Reserving WSMT table memory at [mem 0xc3c06000-0xc3c06027]
> May 05 15:22:24 manjaro kernel: ACPI: Reserving HPET table memory at [mem 0xc3c04000-0xc3c04037]
> May 05 15:22:24 manjaro kernel: ACPI: Reserving APIC table memory at [mem 0xc3c03000-0xc3c0312b]
> May 05 15:22:24 manjaro kernel: ACPI: Reserving MCFG table memory at [mem 0xc3c02000-0xc3c0203b]
> May 05 15:22:24 manjaro kernel: ACPI: Reserving SSDT table memory at [mem 0xc3be1000-0xc3be1733]
> May 05 15:22:24 manjaro kernel: ACPI: Reserving SSDT table memory at [mem 0xc3be0000-0xc3be0e5a]
> May 05 15:22:24 manjaro kernel: ACPI: Reserving SSDT table memory at [mem 0xc3bdc000-0xc3bdf146]
> May 05 15:22:24 manjaro kernel: ACPI: Reserving LPIT table memory at [mem 0xc3bdb000-0xc3bdb093]
> May 05 15:22:24 manjaro kernel: ACPI: Reserving WSMT table memory at [mem 0xc3bda000-0xc3bda027]
> May 05 15:22:24 manjaro kernel: ACPI: Reserving SSDT table memory at [mem 0xc3bd9000-0xc3bd93cd]
> May 05 15:22:24 manjaro kernel: ACPI: Reserving TPM2 table memory at [mem 0xc3bd8000-0xc3bd8033]
> May 05 15:22:24 manjaro kernel: ACPI: Reserving UEFI table memory at [mem 0xc3b4e000-0xc3b4e041]
> May 05 15:22:24 manjaro kernel: ACPI: Reserving OEML table memory at [mem 0xc3bd7000-0xc3bd7027]
> May 05 15:22:24 manjaro kernel: ACPI: Reserving SSDT table memory at [mem 0xc3bd6000-0xc3bd63de]
> May 05 15:22:24 manjaro kernel: ACPI: Reserving SSDT table memory at [mem 0xc3bc6000-0xc3bd3378]
> May 05 15:22:24 manjaro kernel: ACPI: Reserving SSDT table memory at [mem 0xc3c0d000-0xc3c0d031]
> May 05 15:22:24 manjaro kernel: ACPI: Reserving SSDT table memory at [mem 0xc3bc5000-0xc3bc5068]
> May 05 15:22:24 manjaro kernel: ACPI: Reserving ASF! table memory at [mem 0xc3bc4000-0xc3bc409f]
> May 05 15:22:24 manjaro kernel: ACPI: Reserving DMAR table memory at [mem 0xc3bd5000-0xc3bd50c7]
> May 05 15:22:24 manjaro kernel: ACPI: Reserving FPDT table memory at [mem 0xc3bc3000-0xc3bc3043]
> May 05 15:22:24 manjaro kernel: ACPI: Reserving BGRT table memory at [mem 0xc3bc2000-0xc3bc2037]
> May 05 15:22:24 manjaro kernel: ACPI: Local APIC address 0xfee00000
> May 05 15:22:24 manjaro kernel: No NUMA configuration found
> May 05 15:22:24 manjaro kernel: Faking a node at [mem 0x0000000000000000-0x000000042f7fffff]
> May 05 15:22:24 manjaro kernel: NODE_DATA(0) allocated [mem 0x42f7fc000-0x42f7fffff]
> May 05 15:22:24 manjaro kernel: Zone ranges:
> May 05 15:22:24 manjaro kernel:   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
> May 05 15:22:24 manjaro kernel:   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
> May 05 15:22:24 manjaro kernel:   Normal   [mem 0x0000000100000000-0x000000042f7fffff]
> May 05 15:22:24 manjaro kernel:   Device   empty
> May 05 15:22:24 manjaro kernel: Movable zone start for each node
> May 05 15:22:24 manjaro kernel: Early memory node ranges
> May 05 15:22:24 manjaro kernel:   node   0: [mem 0x0000000000001000-0x000000000009efff]
> May 05 15:22:24 manjaro kernel:   node   0: [mem 0x0000000000100000-0x00000000b70f1fff]
> May 05 15:22:24 manjaro kernel:   node   0: [mem 0x00000000b70f3000-0x00000000b7903fff]
> May 05 15:22:24 manjaro kernel:   node   0: [mem 0x00000000b7905000-0x00000000c26aafff]
> May 05 15:22:24 manjaro kernel:   node   0: [mem 0x00000000c3c0f000-0x00000000c3c0ffff]
> May 05 15:22:24 manjaro kernel:   node   0: [mem 0x0000000100000000-0x000000042f7fffff]
> May 05 15:22:24 manjaro kernel: Initmem setup node 0 [mem 0x0000000000001000-0x000000042f7fffff]
> May 05 15:22:24 manjaro kernel: On node 0 totalpages: 4136520
> May 05 15:22:24 manjaro kernel:   DMA zone: 64 pages used for memmap
> May 05 15:22:24 manjaro kernel:   DMA zone: 22 pages reserved
> May 05 15:22:24 manjaro kernel:   DMA zone: 3998 pages, LIFO batch:0
> May 05 15:22:24 manjaro kernel:   DMA zone: 28770 pages in unavailable ranges
> May 05 15:22:24 manjaro kernel:   DMA32 zone: 12379 pages used for memmap
> May 05 15:22:24 manjaro kernel:   DMA32 zone: 792234 pages, LIFO batch:63
> May 05 15:22:24 manjaro kernel:   DMA32 zone: 22870 pages in unavailable ranges
> May 05 15:22:24 manjaro kernel:   Normal zone: 52192 pages used for memmap
> May 05 15:22:24 manjaro kernel:   Normal zone: 3340288 pages, LIFO batch:63
> May 05 15:22:24 manjaro kernel:   Normal zone: 2048 pages in unavailable ranges
> May 05 15:22:24 manjaro kernel: Reserving Intel graphics memory at [mem 0xc8800000-0xcc7fffff]
> May 05 15:22:24 manjaro kernel: ACPI: PM-Timer IO Port: 0x1808
> May 05 15:22:24 manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
> May 05 15:22:24 manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
> May 05 15:22:24 manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
> May 05 15:22:24 manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
