Random Freezing/Not responding
Hi there, have a fresh installation of manjaro KDE and have experienced random freezes where the system is completely unresponsive and am forced to reboot.I run windows on the same disk and it does not experience any issue.
System info:
KDE Plasma Version: 5.21.4
KDE Frameworks Version: 5.81.0
Qt Version: 5.15.2
Kernel Version: 5.10.34-1-MANJARO
OS Type: 64-bit
Graphics Platform: X11
Processors: 4 × Intel® Core™ i7-4600U CPU @ 2.10GHz
Memory: 15.1 GiB of RAM
Graphics Processor: Mesa DRI Intel® HD Graphics 4400
Journal:
-- Journal begins at Sun 2021-05-09 20:52:22 EAT, ends at Sun 2021-05-09 23:52:21 EAT. --
May 09 21:00:49 datanav kernel: MDS CPU bug present and SMT on, data leak possible.
May 09 21:00:49 datanav kernel:  #2 #3
May 09 21:00:49 datanav kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
May 09 21:00:49 datanav kernel: mtrr: your CPUs had inconsistent variable MTRR settings
May 09 21:00:49 datanav kernel: ata2.00: supports DRM functions and may not be fully accessible
May 09 21:00:49 datanav kernel: ata2.00: NCQ Send/Recv Log not supported
May 09 21:00:49 datanav kernel: usb: port power management may be unreliable
May 09 21:00:50 datanav systemd[1]: logrotate.timer: Not using persistent file timestamp Sun 2021-05-09 23:22:09 EAT as it is in th>
May 09 21:00:50 datanav systemd[1]: man-db.timer: Not using persistent file timestamp Sun 2021-05-09 23:22:09 EAT as it is in the f>
May 09 21:00:50 datanav systemd[1]: pamac-cleancache.timer: Not using persistent file timestamp Sun 2021-05-09 23:22:09 EAT as it i>
May 09 21:00:50 datanav systemd[1]: pamac-mirrorlist.timer: Not using persistent file timestamp Sun 2021-05-09 23:22:09 EAT as it i>
May 09 21:00:50 datanav systemd[1]: pkgfile-update.timer: Not using persistent file timestamp Sun 2021-05-09 23:22:09 EAT as it is >
May 09 21:00:50 datanav systemd[1]: shadow.timer: Not using persistent file timestamp Sun 2021-05-09 23:22:09 EAT as it is in the f>
May 09 21:00:50 datanav kernel: resource sanity check: requesting [mem 0xfed10000-0xfed15fff], which spans more than Reserved [mem >
May 09 21:00:50 datanav kernel: caller snb_uncore_imc_init_box+0x82/0xd0 [intel_uncore] mapping multiple BARs
May 09 21:00:51 datanav kernel: at24 0-0050: supply vcc not found, using dummy regulator
May 09 21:00:52 datanav kernel: Bluetooth: hci0: unexpected event for opcode 0xfc2f
May 09 21:00:52 datanav NetworkManager[300]: <warn>  [1620583252.5167] sup-iface[7354b6d667cba506,0,wlo1]: call-p2p-cancel: failed >
May 09 21:00:53 datanav systemd-xdg-autostart-generator[793]: Configuration file /etc/xdg/autostart/msm_kde_notifier.desktop is mar>
May 09 21:00:54 datanav systemd[787]: -.slice: Failed to migrate controller cgroups from /user.slice/user-965.slice/user@965.servic>
May 09 21:00:54 datanav sddm-greeter[797]: QFont::fromString: Invalid description '(empty)'
May 09 21:00:54 datanav sddm-greeter[797]: QObject: Cannot create children for a parent that is in a different thread.
                                           (Parent is QGuiApplication(0x7fff8d61a450), parent's thread is QThread(0x55b030ba0dd0), >
lines 1-30
  1. In the future, when providing code/output, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text so that the output looks like this:
    Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua.
    Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat.
    Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur.
    Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
    instead of like this:
    Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.`
    (as that makes both our lives much easier)
  2. No need to do anything right now as I’m an editor here on this site and have fixed it for you already. However, in the future I might not see your post so review my edits by pushing the orange pencil above the post I just fixed. :wink:
  3. As you’re on kernel 5.10 and have an AMD integrated graphics card, have you tried 5.4 LTS already? (and 5.12 would be my next choice)
:+1:
Thanks Fabby for the clarification and edit.
I will change kernel version and monitor how the system will behave.
Thank you again.
If you’re running into trouble installing 5.4 or 5.12, please do this:
  • Print this page so you have it as a reference while in TTY2
  • Log off
  • Switch to TTY2 by pressing Ctrl+Alt+F2
  • Log in there
  • Execute:
    sudo mhwd-kernel --install linux54
    sudo mhwd-kernel --install linux512
  • to ensure grub is showing, execute:
    sudo nano --backup /etc/default/grub
  • Change (or add?) the following 3 lines:
    GRUB_TIMEOUT=3
    #GRUB_HIDDEN_TIMEOUT=0
    #GRUB_TIMEOUT_STYLE=hidden
    (3 or higher is fine, add the # before the lines above if those lines are present)
  • Ctrl+X Y Enter to save if there is anything to save
  • If you did save, execute:
    sudo update-grub
  • Reboot
  • Go to grub’s Advanced options
  • Choose these kernels one by one and try them out one by one and see if that helps.
:+1:
Fabby,
After changing and installing kernel 5.4 i still experienced the freeze. Will try kernel 5.12 and see what will happen.
  • If upgrading the kernel to 5.12 wouldn’t help neither, please try to create a new user and log in there and see if you have the issue there as well. (E.G. couch2)
  • if the above doesn’t help neither, please:
    • Post the output of an
    • Run the following in a terminal (and keep that terminal open, minimized is fine):
      watch --interval=3 'free --human > /var/tmp/myfree.txt'
    • when the problem arrives:
      • note the exact time
      • REISUB
      • Post the output of:
        journalctl --system --boot=-1 --since "YYYY-MM-DD HH:MM:SS" --until "YYYY-MM-DD HH:MM:SS"
      where YYYY-MM-DD is obviously the date and HH:MM:SS is 3 seconds before and after the freeze issue.
      • Obviously, provide the contents of /var/tmp/myfree.txt too
:thinking:
the last step might be impossible to do since when the freeze happens it continues until i have to do a cold reboot…
Are you saying that you’ve followed the tutorial and activated sysrq_always_enabled=1 but once you get a freeze, REISUB doesn’t work???
:thinking:
Created a new user and haven’t experienced any freeze so far. Is there any reason as to why the freeze is happening on the original account and not on the second one?
  • It happens that user profiles get corrupted especially if you experiment with multiple DEs (or a bunch of old unmaintained themes) with a single user… :sob:
  • Verify that the new user has access to the same groups as your old one by executing groups and comparing the output of both users.
    groups couch
    groups couch2
    (Where obviously, couch is your old user and couch2 is your new one.)
    E.G. if couch is a member of operator and couch2 isn’t, execute:
    usermod --append --groups operator couch2
  • Copy all data files from your old profile into your new one
    cp --verbose --recursive --preserve=time-stamps /home/couch/Documents/* /home/couch2/Documents/
    If that worked and you had no errors, remove the documents from your old user:
    rm --recursive /home/couch/Documents/*
    repeat for:
    • Pictures
    • Videos
    • Music
    • .thunderbird
    • .mozilla/firefox/
    • Templates, and everything else that is important to you.
    • Linux games like Battle of Wesnoth have their game data stored under ~/.local/share/ E.G. ~/.local/share/wesnoth/
    After everything has been copied over, disable the old user so you cannot accidentally log on:
    usermod --lock couch
    If you would have theming going on, don’t do everything in one day but do this at the rate of 1 application / theme / whatever per day and if the same issue crops up again, roll back your last change
  • in 1 month delete the entire home directory of your old user, but don’t delete the user itself so that in 6 months time files still owned by that user will still show up under its username.
