I am having the same problem, also with Kaby Lake and Intel-only graphics. The system only reboots unexpectedly while idle, so I hardly ever see it happen.
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=f2aa7cd8-38da-49a0-b318-3592b2a7850c rw quiet apparmor=1
Desktop: Cinnamon 5.0.5 tk: GTK 3.24.30 vt: 7 dm: LightDM 1.30.0
Type: Desktop System: System76 product: Meerkat v: meer4 serial: <filter>
Chassis: type: 3 v: meer4 serial: <filter>
Mobo: Intel model: NUC8BEB v: J72692-306 serial: <filter> UEFI: Intel
v: BECFL357.86A.0071.2019.0510.1505 date: 05/10/2019
RAM: total: 7.64 GiB used: 4.83 GiB (63.2%)
Info: Quad Core model: Intel Core i5-8259U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: EA cache: L2: 6 MiB bogomips: 36812
Speed: 3701 MHz min/max: 400/3800 MHz Core speeds (MHz): 1: 3701 2: 3654
3: 3781 4: 3665 5: 3757 6: 3783 7: 3744 8: 3763
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel CoffeeLake-U GT3e [Iris Plus Graphics 655] driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:3ea5 class-ID: 0300
Display: x11 server: X.Org 1.20.13 driver: loaded: modesetting
alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 48 s-size: 2032x1143mm (80.0x45.0")
s-diag: 2331mm (91.8")
Monitor-1: DP-1 res: 3840x2160 hz: 60 dpi: 157 size: 621x341mm (24.4x13.4")
diag: 708mm (27.9")
OpenGL: renderer: Mesa Intel Iris Plus Graphics 655 (CFL GT3)
v: 4.6 Mesa 21.2.3 direct render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio driver: snd_hda_intel
chip-ID: 8086:9dc8 class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: no
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
Device-2: Intel Ethernet I219-V driver: e1000e v: kernel port: N/A
bus-ID: 00:1f.6 chip-ID: 8086:15be class-ID: 0200
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-10:4 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 232.89 GiB used: 174.75 GiB (75.0%)
model: SSD 970 EVO Plus 250GB size: 232.89 GiB block-size: physical: 512 B
rev: 1B2QEXM7 temp: 39.9 C scheme: GPT
ID-1: / raw-size: 228.38 GiB size: 223.8 GiB (97.99%)
used: 174.75 GiB (78.1%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
label: ROOT uuid: f2aa7cd8-38da-49a0-b318-3592b2a7850c
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 0F05-C403
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 4 GiB fs: vfat label: RECOVERY
uuid: 03D3-F805
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-3:2 info: Logitech K840 Mechanical Corded Keyboard
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 98mA chip-ID: 046d:c33b class-ID: 0300
serial: <filter>
Device-2: 1-4:3 info: Logitech Optical Wheel Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 046d:c018 class-ID: 0301
Device-3: 1-10:4 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 58.0 C mobo: 27.8 C
Processes: 235 Uptime: 30m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1082 lib: 280 flatpak: 0
Shell: Bash v: 5.1.8 running-in: gnome-terminal inxi: 3.3.07
journalctl -b -1 --catalog --priority=4
-- Journal begins at Tue 2021-10-12 21:18:16 CDT, ends at Sun 2021-10-17 19:46:36 CDT. --
Oct 16 20:06:40 LasCruces kernel: x86/cpu: SGX disabled by BIOS.
Oct 16 20:06:40 LasCruces kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Oct 16 20:06:40 LasCruces kernel: #5 #6 #7
Oct 16 20:06:40 LasCruces kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Oct 16 20:06:40 LasCruces kernel: nvme nvme0: missing or invalid SUBNQN field.
Oct 16 20:06:40 LasCruces kernel: usb: port power management may be unreliable
Oct 16 20:06:40 LasCruces kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
Oct 16 20:06:40 LasCruces kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
Oct 16 20:06:40 LasCruces kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 0
Oct 16 20:06:40 LasCruces kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 1
Oct 16 20:06:40 LasCruces kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 2
Oct 16 20:06:40 LasCruces kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 3
Oct 16 20:06:40 LasCruces kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 4
Oct 16 20:06:40 LasCruces kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 6
Oct 16 20:06:40 LasCruces kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 8
Oct 16 20:06:40 LasCruces kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 9
Oct 16 20:06:40 LasCruces kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 10
Oct 16 20:06:40 LasCruces kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 11
Oct 16 20:06:40 LasCruces kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 15
Oct 16 20:06:40 LasCruces kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 16
Oct 16 20:06:40 LasCruces kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 18
Oct 16 20:06:40 LasCruces kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 19
Oct 16 20:06:40 LasCruces kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 20
Oct 16 20:06:40 LasCruces kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 21
Oct 16 20:06:40 LasCruces kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 28
Oct 16 20:06:40 LasCruces systemd[1]: lightdm.service: Failed with result 'exit-code'.