> May 05 15:22:24 manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
> May 05 15:22:24 manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
> May 05 15:22:24 manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
> May 05 15:22:24 manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
> May 05 15:22:24 manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
> May 05 15:22:24 manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
> May 05 15:22:24 manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
> May 05 15:22:24 manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
> May 05 15:22:24 manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
> May 05 15:22:24 manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
> May 05 15:22:24 manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
> May 05 15:22:24 manjaro kernel: ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
> May 05 15:22:24 manjaro kernel: IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
> May 05 15:22:24 manjaro kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
> May 05 15:22:24 manjaro kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
> May 05 15:22:24 manjaro kernel: ACPI: IRQ0 used by override.
> May 05 15:22:24 manjaro kernel: ACPI: IRQ9 used by override.
> May 05 15:22:24 manjaro kernel: Using ACPI (MADT) for SMP configuration information
> May 05 15:22:24 manjaro kernel: ACPI: HPET id: 0x8086a201 base: 0xfed00000
> May 05 15:22:24 manjaro kernel: e820: update [mem 0xb2157000-0xb21a1fff] usable ==> reserved
> May 05 15:22:24 manjaro kernel: TSC deadline timer available
> May 05 15:22:24 manjaro kernel: smpboot: Allowing 4 CPUs, 0 hotplug CPUs
> May 05 15:22:24 manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
> May 05 15:22:24 manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
> May 05 15:22:24 manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0xb2157000-0xb21a1fff]
> May 05 15:22:24 manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0xb70f2000-0xb70f2fff]
> May 05 15:22:24 manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0xb7904000-0xb7904fff]
> May 05 15:22:24 manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0xc26ab000-0xc2baafff]
> May 05 15:22:24 manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0xc2bab000-0xc398efff]
> May 05 15:22:24 manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0xc398f000-0xc3b8efff]
> May 05 15:22:24 manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0xc3b8f000-0xc3c0efff]
> May 05 15:22:24 manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0xc3c10000-0xcc7fffff]
> May 05 15:22:24 manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0xcc800000-0xfe00ffff]
> May 05 15:22:24 manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0xfe010000-0xfe010fff]
> May 05 15:22:24 manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xfeffffff]
> May 05 15:22:24 manjaro kernel: PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
> May 05 15:22:24 manjaro kernel: [mem 0xcc800000-0xfe00ffff] available for PCI devices
> May 05 15:22:24 manjaro kernel: Booting paravirtualized kernel on bare hardware
> May 05 15:22:24 manjaro kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
> May 05 15:22:24 manjaro kernel: setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:4 nr_node_ids:1
> May 05 15:22:24 manjaro kernel: percpu: Embedded 55 pages/cpu s188416 r8192 d28672 u524288
> May 05 15:22:24 manjaro kernel: pcpu-alloc: s188416 r8192 d28672 u524288 alloc=1*2097152
> May 05 15:22:24 manjaro kernel: pcpu-alloc: [0] 0 1 2 3
> May 05 15:22:24 manjaro kernel: Built 1 zonelists, mobility grouping on.  Total pages: 4071863
> May 05 15:22:24 manjaro kernel: Policy zone: Normal
> May 05 15:22:24 manjaro kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=3814721c-83c2-4527-890f-dd000caf568b ro quiet udev.log_priority=3
> May 05 15:22:24 manjaro kernel: Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
> May 05 15:22:24 manjaro kernel: Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
> May 05 15:22:24 manjaro kernel: mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
> May 05 15:22:24 manjaro kernel: Memory: 16016012K/16546080K available (14344K kernel code, 2055K rwdata, 4792K rodata, 1724K init, 4292K bss, 529808K reserved, 0K cma-reserved)
> May 05 15:22:24 manjaro kernel: random: get_random_u64 called from __kmem_cache_create+0x26/0x520 with crng_init=0
> May 05 15:22:24 manjaro kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
> May 05 15:22:24 manjaro kernel: Kernel/User page tables isolation: enabled
> May 05 15:22:24 manjaro kernel: ftrace: allocating 41708 entries in 163 pages
> May 05 15:22:24 manjaro kernel: ftrace: allocated 163 pages with 4 groups
> May 05 15:22:24 manjaro kernel: rcu: Hierarchical RCU implementation.
