Okay, she doesn’t actually catch fire. but she does halt!
I unwrapped a brand-new RX6600 (bought from a store! at MSRP! I know!) on the 29th or so. It replaced my RX580.
Initially, I got a very confusing issue where Xfce refused to start. Kernel update to 5.15 fixed that.
The dektop boots! yay! but after maybe ten minutes, the whole system freezes, blackscreens, and reboots.
[ TODO: capture a journalctl -b-1
of the crash ]
Reinstalling the entire OS didn’t help.
I installed Ubuntu, and have been running glmark2
for a while now and it hasn’t crashed so I think it’s a bug specific to Manjaro, but I can’t say for sure.
I’m not smart enough to figure out what part of the OS is causing the crash. Send help!
Output of inxi --admin --verbosity=7 --filter --width
after fresh install and pacman -Syyu
Kernel: 5.15.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=86e2567e-67a9-4912-9243-075688e00ee7 rw quiet apparmor=1
security=apparmor resume=UUID=f97e718b-3cfd-4490-b346-f252f97cd876
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Gigabyte product: B450 AORUS PRO WIFI v: N/A
serial: <superuser required>
Mobo: Gigabyte model: B450 AORUS PRO WIFI-CF v: x.x
serial: <superuser required> UEFI: American Megatrends v: F51
date: 07/29/2020
RAM: total: 15.63 GiB used: 1.91 GiB (12.2%)
RAM Report:
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 2561 high: 4192 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3593 2: 2051
3: 2049 4: 2196 5: 2194 6: 2195 7: 3582 8: 4192 9: 2095 10: 2196 11: 2194
12: 2196 bogomips: 86271
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse
sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
conditional, RSB filling
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: ASUSTeK
driver: amdgpu v: kernel bus-ID: 0a:00.0 chip-ID: 1002:73ff class-ID: 0300
Display: x11 server: X.Org 1.21.1.2 compositor: xfwm4 v: 4.16.1 driver:
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2")
s-diag: 1055mm (41.5")
Monitor-1: DisplayPort-1 res: 1920x1080 hz: 60 dpi: 82
size: 598x336mm (23.5x13.2") diag: 686mm (27")
Monitor-2: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 92
size: 531x299mm (20.9x11.8") diag: 609mm (24")
Device-1: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
driver: snd_hda_intel v: kernel bus-ID: 0a:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 0c:00.4 chip-ID: 1022:1487
class-ID: 0403
Sound Server-1: ALSA v: k5.15.7-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: no
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
port: f000 bus-ID: 03:00.0 chip-ID: 8086:1539 class-ID: 0200
Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel bus-ID: 04:00.0
chip-ID: 8086:2526 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-5:3 chip-ID: 8087:0025 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 4.26 TiB used: 8.94 GiB (0.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000DM000-1F2168
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 5900 serial: <filter> rev: CC52 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Intel model: SSDSC2CT120A3
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 300i scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 500GB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Netac model: OnlyDisk
size: 57.99 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 8.07 scheme: MBR
ID-1: / raw-size: 94.3 GiB size: 92.26 GiB (97.84%) used: 8.94 GiB (9.7%)
fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 86e2567e-67a9-4912-9243-075688e00ee7
used: 288 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
uuid: 1F49-4F5B
ID-1: swap-1 type: partition size: 17.2 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb3 maj-min: 8:19 label: swap
uuid: f97e718b-3cfd-4490-b346-f252f97cd876
ID-1: /dev/sda1 maj-min: 8:1 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda2 maj-min: 8:2 size: 3.64 TiB fs: ntfs label: Victoria
uuid: 3092E79392E75C3A
ID-3: /dev/sda3 maj-min: 8:3 size: 1.95 GiB fs: ntfs label: Backup_Boot
uuid: 4C6AF9AC6AF99346
ID-4: /dev/sdc1 maj-min: 8:33 size: 100 MiB fs: vfat label: N/A
uuid: 342D-15CF
ID-5: /dev/sdc2 maj-min: 8:34 size: 16 MiB fs: <superuser required>
ID-6: /dev/sdc3 maj-min: 8:35 size: 465.16 GiB fs: ntfs
label: Zephyr Aspiration uuid: 40362E0A362E0210
ID-7: /dev/sdc4 maj-min: 8:36 size: 499 MiB fs: ntfs label: N/A
uuid: 1C74D7F474D7CEA0
ID-8: /dev/sdd1 maj-min: 8:49 size: 3.3 GiB fs: iso9660
ID-9: /dev/sdd2 maj-min: 8:50 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 92C2-BE26
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-3:2 info: Netac OnlyDisk type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA
chip-ID: 0dd8:2300 class-ID: 0806 serial: <filter>
Device-2: 1-5:3 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0025 class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-4: 3-1:2 info: VIA Labs Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 2109:3431 class-ID: 0900
Hub-5: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
Hub-6: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-2:2 info: IBM NetVista Full Width Keyboard type: Keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 04b3:3025 class-ID: 0301
Device-2: 5-4:3 info: SINOWEALTH Game Mouse type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 480mA chip-ID: 258a:1007 class-ID: 0301
Hub-7: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 33.0 C mem: 32.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 326 Uptime: 12m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 1076 lib: 314 flatpak: 0 Shell: Bash
v: 5.1.12 running-in: xfce4-terminal inxi: 3.3.11
Output of xrandr
Screen 0: minimum 320 x 200, current 3840 x 1080, maximum 16384 x 16384
DisplayPort-0 disconnected primary (normal left inverted right x axis y axis)
DisplayPort-1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 598mm x 336mm
1920x1080 60.00*+ 143.85 119.98 59.94
1680x1050 59.95
1280x1024 75.02 60.02
1440x900 59.89
1280x960 60.00
1280x800 60.00
1152x864 75.00
1280x720 60.00 59.94
1440x576 50.00
1024x768 75.03 70.07 60.00
1440x480 60.00 59.94
800x600 72.19 75.00 60.32 56.25
720x480 60.00 59.94
640x480 75.00 72.81 66.67 60.00 59.94
720x400 70.08
DisplayPort-2 disconnected (normal left inverted right x axis y axis)
HDMI-A-0 connected 1920x1080+1920+0 (normal left inverted right x axis y axis) 531mm x 299mm
1920x1080 60.00*+ 50.00 59.94
1680x1050 59.88
1440x900 59.90
1280x960 60.00
1280x800 59.91
1152x864 75.00
1280x720 60.00 50.00 59.94
832x624 74.55
720x576 50.00
720x480 60.00 59.94
720x400 70.08