ββ Subject: Unit failed
ββ Defined-By: systemd
ββ Support: https://forum.manjaro.org/c/support
ββ
ββ The unit lightdm.service has entered the 'failed' state with result 'exit-code'.
Oct 16 20:06:41 LasCruces systemd[1]: systemd-rfkill.socket: Socket service systemd-rfkill.service not loaded, refusing.
Oct 16 20:06:41 LasCruces systemd[1]: Failed to listen on Load/Save RF Kill Switch Status /dev/rfkill Watch.
ββ Subject: A start job for unit systemd-rfkill.socket has failed
ββ
ββ A start job for unit systemd-rfkill.socket has finished with a failure.
ββ
ββ The job identifier is 471 and the job result is failed.
Oct 16 20:06:41 LasCruces systemd[1]: lightdm.service: Failed with result 'exit-code'.
ββ
Oct 16 20:06:41 LasCruces kernel: thermal thermal_zone3: failed to read out thermal zone (-61)
ββ
Oct 16 20:06:41 LasCruces systemd-udevd[307]: could not read from '/sys/module/pcc_cpufreq/initstate': No such device
Oct 16 20:06:41 LasCruces kernel: snd_hda_codec_hdmi hdaudioC0D2: Monitor plugged-in, Failed to power up codec ret=[-13]
Oct 16 20:06:43 LasCruces kernel: Bluetooth: hci0: MSFT filter_enable is already on
Oct 16 20:06:43 LasCruces systemd-logind[376]: /etc/systemd/sleep.conf.d/disable-hibernate.conf:1: Assignment outside of section. Ignoring.
Oct 16 20:06:43 LasCruces kernel: kauditd_printk_skb: 64 callbacks suppressed
Oct 16 20:11:00 LasCruces lightdm[812]: gkr-pam: unable to locate daemon control file
Oct 16 20:11:00 LasCruces systemd-xdg-autostart-generator[852]: /home/ben/.config/autostart/transmission-gtk.desktop:16: Unknown key name 'Actions' in section 'Desktop Entry', ignoring.
Oct 16 20:11:00 LasCruces systemd-xdg-autostart-generator[852]: /home/ben/.config/autostart/transmission-gtk.desktop:24: Unknown section 'Desktop Action Pause'. Ignoring.
Oct 16 20:11:00 LasCruces systemd-xdg-autostart-generator[852]: /home/ben/.config/autostart/transmission-gtk.desktop:28: Unknown section 'Desktop Action Minimize'. Ignoring.
Oct 16 20:11:01 LasCruces pulseaudio[969]: stat('/etc/pulse/default.pa.d'): No such file or directory
Oct 16 20:11:02 LasCruces cinnamon-session[860]: WARNING: t+1.75453s: Detected that screensaver has appeared on the bus
Oct 16 20:11:10 LasCruces kernel: kauditd_printk_skb: 16 callbacks suppressed
Oct 16 20:11:12 LasCruces cinnamon-session[860]: WARNING: t+11.75464s: Detected that screensaver has left the bus
Oct 16 22:12:45 LasCruces cinnamon-session[860]: WARNING: t+7304.24036s: Detected that screensaver has appeared on the bus
Oct 16 22:38:41 LasCruces cinnamon-session[860]: WARNING: t+8860.58739s: Detected that screensaver has left the bus
Oct 16 22:38:41 LasCruces org.cinnamon.ScreenSaver[2780]: Error in sys.excepthook:
Oct 16 22:38:41 LasCruces org.cinnamon.ScreenSaver[2780]: Original exception was:
Oct 16 23:49:15 LasCruces cinnamon-session[860]: WARNING: t+13094.42184s: Detected that screensaver has appeared on the bus
Oct 16 23:57:30 LasCruces cinnamon-session[860]: WARNING: t+13589.84620s: Detected that screensaver has left the bus
Oct 16 23:57:30 LasCruces org.cinnamon.ScreenSaver[3605]: Error in sys.excepthook:
Oct 16 23:57:30 LasCruces org.cinnamon.ScreenSaver[3605]: Original exception was:
Oct 17 00:07:23 LasCruces systemd-logind[376]: /etc/systemd/sleep.conf.d/disable-hibernate.conf:1: Assignment outside of section. Ignoring.
Oct 17 00:07:27 LasCruces systemd-logind[376]: /etc/systemd/sleep.conf.d/disable-hibernate.conf:1: Assignment outside of section. Ignoring.