  • If you ever migrate to a new machine, just don’t migrate the old user: only the new one.
  • From now on, start making backups so you can roll back and never have to do this again:
Fabby, the funny thing is that this was a new installation. Practically new, nothing saved in all those directories and no special programs installed, so migrating to this new account will be easy. Below is the outcome of groups command
wheel lp sys network power kevin
[mbugua@Datanav ~]$ groups mbugua
audio lp optical video sys network scanner power mbugua
[mbugua@Datanav ~]$
kevin is the old user and it seems he had far much less rights than the new account. Tried issuing the wheel rights to the new account but was met with an access denied error or do i need to switch to the old account and issue the rights from there?
To protect people from themselves by reading and applying random posts on the internet, I never include sudo in any of my commands, so:
sandwich
Did not get the joke at all… :man_shrugging:
Being extremely clear now:
Execute:
sudo usermod --append --groups wheel mbugua
:wink:
I can humbly confirm that the system is fine now with no freezes at all! Creating a new user and upgrading the kernel to version 5.12.1-2 solved the issue. Thank you fabby!
Well it froze again, completely unusable until a hard reboot had to be done.
The freeze started by inter changing the mouse button functions, then went completely ice, even the backlight keyboard lights would not go off. They stayed on until the reboot. Then even after rebooting the same thing happened all over again!
  Kernel: 5.12.1-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
  root=UUID=28eb9023-ea6d-4dc6-91eb-e41f64b8dd69 ro quiet apparmor=1
  security=apparmor resume=UUID=e8bade99-7070-4a59-bb67-adad67c1e659
  udev.log_priority=3
  Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: Hewlett-Packard product: HP EliteBook Folio 9480m
  v: A3009DD10303 serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: Hewlett-Packard model: 22DA v: KBC Version 92.17 serial: <filter>
  BIOS: Hewlett-Packard v: M85 Ver. 01.50 date: 02/24/2020
  ID-1: BAT0 charge: 21.1 Wh (100.0%) condition: 21.1/21.1 Wh (100.0%)
  volts: 16.4 min: 14.8 model: Hewlett-Packard Primary type: Li-ion
  serial: <filter> status: Full
  RAM: total: 15.06 GiB used: 1.88 GiB (12.5%)
  Info: Dual Core model: Intel Core i7-4600U bits: 64 type: MT MCP
  arch: Haswell family: 6 model-id: 45 (69) stepping: 1 microcode: 26 cache:
  L2: 4 MiB bogomips: 21556
  Speed: 1099 MHz min/max: 800/3300 MHz Core speeds (MHz): 1: 1099 2: 843
  3: 959 4: 2096
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts
  clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm
  dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase
  fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx
  monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
  pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good
  sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
  tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave
  xsaveopt xtopology xtpr
  Type: l1tf
  Device-1: Intel Haswell-ULT Integrated Graphics vendor: Hewlett-Packard
  driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0a16 class-ID: 0300
  Device-2: Cheng Uei Precision Industry (Foxlink) HP EliteBook integrated HD
  Webcam
  type: USB driver: uvcvideo bus-ID: 2-7:5 chip-ID: 05c8:0374 class-ID: 0e02
  Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
  loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
  screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
  s-diag: 414mm (16.3")
  Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 112 size: 310x170mm (12.2x6.7")
  diag: 354mm (13.9")
  OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2)
  v: 4.5 Mesa 21.0.3 compat-v: 3.0 direct render: Yes
  Device-1: Intel Haswell-ULT HD Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c
  class-ID: 0403
  Device-2: Intel 8 Series HD Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20
