kyhou
16 July 2022 03:43
1
So, I just installed a Radeon RX 5600 XT on my PC, before that I was using the iGPU (Vega 11) from my CPU, a Ryzen 5 3400G.
It booted with no problems that I could see, but, when I tried playing some games, the performance was horrible, for example, Ori and the will of the wisps was supposed to be able to run with 100+ fps, but I’m stuck with +/- 35 FPS.
I already searched everywhere for a solution but nothing worked.
I’m new here so I don’t know what data would be helpful, so please let me know and I will provide it ASAP.
Thanks!
Hello,
Is your Monitor connected to the dGPU (dedicated GPU and not the discrete one) … In some cases you either disable the iGPU from BIOS, or go with something like:
DRI_PRIME=1 <command>
to use the dGPU …
Also, make sure you actually use the AMDGPU drivers and not the Radeon drivers.
Follow this [HowTo] Provide System Information and share that information here, so we have more context.
kyhou
16 July 2022 15:29
3
Kernel: 5.18.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
root=UUID=a6c51957-e530-4074-9bcb-051fc0ba9c37 rw apparmor=1
security=apparmor resume=UUID=5bfa974e-aa78-4029-80f0-dacea72517fb
udev.log_priority=3 amdgpu.ppfeaturemask=0xffffffff
Desktop: GNOME v: 42.3.1 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM
v: 42.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: Micro-Star model: B450 GAMING PLUS (MS-7B86) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.H2
date: 02/05/2021
RAM: total: 15.55 GiB used: 6.81 GiB (43.8%)
RAM Report:
Info: model: AMD Ryzen 5 3400G with Radeon Vega Graphics bits: 64
type: MT MCP arch: Zen/Zen+ note: check gen: 1 built: 2019 process: GF 12nm
family: 0x17 (23) model-id: 0x18 (24) stepping: 1 microcode: 0x8108109
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1423 high: 1634 min/max: 1400/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: ondemand cores: 1: 1432 2: 1361
3: 1379 4: 1434 5: 1407 6: 1361 7: 1376 8: 1634 bogomips: 59112
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm
mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rapl rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap
smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock
syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2
mitigation: Retpolines, IBPB: conditional, STIBP: disabled, RSB filling
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: ASRock driver: amdgpu v: kernel arch: RDNA 1 process: TSMC n7 (7nm)
built: 2019-20 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 12:00.0 chip-ID: 1002:731f
class-ID: 0300
Display: x11 server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.2
compositor: gnome-shell driver: X: loaded: amdgpu unloaded: vesa gpu: amdgpu
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: LG (GoldStar) 22MP55
built: 2014 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 477x268mm (18.78x10.55") diag: 547mm (21.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
OpenGL: renderer: AMD Radeon RX 5600 XT (navi10 LLVM 14.0.6 DRM 3.46
5.18.10-1-MANJARO)
v: 4.6 Mesa 22.1.3 direct render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
bus-ID: 3-4:2 pcie: chip-ID: 0d8c:000c gen: 4 class-ID: 0300 speed: 16 GT/s
lanes: 16 bus-ID: 12:00.1 chip-ID: 1002:ab38 class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
bus-ID: 30:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: C-Media Audio Adapter type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound Server-1: ALSA v: k5.18.10-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.54 running: yes
vendor: Micro-Star MSI driver: r8168 v: 8.049.02-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 22:00.0
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Microsoft Xbox 360 Wireless Adapter type: USB driver: xpad
bus-ID: 1-9:4 chip-ID: 045e:0719 class-ID: ff00 serial: <filter>
Local Storage: total: 2.3 TiB used: 1.24 TiB (54.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KingSpec model: NE-512
lanes: 4 type: SSD serial: <filter> rev: S1111A0L temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST9750420AS
size: 698.64 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: SDM5 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WDS240G2G0A-00JH30 size: 223.58 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0000
scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: SanDisk model: Cruzer Blade
size: 29.25 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: MBR
ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: Samsung model: M3 Portable
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1301 scheme: MBR
ID-1: / raw-size: 467.84 GiB size: 459.43 GiB (98.20%)
used: 357.6 GiB (77.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: a6c51957-e530-4074-9bcb-051fc0ba9c37
label: NO_LABEL uuid: 3E36-479F
ID-3: /run/media/joel/C99E-43B1 raw-size: 29.25 GiB
size: 29.23 GiB (99.95%) used: 1.13 GiB (3.9%) fs: vfat dev: /dev/sdc1
maj-min: 8:33 label: N/A uuid: C99E-43B1
ID-4: /run/media/joel/SAMSUNG raw-size: 931.51 GiB
size: 931.51 GiB (100.00%) used: 915.02 GiB (98.2%) fs: ntfs dev: /dev/sdd1
maj-min: 8:49 label: SAMSUNG uuid: F838C80738C7C2BC
ID-1: swap-1 type: partition size: 8.8 GiB used: 406.7 MiB (4.5%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 5bfa974e-aa78-4029-80f0-dacea72517fb
ID-1: /dev/sda1 maj-min: 8:1 size: 698.64 GiB fs: ntfs label: N/A
uuid: 000038860002BBC0
ID-2: /dev/sdb1 maj-min: 8:17 size: 499 MiB fs: ntfs
label: Recupera\xc3\xa7\xc3\xa3o uuid: 0EB64ABFB64AA755
ID-3: /dev/sdb2 maj-min: 8:18 size: 100 MiB fs: vfat label: N/A
uuid: 9A4B-7000
ID-4: /dev/sdb3 maj-min: 8:19 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-5: /dev/sdb4 maj-min: 8:20 size: 222.45 GiB fs: ntfs label: N/A
uuid: 44088287088277A6
ID-6: /dev/sdb5 maj-min: 8:21 size: 538 MiB fs: ntfs label: N/A
uuid: 42E00231E0022BAB
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-3:2 info: SanDisk Cruzer Blade type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA
chip-ID: 0781:5567 class-ID: 0806 serial: <filter>
Device-2: 1-8:3 info: Pixart Imaging Gaming Mouse type: Mouse,Keyboard
power: 100mA chip-ID: 093a:2533 class-ID: 0300
Device-3: 1-9:4 info: Microsoft Xbox 360 Wireless Adapter type: WiFi
driver: xpad interfaces: 8 rev: 2.0 speed: 12 Mb/s power: 260mA
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Device-1: 2-2:2 info: Samsung M3 Portable Hard Drive 1TB
type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 8mA chip-ID: 04e8:61b6 class-ID: 0806 serial: <filter>
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-4:2 info: C-Media Audio Adapter type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0d8c:000c class-ID: 0300
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Device-1: 5-1:2 info: BY Tech Gaming Keyboard type: Keyboard,HID
power: 500mA chip-ID: 258a:0049 class-ID: 0300
Hub-6: 6-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 34.0 C mem: 34.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1024
Processes: 376 Uptime: 11h 36m wakeups: 14 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6
Packages: 1597 pacman: 1593 lib: 425 flatpak: 0 snap: 4 Shell: Zsh v: 5.9
running-in: terminator inxi: 3.3.19
Yes, and I disabled it in BIOS
kyhou
17 July 2022 23:10
4
So, after a lot of testing I got a workaround.
After I turn the PC on, I first open Trackmania 2020 and enter any map. After this every other game that I play will have the correct performance.
I don’t know if it will work with any other game, but I think this could give a clue to the problem.