Oct 17 00:07:28 LasCruces cinnamon-session[860]: WARNING: t+14187.21526s: Detected that screensaver has appeared on the bus
Oct 17 00:07:28 LasCruces systemd-sleep[4028]: /etc/systemd/sleep.conf.d/disable-hibernate.conf:1: Assignment outside of section. Ignoring.
Oct 17 13:03:27 LasCruces kernel: IRQ 142: no longer affine to CPU1
Oct 17 13:03:27 LasCruces kernel: IRQ 143: no longer affine to CPU2
Oct 17 13:03:27 LasCruces kernel: IRQ 144: no longer affine to CPU3
Oct 17 13:03:27 LasCruces kernel: done.
Oct 17 13:03:27 LasCruces kernel: thermal thermal_zone3: failed to read out thermal zone (-61)
Oct 17 13:03:50 LasCruces cinnamon-session[860]: WARNING: t+14212.74532s: Detected that screensaver has left the bus
Oct 17 13:03:50 LasCruces org.cinnamon.ScreenSaver[3997]: Error in sys.excepthook:
Oct 17 13:03:50 LasCruces org.cinnamon.ScreenSaver[3997]: Original exception was:
Oct 17 14:35:14 LasCruces devhelp[5673]: The file 'file:///usr/share/gtk-doc/html/libxml2/libxml2.devhelp' uses the Devhelp index file format version 1, which is deprecated. A future version of Devhelp may remove the support for the format version 1. The index file should be ported to the Devhelp index file format version 2.
Oct 17 14:35:14 LasCruces org.gnome.Devhelp[5694]: (WebKitWebProcess:2): dbind-WARNING **: 14:35:14.715: Couldn't connect to accessibility bus: Failed to connect to socket /tmp/dbus-KNGE44KMT7: No such file or directory
Oct 17 18:42:30 LasCruces cinnamon-session[860]: WARNING: t+34532.23361s: Detected that screensaver has appeared on the bus
sudo dmesg --until β2021-10-17 19:28:34β --level emerg,alert,crit,err,warn
[ 0.160048] x86/cpu: SGX disabled by BIOS.
[ 0.174634] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 0.174634] #5 #6 #7
[ 0.181175] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.503993] nvme nvme0: missing or invalid SUBNQN field.
[ 1.089914] usb: port power management may be unreliable
[ 2.927438] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[ 2.927548] acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[ 3.203069] iwlwifi 0000:00:14.3: WRT: Overriding region id 0
[ 3.203072] iwlwifi 0000:00:14.3: WRT: Overriding region id 1
[ 3.203074] iwlwifi 0000:00:14.3: WRT: Overriding region id 2
[ 3.203076] iwlwifi 0000:00:14.3: WRT: Overriding region id 3
[ 3.203077] iwlwifi 0000:00:14.3: WRT: Overriding region id 4
[ 3.203078] iwlwifi 0000:00:14.3: WRT: Overriding region id 6
[ 3.203079] iwlwifi 0000:00:14.3: WRT: Overriding region id 8
[ 3.203081] iwlwifi 0000:00:14.3: WRT: Overriding region id 9
[ 3.203082] iwlwifi 0000:00:14.3: WRT: Overriding region id 10
[ 3.203083] iwlwifi 0000:00:14.3: WRT: Overriding region id 11
[ 3.203084] iwlwifi 0000:00:14.3: WRT: Overriding region id 15
[ 3.203086] iwlwifi 0000:00:14.3: WRT: Overriding region id 16
[ 3.203087] iwlwifi 0000:00:14.3: WRT: Overriding region id 18
[ 3.203088] iwlwifi 0000:00:14.3: WRT: Overriding region id 19
[ 3.203090] iwlwifi 0000:00:14.3: WRT: Overriding region id 20
[ 3.203091] iwlwifi 0000:00:14.3: WRT: Overriding region id 21
[ 3.203093] iwlwifi 0000:00:14.3: WRT: Overriding region id 28
[ 3.438739] thermal thermal_zone3: failed to read out thermal zone (-61)
[ 4.130626] snd_hda_codec_hdmi hdaudioC0D2: Monitor plugged-in, Failed to power up codec ret=[-13]
[ 5.252910] kauditd_printk_skb: 58 callbacks suppressed
[ 6.004727] Bluetooth: hci0: MSFT filter_enable is already on
[ 386.175387] kauditd_printk_skb: 16 callbacks suppressed
/var/log/Xorg.0.log.old
[ 3.693]
X.Org X Server 1.20.13
[ 3.693] Build Operating System: Linux Manjaro Linux
[ 3.693] Current Operating System: Linux LasCruces 5.13.19-2-MANJARO #1 SMP PREEMPT Sun Sep 19 21:31:53 UTC 2021 x86_64
[ 3.693] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64 root=UUID=f2aa7cd8-38da-49a0-b318-3592b2a7850c rw quiet apparmor=1 security=apparmor udev.log_priority=3
[ 3.693] Build Date: 24 August 2021 10:21:29AM
[ 3.693]
[ 3.693] Current version of pixman: 0.40.0
[ 3.693] Before reporting problems, check http://wiki.x.org
[ 3.693] Markers: (--) probed, (**) from config file, (==) default setting,
[ 3.693] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Oct 17 19:28:35 2021
[ 3.693] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 3.693] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 3.693] (==) No Layout section. Using the first Screen section.