  class-ID: 0403
  Sound Server-1: ALSA v: k5.12.1-2-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.26 running: yes
  Device-1: Intel Ethernet I218-LM vendor: Hewlett-Packard driver: e1000e
  v: kernel port: 5080 bus-ID: 00:19.0 chip-ID: 8086:155a class-ID: 0200
  IF: enp0s25 state: down mac: <filter>
  Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel port: ef80
  bus-ID: 08:00.0 chip-ID: 8086:08b1 class-ID: 0280
  bus-ID: 2-4:3 chip-ID: 8087:07dc class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Local Storage: total: 238.47 GiB used: 20.24 GiB (8.5%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZ7PD256HCGM-000H7
  size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  rotation: SSD serial: <filter> rev: 6H6Q scheme: MBR
  ID-1: / raw-size: 94.73 GiB size: 92.74 GiB (97.90%) used: 20.24 GiB (21.8%)
  fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
  uuid: 28eb9023-ea6d-4dc6-91eb-e41f64b8dd69
  ID-1: swap-1 type: partition size: 5.86 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/sda6 maj-min: 8:6 label: N/A
  uuid: e8bade99-7070-4a59-bb67-adad67c1e659
  ID-1: /dev/sda1 maj-min: 8:1 size: 549 MiB fs: ntfs label: System Reserved
  uuid: 3BB43BDF5A6D727C
  ID-2: /dev/sda2 maj-min: 8:2 size: 136.68 GiB fs: ntfs label: N/A
  uuid: B8D09D6CD09D321C
  ID-3: /dev/sda3 maj-min: 8:3 size: 685 MiB fs: ntfs label: N/A
  uuid: BA4C23DE4C2393E3
  ID-4: /dev/sda4 maj-min: 8:4 size: 1 KiB fs: <superuser required> label: N/A
  uuid: N/A
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
  Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
  speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 9 rev: 2.0
  Hub-4: 2-3:2 info: Microchip (formerly SMSC) Hub ports: 3 rev: 2.1
  speed: 480 Mb/s chip-ID: 0424:2134 class-ID: 0900
  Device-1: 2-3.2:4 info: Logitech Unifying Receiver type: Mouse,HID
  driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
  power: 98mA chip-ID: 046d:c52f class-ID: 0300
  Device-2: 2-4:3 info: Intel Bluetooth wireless interface type: Bluetooth
  Device-3: 2-7:5 info: Cheng Uei Precision Industry (Foxlink) HP EliteBook
  integrated HD Webcam
  type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
  power: 500mA chip-ID: 05c8:0374 class-ID: 0e02
  Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
  Hub-6: 3-3:2 info: Microchip (formerly SMSC) Hub ports: 3 rev: 3.0
  speed: 5 Gb/s chip-ID: 0424:5534 class-ID: 0900
  System Temperatures: cpu: 55.0 C mobo: 0.0 C
  Processes: 193 Uptime: 7m wakeups: 1 Init: systemd v: 247 tool: systemctl
  Compilers: gcc: 10.2.0 Packages: pacman: 1272 lib: 382 flatpak: 0
  Shell: Bash v: 5.1.4 running-in: yakuake inxi: 3.3.04
Didn’t note the time for a journalctl.
I hope you did a REISUB??? If not; that is a sure way of messing up your system partition and getting all kinds of trouble!
After the above REISUB, please?
While I’m looking into that, please also:
  • Try another mouse
  • have a look if there is a BIOS / UEFI firmware upgrade for your machine…
:scream:
Fabby,
Failed to parse timestamp: “2021-05-21
[kevinm@DataNav ~]$ journalctl --system --boot=-1 --since “2021-05-21 14:19:01” --until “2021-05-21 14:20:01”
Oh wow. there is a bug in journalctl. it used to be able to do that just a few days ago… :sob:
So do it manually: redirect to a text file and cut the superfluous information.
How about:
:question:
Its was the internal touchpad and not an external mouse. And nop i dont have any new Bios update for my PC…also been trying to do a REISUB but nop it does not work either. If i hold ALT key and press the buttons, it just highlights the usual ALT shortcuts on the browser. Also noticed with the current form of freeze, i can restart the PC by pressing the power button and choosing “restart”. Apparently only the DE(plus the apps already opened) is freezing. And it has happened thrice in 5 minutes so far. Would it be due to the updates that were pushed early on this week?
Also i have no clue how to export the journal data to a text file(novice human being here)
