Hello there,
I have been daily driving my Manjaro KDE Plasma for almost half a year.
I have experienced several hard freezes on my system for the last two months.
The freezes made my PC completely unresponsive.
My keyboard and mouse were unresponsive, and unless I hard reset my system, I couldn’t get out of the freeze (REISUB/REISUO didn’t work because of that). Furthermore, whenever I tried to reconnect the USB of my keyboard, the light of the RGB did not come back.
Another freeze happened to me when I watched a YouTube video, and the video’s audio just kept looping.
I’m using Manjaro mainly for gaming (League of Legends etc.), web development, general programming, and browsing.
I’m running X11, kernel 6.1 LTS with KDE 5.27.4.
Here are the system information thank you @cscs for pointing me to that ![]()
Kernel: 6.1.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=872e7e02-40b2-4774-bdd7-a968669be84f rw quiet
resume=UUID=01c70591-250b-487a-8c89-232c9cb21e2e udev.log_priority=3
nvidia-drm.modeset=1
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Gigabyte model: B450 AORUS ELITE v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F62c
date: 05/10/2021
RAM: total: 23.41 GiB used: 4.24 GiB (18.1%)
Info: model: AMD Ryzen 7 3800X bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 32 MiB
desc: 2x16 MiB
Speed (MHz): avg: 2656 high: 4466 min/max: 2200/4559 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3803 2: 1985
3: 2015 4: 2200 5: 4466 6: 2200 7: 2551 8: 2200 9: 4071 10: 2200 11: 2041
12: 2016 13: 4192 14: 2027 15: 2557 16: 1985 bogomips: 124615
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: Gigabyte
driver: nvidia v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-03) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none off: HDMI-A-1
empty: DP-1,DP-2,HDMI-A-2 bus-ID: 07:00.0 chip-ID: 10de:2504 class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 93 s-size: 524x292mm (20.63x11.50")
s-diag: 600mm (23.62")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: Philips PHL 243V5
serial: <filter> built: 2017 res: 1920x1080 hz: 60 dpi: 94 gamma: 1.2
size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce RTX
3060/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GA106 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 1-3:2 chip-ID: 1038:12b3 pcie: gen: 3
class-ID: 0300 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 07:00.1 chip-ID: 10de:228e class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: SteelSeries ApS Arctis 1 Wireless type: USB
driver: hid-generic,snd-usb-audio,usbhid
API: ALSA v: k6.1.25-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-3: PipeWire v: 0.3.70 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-4: PulseAudio v: 16.1 status: active tools: pacat,pactl
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 3.62 TiB used: 463.21 GiB (12.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: Force MP510
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: ECFM22.6 temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EFRX-68FYTN0
type: HDD rpm: 5400 serial: <filter> rev: 0A82 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Toshiba model: DT01ACA050
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: A750 scheme: MBR
ID-1: / raw-size: 93.29 GiB size: 91.27 GiB (97.83%) used: 52.05 GiB (57.0%)
fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8 label: N/A
uuid: 872e7e02-40b2-4774-bdd7-a968669be84f
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p7 maj-min: 259:7
label: NO_LABEL uuid: 89A4-BEA0
ID-3: /home raw-size: 913.57 GiB size: 898.16 GiB (98.31%)
used: 411.16 GiB (45.8%) fs: ext4 dev: /dev/sdb6 maj-min: 8:22 label: N/A
uuid: a631decb-30d9-4e0b-b11c-a99f497db1c7
ID-1: swap-1 type: partition size: 15.63 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb5 maj-min: 8:21 label: N/A
uuid: 01c70591-250b-487a-8c89-232c9cb21e2e
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: 2E7F-A6A3
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 351.06 GiB fs: ntfs label: N/A
uuid: 56E2A44CE2A431E3
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 509 MiB fs: ntfs label: N/A
uuid: DAAEB31CAEB2EFDD
ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 512 MiB fs: vfat label: NO_LABEL
uuid: D724-4036
ID-6: /dev/nvme0n1p6 maj-min: 259:6 size: 1.16 GiB fs: vfat label: N/A
uuid: 15B0-C849
ID-7: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: ntfs
label: \xd7\x9b\xd7\x95\xd7\xa0\xd7\x9f \xd7\xa7\xd7\xa9\xd7\x99\xd7\x97
uuid: DECE1B73CE1B42E7
ID-8: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
ID-9: /dev/sdb2 maj-min: 8:18 size: 600 MiB fs: vfat label: N/A
uuid: ADB8-0557
ID-10: /dev/sdb3 maj-min: 8:19 size: 1024 MiB fs: ext4 label: N/A
uuid: dd80abbb-d05a-4ada-bfbc-dee2ad84db64
ID-11: /dev/sdb4 maj-min: 8:20 size: 932.22 GiB fs: ntfs label: N/A
uuid: 8E40B70A40B6F7D3
ID-12: /dev/sdc1 maj-min: 8:33 size: 465.76 GiB fs: ntfs label: N/A
uuid: A69CF9199CF8E4A9
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-3:2 info: SteelSeries ApS Arctis 1 Wireless type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 1038:12b3 class-ID: 0300
Device-2: 1-8:3 info: Cooler Master AMD SR4 lamplight Control
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 2516:0051 class-ID: 0300
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:2 info: Logitech G502 SE HERO Gaming Mouse type: Mouse,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 300mA
chip-ID: 046d:c08b class-ID: 0300 serial: <filter>
Device-2: 3-4:3 info: SteelSeries ApS Apex 150 Gaming Keyboard
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 400mA chip-ID: 1038:1616 class-ID: 0300
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 49.0 C mobo: N/A
Processes: 316 Uptime: 32m wakeups: 0 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1718
pm: pacman pkgs: 1694 libs: 482 tools: pamac,yay pm: flatpak pkgs: 24
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.26
Here’s a demonstration video I uploaded. Click here
If anyone can come to the rescue, I would appreciate it!