[ 3.693] (==) No screen section available. Using defaults.
[ 3.693] (**) |-->Screen "Default Screen Section" (0)
[ 3.693] (**) | |-->Monitor "<default monitor>"
[ 3.693] (==) No monitor specified for screen "Default Screen Section".
[ 3.693] (==) Automatically adding devices
[ 3.693] (==) Automatically enabling devices
[ 3.693] (==) Automatically adding GPU devices
[ 3.693] (==) Automatically binding GPU devices
[ 3.693] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 3.693] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/misc".
[ 3.693] Entry deleted from font path.
[ 3.693] (Run 'mkfontdir' on "/usr/share/fonts/misc").
[ 3.693] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[ 3.693] (Run 'mkfontdir' on "/usr/share/fonts/TTF").
[ 3.693] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 3.693] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 3.693] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 3.693] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 3.693] (==) FontPath set to:
[ 3.693] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 3.693] (II) The server relies on udev to provide the list of input devices.
[ 3.693] (II) Module ABI versions:
[ 3.693] X.Org ANSI C Emulation: 0.4
[ 3.693] X.Org Video Driver: 24.1
[ 3.693] X.Org XInput driver : 24.1
[ 3.693] X.Org Server Extension : 10.0
[ 3.694] (++) using VT number 7
[ 3.694] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 3.696] (--) PCI:*(0@0:2:0) 8086:3ea5:8086:2074 rev 1, Mem @ 0xbf000000/16777216, 0x80000000/268435456, I/O @ 0x00004000/64, BIOS @ 0x????????/131072
[ 3.696] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 3.696] (II) LoadModule: "glx"
[ 3.696] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 3.697] (II) Module glx: vendor="X.Org Foundation"
[ 3.697] compiled for 1.20.13, module version = 1.0.0
[ 3.697] ABI class: X.Org Server Extension, version 10.0
[ 3.697] (==) Matched modesetting as autoconfigured driver 0
[ 3.697] (==) Matched fbdev as autoconfigured driver 1
[ 3.697] (==) Matched vesa as autoconfigured driver 2
[ 3.697] (==) Assigned the driver to the xf86ConfigLayout
[ 3.697] (II) LoadModule: "modesetting"
[ 3.697] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 3.698] (II) Module modesetting: vendor="X.Org Foundation"
[ 3.698] compiled for 1.20.13, module version = 1.20.13
[ 3.698] Module class: X.Org Video Driver
[ 3.698] ABI class: X.Org Video Driver, version 24.1
[ 3.698] (II) LoadModule: "fbdev"
[ 3.698] (WW) Warning, couldn't open module fbdev
[ 3.698] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 3.698] (II) LoadModule: "vesa"
[ 3.698] (WW) Warning, couldn't open module vesa
[ 3.698] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 3.698] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 3.698] (EE) open /dev/dri/card0: No such file or directory
[ 3.698] (WW) Falling back to old probe method for modesetting
[ 3.698] (EE) Screen 0 deleted because of no matching config section.
[ 3.698] (II) UnloadModule: "modesetting"
[ 3.698] (EE) Device(s) detected, but none match those in the config file.
[ 3.698] (EE)
Fatal server error:
[ 3.698] (EE) no screens found(EE)
[ 3.698] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 3.698] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 3.698] (EE)
[ 3.698] (EE) Server terminated with error (1). Closing log file.
I have tried to fix the problem by creating /etc/systemd/sleep.conf.d/disable-hibernate.conf
with
AllowHibernation=no
and creating /etc/tlp.d/50-fix-pstate-crash.conf
with
CPU_MIN_PERF_ON_AC=100
CPU_MAX_PERF_ON_AC=100
CPU_MIN_PERF_ON_BAT=100
CPU_MAX_PERF_ON_BAT=100
I have also reinstalled the OS from manjaro-cinnamon-21.1.0-210826-linux513.iso.