> May 05 15:22:24 manjaro kernel: rcu:         RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
> May 05 15:22:24 manjaro kernel:         Rude variant of Tasks RCU enabled.
> May 05 15:22:24 manjaro kernel:         Tracing variant of Tasks RCU enabled.
> May 05 15:22:24 manjaro kernel: rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
> May 05 15:22:24 manjaro kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
> May 05 15:22:24 manjaro kernel: NR_IRQS: 20736, nr_irqs: 1024, preallocated irqs: 16
> May 05 15:22:24 manjaro kernel: Console: colour dummy device 80x25
> May 05 15:22:24 manjaro kernel: printk: console [tty0] enabled
> May 05 15:22:24 manjaro kernel: ACPI: Core revision 20200925
> May 05 15:22:24 manjaro kernel: clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
> May 05 15:22:24 manjaro kernel: APIC: Switch to symmetric I/O mode setup
> May 05 15:22:24 manjaro kernel: DMAR: Host address width 39
> May 05 15:22:24 manjaro kernel: DMAR: DRHD base: 0x000000fed90000 flags: 0x0
> May 05 15:22:24 manjaro kernel: DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
> May 05 15:22:24 manjaro kernel: DMAR: DRHD base: 0x000000fed91000 flags: 0x1
> May 05 15:22:24 manjaro kernel: DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
> May 05 15:22:24 manjaro kernel: DMAR: RMRR base: 0x000000c381e000 end: 0x000000c383dfff
> May 05 15:22:24 manjaro kernel: DMAR: RMRR base: 0x000000c8000000 end: 0x000000cc7fffff
> May 05 15:22:24 manjaro kernel: DMAR: RMRR base: 0x000000c386f000 end: 0x000000c38eefff
> May 05 15:22:24 manjaro kernel: DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
> May 05 15:22:24 manjaro kernel: DMAR-IR: HPET id 0 under DRHD base 0xfed91000
> May 05 15:22:24 manjaro kernel: DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
> May 05 15:22:24 manjaro kernel: DMAR-IR: Enabled IRQ remapping in x2apic mode
> May 05 15:22:24 manjaro kernel: x2apic enabled
> May 05 15:22:24 manjaro kernel: Switched APIC routing to cluster x2apic.
> May 05 15:22:24 manjaro kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
> May 05 15:22:24 manjaro kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2e2036ff8d5, max_idle_ns: 440795275316 ns
> May 05 15:22:24 manjaro kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 6399.96 BogoMIPS (lpj=31999800)
> May 05 15:22:24 manjaro kernel: pid_max: default: 32768 minimum: 301
> May 05 15:22:24 manjaro kernel: LSM: Security Framework initializing
> May 05 15:22:24 manjaro kernel: Yama: becoming mindful.
> May 05 15:22:24 manjaro kernel: Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
> May 05 15:22:24 manjaro kernel: Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
> May 05 15:22:24 manjaro kernel: mce: CPU0: Thermal monitoring enabled (TM1)
> May 05 15:22:24 manjaro kernel: process: using mwait in idle threads
> May 05 15:22:24 manjaro kernel: Last level iTLB entries: 4KB 128, 2MB 8, 4MB 8
> May 05 15:22:24 manjaro kernel: Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
> May 05 15:22:24 manjaro kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
> May 05 15:22:24 manjaro kernel: Spectre V2 : Mitigation: Full generic retpoline
> May 05 15:22:24 manjaro kernel: Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
> May 05 15:22:24 manjaro kernel: Spectre V2 : Enabling Restricted Speculation for firmware calls
> May 05 15:22:24 manjaro kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier```
Hi @niclasc,
I’m in no way an expert, so I might be wrong. However, this:
leads me to think it might have something to do with hibernation. Is it enabled? If so, have you tried disabling it to see if it makes a difference?
Hope it helps!
What command did you use to get/create that log?
This looks like (part of) a normal boot log.
We would probably need the log of the prior boot and subsequent shutdown.
… to perhaps see what made it shut down … on it’s own …
journalctl
was probably used
man journalctl
journalctl --list-boots
the -b parameter selects the boot protocol
0 is current
-1 the one before
run it via sudo - it sometimes gives more info
(can’t describe the obvious difference better)
