Hello, I’m a new Manjaro user and I really like this system very much, but there are some thing that ruin my workflow. I tried to fix them by myself, but my trying was futile, so after awhile I decided to create a topic on Manjaro forum.
I’m using laptop HP Pavilion 15-cx with nvidia gtx 1050 mobile and using drivers hybrid-nvidia-intel prime.
Manjaro is my primal OS with no dualboot whatsoever and OS is located on NVMe driver. I run bios with disabled security boot and without legacy mode (from my understanding I’m boot from uefi, could be wrong tho)
As I said in my headline, Manjaro often freezes completely leaving me no choice but to use hard reset, sometimes it’s just freezes for a short time (seeing it more often when doing something like watching youtube videos), one time it was lagging for some long time but in the end I have to hard reset, it did happen when I tried to delete wine through pamac. (could be somethign with proccesor) Often Manjaro likes to kill/crush my libre office writer when I’m in the middle of the work.
When I close the laptop’s lid there’s around 50% chance that when I open lid after a while I’ll see a black screen with LED on my keyboard still on (if i recall correctly), leaving me only one option to do a hard reset. It’s probably happen more often when i close the lid with youtube video still on and in fullscreen.
After I close the lid sometimes fans still working. One time i closed the lid and hear fans spinning, but i wen to sleep and after i wake up all power from laptop was drain and it was unable to power on for some time.
I’m using Firefox and like to open a bunch of tabs (could be between 10 and 40), from what I was reading on forums i have some guesses with which could be some problems. Maybe i don’t have swap on my system, but I’m inexperienced and didn’t get to how to make it, could be some problems with my hybrid graphics or some problems with NVMe, I did install TLP and TLP UI for power management, but didn’t get anything useful from TLP UI. Also could be something with BIOS. I tried a few versions of kernel (5.4; 5.10), I believe results are the same.
Here’s my system information:
inxi --admin --verbosity=7 --filter --width
Kernel: 5.4.207-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=f80d4a95-3df9-439a-a286-44988d8123e4 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-cx0xxx
v: Type1ProductConfigId serial: <superuser required> Chassis: type: 10
Mobo: HP model: 8478 v: 70.60 serial: <superuser required> UEFI: Insyde
v: F.26 date: 08/10/2021
ID-1: BAT1 charge: 53.3 Wh (100.0%) condition: 53.3/52.7 Wh (101.0%)
volts: 13.0 min: 11.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: full
RAM: total: 7.66 GiB used: 3.4 GiB (44.4%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i5-8300H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158)
stepping: 0xA (10) microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1712 high: 3998 min/max: 800/4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 900 3: 912 4: 3998
5: 2742 6: 2178 7: 1172 8: 900 bogomips: 36812
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
prctl and seccomp
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Hewlett-Packard
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile]
vendor: Hewlett-Packard driver: nvidia v: 515.57
alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current (as of
2022-07) arch: Pascal code: GP10x process: TSMC 16nm built: 2016-21 pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
bus-ID: 01:00.0 chip-ID: 10de:1c8c class-ID: 0300
Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD
Integrated Webcam type: USB driver: uvcvideo bus-ID: 1-5:2
chip-ID: 05c8:03bc class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: AU Optronics 0x23ed built: 2016 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 22.1.4
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fb9
class-ID: 0403
Sound Server-1: ALSA v: k5.4.207-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
vendor: Hewlett-Packard driver: rtw_pci v: N/A modules: rtwpci pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:b822
class-ID: 0280
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-14:3 chip-ID: 0bda:b00b class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 476.94 GiB used: 236.24 GiB (49.5%)
model: MZVLB512HAJQ-000H1 size: 476.94 GiB block-size: physical: 512 B
rev: EXA73H1Q scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%) used: 236.24 GiB
(50.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: f80d4a95-3df9-439a-a286-44988d8123e4
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: NO_LABEL
uuid: AF9C-86FF
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-1:4 info: Holtek E-Signal LUOM G10 Mechanical Gaming Mouse
type: Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 04d9:a09f class-ID: 0300
Device-2: 1-5:2 info: Cheng Uei Precision Industry (Foxlink) HP Wide
Vision HD Integrated Webcam type: Video driver: uvcvideo interfaces: 2
rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 05c8:03bc class-ID: 0e02
Device-3: 1-14:3 info: Realtek Bluetooth 4.2 Adapter type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 52.0 C pch: 54.0 C mobo: N/A
Processes: 235 Uptime: 6m wakeups: 1 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: pacman: 1438
lib: 451 flatpak: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.20
Looking forward for any advises and suggestion related to at least one of the issues!
